27th September 2023, 11:23 | #181 | Link |
Version 18 beta 4 has been released
Version 18 beta 4 has been released.
Download: Zoom Player BETA Changes in this beta: * New feature! + Changed feature! - Fixed feature! * The IPTV auto-updating EPG and Stream List downloads can now handle ".zip" and ".gz" archive URLs (e.g. "https://website.com/epg.zip"). * New Filter EPG feature on the IPTV interface. * New IPTV setting (Adv. Options / Playback / IPTV) that controls the EPG font size. * New IPTV setting (Adv. Options / Playback / IPTV) to control whether the EPG filter checks program description or only the program's title. * New "Custom Action" button on the main window (near the top-left) that allows you to set any standard Zoom Player function to the button. By default this button opens the new IPTV interface. * New Setting (Adv. Options / Interface) that allows you to assign a function to the new "Custom Action" button. - The IPTV interface should feel a bit smoother (less flickering). - In the media library's category editor, specifying a category name containing unicode characters would not highlight the entry in the category list after clicking. - Media Title containing certain unicode characters (e.g. emoji) did not show when loading some playlist formats (m3u, asx, b4s, wpl). Previous beta changes since the release of version 17.5: http://inmatrix.com/files/zoomplayer_whatsnew_beta_18.shtml |
4th October 2023, 08:58 | #182 | Link |
Version 18 beta 5 has been released
Version 18 beta 5 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * You can now select IPTV streams as favorites and they automatically show up under a "Favorites" group at the start of the stream list. You can right click a favorite stream to re-arrange or sort your favorites list or simply remove the stream from the favorites section. * You can now hide IPTV groups from being listed by right-clicking the group and selecting "Hide Group" or through the options dialog. * Right-clicking an IPTV EPG entry will now show the program's description and allow you to set a notification to remind you that the program is about to start as well as specify that you want to automatically switch to the program's stream in due time. Notifications are remembered even if you close and re-open Zoom Player, but they will not activate if Zoom Player is not running. * New Hidden IPTV Group controls (Adv. Options / Playback / IPTV). * New Setting (Adv. Options / Interface / Control Bar / Timeline Area) that allows you to control whether the timeline displays the current playlist track number. You can also toggle this setting through the control bar menu by right-clicking the timeline with nothing playing (or middle-clicking if something is playing). * The Advanced Playlist Control interface is now accessible through the right-click menu under the "Open Interface" section. + Optimized EPG parsing, improving load time by 5-15%. + The playlist editor's search feature has been enhanced to support repeated search. Simply press Enter to cycle between all entries that contain the searched term. + The Station Manager window now has an "X" in the corner to close the window (previously you had to click the "close" button). - The Media Libary's category editor's "Playlist" category option did not display categories correctly if they had certain unicode characters in the name (e.g. Emojis). Previous beta changes since the release of version 17.5: http://inmatrix.com/files/zoomplayer..._beta_18.shtml |
9th October 2023, 13:19 | #183 | Link |
Version 18 beta 6 has been released
Version 18 beta 6 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * This feature has been requested by many. The ability to scale Zoom Player's skinned windows to make them easier to use on 4K and 8K displays: New Setting (Adv. Options / System) that allows you to resize the current windowed skin by 200-800%. Please note that this setting may not work well with some older Zoom Player skins. * New button added to the IPTV interface that allows you to toggle the EPG display on and off. * New IPTV setting (Adv. Options / Playback / IPTV) to hide old EPG entries (programs that have already aired). * New Search feature in the media library category editor. + Redesigned the media library category editor layout. Hopefully it's clearer and easier to work with. + Pressing ESC with the player window in focus now closes the IPTV interface window. + Pressing ESC now closes the "Patterns" interface instead of having to cycle through every pattern. - You can no longer set an IPTV program start notification or switching to the live stream if the EPG entry is older than the current time (has already finished airing). - The IPTV notification message before a program starts will now remain visible for several more seconds. - Loading M3U playlists containing links to other M3U playlists, no longer tries to insert the embedded playlists as part of the loaded playlists, which can cause many unforeseen issues. - Loading some M3U playlists in the playlist editor did not always show the media's title. - Opening a stream from the IPTV interface in fullscreen mode would hide the IPTV interface in the background behind the video window. - Under some conditions, the "Add Folder to Category" and "Remove Folder" buttons in the media library category editor were enabled for Plugin based categories which would have allowed you to mess up these categories if you were not careful. - When adding a new plugin based Media Library category, you can no longer add duplicate entries even after renaming the category. - In the media library category editor, you could press the "Remove Folder" button when selecting the "Folders:" entry instead of an actual folder. - Trying to use Ctrl+V to paste a search term into the playlist editor's search field would result in "????" when trying to paste unicode characters or emoji. Previous beta changes since the release of version 17.5: http://inmatrix.com/files/zoomplayer..._beta_18.shtml |
16th October 2023, 12:35 | #184 | Link |
Version 18 beta 7 has been released
Version 18 beta 7 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * You can now easily multiply Zoom Player's windowed skin resolution from the skin selection dialog (press "N" to open) to better match Zoom Player's skin to your monitor's resolution. * You can now time-shift IPTV channels in the EPG by right-clicking an EPG entry. * New IPTV Safe mode setting (Adv. Options / Playback / IPTV) that blocks access to Hiding Groups, Adding/Modifying favorites and EPG Time Shifting. + Zoom Player will load slightly faster when using a multiplied resolution skin. + Zoom Player's title text now scrolls if there is no room to show the entire text. - Filtering the media library by Genre stopped working. Previous beta changes since the release of version 17.5: http://inmatrix.com/files/zoomplayer..._beta_18.shtml |
23rd October 2023, 13:20 | #186 | Link |
Version 18 beta 8 has been released
Version 18 beta 8 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * New Wakeup on LAN feature (Adv. Options / System) that allows you to turn on PCs. This feature is extremely useful when using NAS (Network Attached Storage) devices as your source for the media and you only want to turn them on when using Zoom Player. With this new feature, you can specify multiple MAC addresses to wake several PCs and you can trigger the wake-up action with a choice of conditions such as: 1. When starting Zoom Player 2. When opening the Media Library 3. When opening the File Navigator If there are other use-cases where you would want Zoom Player to wake-up remote PCs, let me know. * New button on the IPTV Interface to toggle 50% window transparency. * New IPTV setting to merge duplicate channels. This can be useful if you're using multiple EPG files/links that contain EPG info on the same channel. * New IPTV setting (enabled by default) to keep the IPTV interface window on top of other windows and applications while Zoom Player is in fullscreen mode. * New IPTV setting to control the screen ratio between the stream list and the EPG. The default value is 1:1.5 (Making the EPG 150% wider than the stream list). * If an IPTV channel doesn't have a logo in the M3U playlist file, Zoom Player now tries to use an icon from the EPG XML file and caches the logo so it shows even if you keep the EPG panel closed. + To prevent distracting confirmation messages popping up, the IPTV interface no longer prompts you to update the list once an IPTV M3U playlist or XML EPG finished downloading, instead it will enable a refresh button which you can click at your leisure. + Enhanced IPTV stream list keyboard navigation. + When opening the IPTV interface with the EPG hidden, the EPG data will not load until the EPG section is opened which results in the IPTV interface becoming accessible faster. + When loading IPTV playlists, if a channel does not contain ID information, Zoom Player will try to match EPG entries based on the channel name instead. + IPTV channel logos should appear faster if there are broken links in the M3U playlist file. + Closing and opening the IPTV interface window now restores the previously opened group layout. - Resizing the IPTV interface window could leave trails on screen until the stream list was scrolled. - Right clicking a history entry and selecting "copy" in the playback history interface returned a jumble result when copying links. - The scroll bar on the description section of the IPTV program information dialog accessible by right-clicking an EPG program did not show/hide properly based on the window size. Previous beta changes since the release of version 17.5: http://inmatrix.com/files/zoomplayer..._beta_18.shtml |
23rd October 2023, 13:24 | #187 | Link |
Yes, Zoom Player supports several different types of plugins", for example, here's a plugin for the media library's YouTube plugin:
https://github.com/bLightZP/Delphi-Y...or-Zoom-Player |
31st October 2023, 13:10 | #188 | Link |
Version 18 beta 9 has been released
Version 18 beta 9 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * Added a clock to the top of the IPTV's Electronic Program Guide section. * Added a button to clear the IPTV channel logo cache (Adv. Options / Playback / IPTV). Clearing the logo cache forces Zoom Player to re-download the channel icons. + If an IPTV channel doesn't have a logo or ID in the M3U playlist file, Zoom Player now tries to use an icon from the EPG XML file based on the channel name (or partial name) and caches the logo so it shows even if you keep the EPG panel closed. + IPTV Stream Channel -> EPG matching by Channel name (when a Channel ID is not present) now works when the EPG contains multiple channel names for the same channel. + IPTV Stream Channel -> EPG matching by Channel name (when a Channel ID is not present) now matches even if there is an uppercase/lowercase mismatch in the name or the EPG contains only a partial name. + IPTV Stream Channel -> EPG matching by Channel name is now automatic if no EPG data was found using the Channel's ID. + The IPTV section of the options dialog is now a lot more informative with regards to the Playlist/EPG download status (or failure). + Closing and re-opening the IPTV interface will now maintain the EPG listing. - Refreshing the IPTV list after a new Playlist or EPG finished downloading should now maintain open groups and EPG listing. - Fixed a bug that prevented some IPTV channel logo from saving properly and may have even caused the wrong icon to show up for some channels. - The IPTV Stream list did not display correctly if specifying a DPI value higher than 100% in Zoom Player's options. Previous beta changes since the release of version 17.5: http://inmatrix.com/files/zoomplayer..._beta_18.shtml |
8th November 2023, 12:53 | #189 | Link |
Version 18 beta 10 has been released
Version 18 beta 10 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * Support for IPTV Archive playback. For channels that support it, double-click the program to start playing it. You can easily identify Archive supporting channels by the icon next to their name. There are multiple implementations of IPTV Archive support and I did my best to make sure all were covered, but if something is not working as intended, let me know on Zoom Player's sub-reddit. * New IPTV Setting (Adv. Options / Playback / IPTV) that clears the playlist before streaming. This setting is enabled by default, disabling it adds the channel to the playlist and play it without clearing the playlist. * New Setting (Adv. Options / Interface / Playlist) to prevent embedded playlists (playlist files within playlist files) from loading when Zoom Player loads a playlist. This setting is enabled by default as embedded playlist can lead to unfortunate infinite-loops cases and other stability problems. + Playing media from the Advanced Playlist Control now ensures the newly played item is visible in the Playlist Editor. + I Didn't like the behavior of the new setting (enabled by default) that automatically hide the control bar when clicking the video area. What annoyed me was that it was canceling my action, so if I wanted to pause the video, it would ignore the pause action and just hide the control bar. Now I adjusted this feature to hide the control bar and not block the intended action. - Fixed a bug that caused the IPTV caches to get wiped clear when Zoom Player was pruning the media library thumbnail and meta-data cache. - Playing an entry from the Advanced Playlist Control interface no longer loses the entry's selection. Previous beta changes since the release of version 17.5: http://inmatrix.com/files/zoomplayer..._beta_18.shtml |
15th November 2023, 11:35 | #190 | Link |
Version 18 release candidate 1 has been released
Version 18 release candidate 1 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * Opening the IPTV interface for the first time now offers you the option to automatically download free, child-friendly, publicly available IPTV channels from around the world through the Free-TV project: https://github.com/Free-TV/IPTV * Using the "Play Stream" button on the IPTV interface will no longer try to play an EPG program and will always try to play the channel live. * New "Play Program" button on the IPTV interface. The "Play Program" button is used to play archived IPTV programs. If the channel does not support archive playback or if the selected program is no longer (or not yet) archived, the "Play Program" button will remain disabled. * New "Add Free Channels" button (Adv. Options / Playback / IPTV) that adds free, child-friendly, publicly available IPTV channels from around the world through the Free-TV project. * You can now control outdated EPG programs background colors (Adv. Options / Playback / IPTV), making it easier to distinguish which programs have already aired. * Support for more IPTV Archive playback schemes (including "Flussonic"). * New Setting (Adv. Options / Playback / IPTV) to specify the symbol used to highlight archive channels in the IPTV stream list. - No longer marking IPTV channels as archive if their "catchup-days" value is "0". - The Playlist Editor's search box did not support unicode characters. - You can now use Ctrl+V to paste Unicode text into the Playlist Editor's search box (including special characters such as Emoji). - Fixed a bug that could cause Zoom Player to freeze when trying to play YouTube URLs containing a space character after the URL. Previous beta changes since the release of version 17.5: http://inmatrix.com/files/zoomplayer..._beta_18.shtml Last edited by Godwin; 16th November 2023 at 12:52. |
26th November 2023, 09:56 | #191 | Link |
Version 18 release candidate 2 has been released
Version 18 release candidate 2 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * New IPTV color-highlighting for the playing channel and program (on channels that support archive playback). You can tweak the colors in the options dialog. * New Setting (Adv. Options / Playback / IPTV) to hide outdated archive channel EPG entries that are too old to stream. * New Setting (Adv. Options / Interface / Playlist) that specifies the default Playlist Load / Save folder. If nothing is specified, the standard windows supplied path is used. * New Setting (Adv. Options / Interface / Playlist) that controls whether Zoom Player should ask you for a confirmation when you clear the playlist. * New Setting (Adv. Options / Interface) to control whether text that has no room to display fully starts scrolling. Currently this only applies to the main window's title text. + The IPTV EPG files are now loaded and parsed in a background thread. This means that the interface should open quickly and you can close it even before the EPG data is finished parsing so the entire interface should feel faster. This change should also fix issues caused when Windows thinks Zoom Player's window has become unresponsive while parsing EPG data (for example, on some systems I got reports that the IPTV window would lose it's "on top" value). - Trying to play a video with an external audio track, for example: "myvideo.mkv" and "myvideo.mp3" in the same folder with the "Load External Audio tracks" setting enabled, resulted in a lot of instability. I rewrote the whole interface and now it's much more stable. Please note that this feature also requires Zoom Player's DSP filter to be enabled (Adv. Options / Playback / Audio - Enable Internal DSP Filter). - The Playlist Editor's "Load Playlist" feature accidentally listed media files instead of playlists by default. - The Folder Browser dialog should no longer appear partially off-screen or hidden by the task bar. - Fixed an IPTV EPG Filtering issue where entering a value into the filter box and then switching to another channel would make it impossible to clear the filtering value. - Under some conditions, the play history fullscreen navigation interface could show a value of "00:00:-1" for the last play position. - When using a non-default font, the play history last play position could mess with the alignment of the file/url. - IPTV Logo caching from EPG files did not work properly for some entries based solely on channel name. - Playing too many broken URLs or files is sequence could have resulted in play history entries being generated even though nothing was played. - Reduced the chances of showing IPTV EPG information for the wrong channel when using badly crafted playlist or EPG sources. Previous beta changes since the release of version 17.5: http://inmatrix.com/files/zoomplayer..._beta_18.shtml |
20th December 2023, 10:34 | #192 | Link |
Zoom Player v18 final has been released
Zoom Player v18 final has been released: Highlights:
Download : What's new |
10th January 2024, 11:32 | #193 | Link |
Version 19 beta 1 has been released
Version 19 beta 1 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * Zoom Player has integrated libVLC, the media engine used by the VLC media player. This integrating means that several new features that were unique to VLC are now available in Zoom Player, leveraging the reliability of VLC with Zoom Player's powerful and customizable user interface. In theory, Zoom Player's default choice of Microsoft's DirectShow media engine is superior to libVLC in a lot of ways. DirectShow is a lower-level, allowing me to develop unique features that are impossible to do with libVLC. At the same time and due to it's complexity, there may be cases where libVLC can be more reliable than DirectShow. By default only BluRay discs play using libVLC due to libVLC's support for playing BluRay discs with menus. However, since this is Zoom Player you're reading about, the ultimate choice of which engine to use is up to you! You can enable libVLC specifically for BluRay discs, IPTV streaming, media playback (by file extension) and open-ended streaming (by URL, for example "youtube") under the new advanced options section (Adv. Options / Playback / libVLC). To use libVLC you must either install the latest version of the 32bit VLC player or install libVLC from the install center (it does not conflict with existing VLC installations). Most Zoom Player features are compatible with the new media engine: - BluRay Playback with Menus! Enabled by default, opening a drive, folder or the "index.bdmv" file begins BluRay playback. Menus are navigated using the standard navigation keys (up/down/left/right Arrows + Enter keys). The same limitation that apply to playing BluRay discs in VLC applies when using the libVLC media engine in Zoom Player, along with any glitches. This means that you must have Java installed for the BluRay menus to work and that playing encrypted discs will not work by default. As for the glitches, I encountered cases where 4K BluRay videos can freeze and verified that the same issue happens in the original VLC player. - Aspect Ratio Controls: Zoom Player's powerful aspect ratio controls are fully supported. - Subtitle Display: Other than re-positioning the subtitles on-screen, most of Zoom Player subtitle features should work great with libVLC. - Add Subtitle Track on Drag & Drop / Add Sub file: You can easily add subtitle files by drag & dropping files on Zoom Player's window or by opening a subtitle file after the video is loaded. - Subtitle Synchronization Adjustments: You can adjust subtitle synchronization through the standard keyboard macros (Alt+Ctrl+"+" and Alt+Ctrl+"-" on the keypad). - Color Controls: Brightness, Contrast, Saturation and Hue color controls are available. - Audio Framework Device Selection: libVLC is pretty flexible in it's audio device selection offering three different frameworks (MMDevice, DirectSound and WaveOut). Zoom Player makes it easy to choose the framework that works best for your PC. - Audio Track Selection & Cycle: Easily select and cycle between multiple audio tracks. - Audio Synchronization Adjustments: You can adjust audio synchronization using the standard keyboard macros (Shift+"+" and Shift+"-" on the keypad). - Virtual Video Editing with BluRay Movies with Menus: The scene cut feature that allows you to virtually edit videos should now be compatible with BluRay titles with Menus when using libVLC. However, this feature has not been heavily tested so please let me know on reddit if it's not working as expected. - Play History (position, audio track, subtitle track): Zoom Player's play history feature which can save and restore the last play position, active audio, subtitle tracks and more is fully compatible. - Play Rates (fast play, slow motion): Fast Play and Slow Motion might even work on more media formats than supported by DirectShow, give it a try. - Load Embedded Chapters (Bookmarks): Using libVLC, Zoom Player can read embedded chapters or bookmarks from both media files and BluRay titles. - Load External Audio Tracks for playing video: Full support for one or more external audio tracks. - Play Next Frame: The next frame feature is fully supported. - Screenshot: The screenshot keyboard macro (Alt+"F") is fully compatible with libVLC with the exception that the screenshot file format is limited to ".png". + And since this is just a beta, there's more to come! * New "Pause closes unseekable live stream (otherwise ignored)" setting that controls if Zoom Player closes a live stream when pausing or if the pause is ignored. Previously the hard-coded default was to close the stream, the new (configurable) default is to ignore the pause command. * New button on the IPTV interface to quickly open the IPTV settings page in the advanced options dialog. + To support chapters (bookmarks) using the VLC Media Engine, I had to rewrite nearly all of Zoom Player's code related to managing chapters. Please let me know if something broke. As a bonus, you can now use emojis and other special Unicode characters in the chapter names. + Media chapters with no titles will now show a "no title" title. + The IPTV stream list group layout (open/close) is now saved and restored even after closing Zoom Player. + The Custom Action button's hint when hovering with the mouse now lists the assigned function and not just a general "Custom Action". + Cleaned up a few of the advanced options dialog pages. - Trying to switch to the next audio track no longer tries to set an audio track if there is only one track present (caused muted audio for a second or two). - Failing to play an IPTV stream will no longer highlight that stream as the active stream. - You should no longer be able to erase embedded chapter entries (it didn't really do anything). - Fixed all sorts of goofs that were possible through the chapter editor. Previous changes since the release of version 18: http://inmatrix.com/files/zoomplayer..._beta_19.shtml |
12th January 2024, 20:02 | #194 | Link |
Are you maybe planning to support goodies like libplacebo too ??
MPC-BE feature wishlist: 1) DiscID 2) Two independent volume control sliders in the UI when using directsound dual-audio-out. |
24th January 2024, 14:11 | #195 | Link |
Version 19 beta 2 has been released
Version 19 beta 2 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * Running Zoom Player on a fresh install will now asks if you would like to enable "Performance Mode". Choosing "Yes" does two things: 1. Enables D3D11 hardware accelerated video decoding in LAV Filters, a requirement for smooth 4K video playback. 2. Sets the Video Renderer to MadVR, enabling HDR video support, high quality video scaling, hardware accelerated subtitle rendering and smoother motion. Both settings can be modified in the advanced options dialog: Adv. Options / Playback / Video * A new "Help" section has been added to the right-click menu. The new help section can quickly bring up the keyboard shortcut list or quick usage guides for many of Zoom Player's popular interfaces. * New keyboard macros to toggle libVLC playback: Alt+"6" - Toggle libVLC IPTV playback (enabled/disabled) Alt+"7" - Toggle libVLC BluRay playback (enabled/disabled) Alt+"8" - Toggle libVLC Media file playback (enabled/disabled) Alt+"9" - Toggle libVLC Streaming playback (enabled/disabled) These toggles still require that you re-open the playing media to take affect. * The right-click menu has been extended with a new "Help" section. The help section provides quick access to the keyboard shortcut list and quick usage guides for most of Zoom Player's interfaces. * The Play History dialog (Alt+"H") has gotten a face-lift, an option whether to clear the playlist when playing from history, a button that automatically sets the column sizes based on the current window size and you can drag the play history window with the mouse by clicking in any empty space. * New "/infojson" command line parameter that can be used to query a running instance of Zoom Player for information. The results are returned in the windows clipboard as a UTF8 encoded JSON string. This feature can be used in combination with Window's Powershell to monitor and control Zoom Player entirely through the command line, without requiring a TCP/IP connection to access the more advanced API. Special characters are encoding using standard JSON character encoding. If no additional parameters are specified, all fields are returned. To get specific results, you can use a combination of one or more of the following: PlayState - A number representing the current play state where 0 : Closed 1 : Stopped 2 : Paused 3 : Playing MediaName - UTF8 string containing the playing file name or URL. Title - UTF8 string containing the playing media's title. Position - The playing position in seconds. Duration - The playing duration in seconds. PlayIndex - The current playlist play index. Playlist - UTF8 string containing the current playlist, each media entry is specified as a part of a JSON array. AudTrack - The current audio track number. SubTrack - The current subtitle track number. Example to get the playing media name, title, duration and position: zplayer.exe /infojson:MediaName,Title,Duration,Position + The keyboard shortcuts list (F1 keyboard shortcut) is now a single dialog which opens much faster and is no longer a part of the options dialog which takes longer to open. + The "Toggle Control Bar" right-click menu option has been re-located to the menu's root level. + If the playing media has only one audio track, it will no longer be listed in the Stream Selection section of the right-click menu. + If MadVR is selected as the Video Renderer without being installed, Zoom Player now notifies you and falls back to the EVR renderer. - A bug caused some information dialogs to show the information in the window's title and the actual title in the windows body. - Fixed several libVLC related bugs, if you're still seeing issues, please let me know on Zoom Player's Community: https://reddit.com/r/zoomplayer Previous beta changes since the release of version 18: http://inmatrix.com/files/zoomplayer..._beta_19.shtml |
8th February 2024, 18:29 | #196 | Link |
Version 19 beta 3 has been released
Version 19 beta 3 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * You can now use libVLC to cast the playing video to supported ChromeCast devices. All you need to do is open "Adv. Options / Playback / libVLC" and scan for the ChromeCast device. Any content played through the libVLC engine will now display on the selected device. Please consider that it can take a few seconds longer to open media files for casting. * MPC-VR can now be selected as a Video Renderer for media playback. It is not fully supported (subtitles, pixel-shaders and other unique features for the video renderer will not work presently. * New Setting (Adv. Options / Playback / Control) that allows you to rollback the current play position when resuming playback from the Pause state. This feature is useful if you have an external receiver that requires a few seconds to restore the audio when playback resumes. + If you previously used as Custom Video Renderer for media playback, you must re-select the custom option (Adv. Options / Playback / Video). + Using the Next/Previous Track features now ensures the newly loaded track is visible in the playlist editor. + Cleaned up some dialogs that had elements that were too close together, especially under Windows 11. - Scraping TheMusicDB should work once again. - When Zoom Player's DSP filter is unable to connect to the audio renderer, the DSP filter is now removed so Smart Play will not fail (fallback to Microsoft's method of choosing components can be unstable), increasing overall stability for badly authored media files. - Fixed a bug that caused the media library background image to be overlaid twice with a slight offset, slowing down opening a folder in the media library a little bit and causing visual ghosting effects (was really hard to see with the default background image). Previous beta changes since the release of version 18: http://inmatrix.com/files/zoomplayer..._beta_19.shtml |
22nd February 2024, 18:57 | #197 | Link |
Version 19 beta 4 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * The playlist editor has received support for multiple playlists that you can instantly switch between. Multiple playlists are loaded in a background thread so even if you use massive playlists with 1000's of items, it should not have much of an impact Zoom Player's load and close time performance. Press the new multi-playlist button on the playlist editor (top left corner) to add the current playlist, a playlist from a file or manage the multiple playlists (remove, rename, reorder). You can see me develop this feature live here: Part 1 : https://www.youtube.com/watch?v=6hhQoJ0kkoA Part 2 : https://www.youtube.com/watch?v=2GLUuymiz_Y * New "Cast to Device" feature on the main right-click menu and available as a keyboard shortcut (Shift+"/") that allows you to Cast the currently playing media to a Chromecast compatible device. This feature does requires libVLC is installed but does not require you to play the current media with libVLC (the playback engines automatically switch as the media is casted). You can see me develop this feature live here: https://www.youtube.com/watch?v=A3eDBtunqZc * New "1510" Zoom Player API message that is triggered when using next/previous chapter. Returns the chapter's position in seconds. - Fixed a bug that caused the background image to show for a split- second when dragging & dropping a media file on top of the player window. Previous beta changes since the release of version 18: http://inmatrix.com/files/zoomplayer..._beta_19.shtml |
14th March 2024, 19:01 | #198 | Link |
Version 19 beta 5 has been released
Version 19 beta 5 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * The IPTV dialog now allows you to filter the stream list by playlist name. You can see me code most of this feature on this live-stream: https://www.youtube.com/watch?v=nSjr8ExbZmM * You can now define custom names for IPTV playlists and Electronic Program Guide sources (Adv. Options / Playback / IPTV). You can see me code this feature on this live-stream: https://www.youtube.com/watch?v=nSjr8ExbZmM * New Setting (Adv. Options / Playback / History) that allows you to hide the "Recent" items section from the Windows taskbar button's right-click menu. * New Setting (Adv. Options / Interface / Mouse / Settings) that allows you to specify the number of seconds to seek when using the mouse wheel while hovering over the timeline area. The default seek distance is 5 seconds. * New label for the skin selection dialog to make it clearer that you can scale the skin resolution by a factor of 100% - 800%. - Zoom Player's "Export Settings" function did not include 4 setting files: 1. Media Favorites (files and URLs). 2. Media Library TAGs. 3. Media Library Collections. 4. IPTV Favorites. - Fixed a bug introduced in v19 beta 3 that prevented the mouse wheel from scrolling through the timeline. Previous beta changes since the release of version 18: http://inmatrix.com/files/zoomplayer..._beta_19.shtml |
12th April 2024, 19:19 | #199 | Link |
Version 19 beta 6 has been released
Version 19 beta 6 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * Added support for the new H.266 VVC (Versatile Video Codec) format. LAV Filters v0.79 is required for decoding. Please note that VCC support is experimental and not fully optimized. To properly support VCC in resolutions above 1080p would require hardware accelerated decoding which is not currently supported by any GPU or CPU. * Added Equalizer and Pre-Amp support for the libVLC media engine, please note that the values work a bit differently when compared to the DirectShow Equalizer values. * Preferred Audio Device switching (Shift+"A") now works with libVLC. You can define you preferred devices in the advanced options dialog's libVLC section. * New Setting (Adv. Options / Interface / Playlist) that allows you to play the next media file in the same folder when using the Del key to erase the currently playing media (or using the home theater delete option). You can see me code this feature here: https://www.youtube.com/watch?v=bs2QS5gd4VU * New Setting (Adv. Options / Interface / On Screen Display / Actions) that allows to force the OSD Actions (Play, Pause, Volume, etc) to appear on a monitor of your choice. You can see me code this feature here: https://www.youtube.com/watch?v=bs2QS5gd4VU * To support IPTV providers that require a specific user agent text to access automated downloads, you can now set a custom User Agent for each IPTV auto update entry (for both playlists and EPGs downloads). * New "Configure" button next to the Video Renderer selection drop-down list (Adv. Options / Playback / Video). * New "exMediaVidRender" extended function that allows you to switch the media video renderer at any point. As an extended function, this functionality can be accessed through the command line or TCP/IP APIs. You can see me code this feature here: https://www.youtube.com/watch?v=hr3FmIi8crI * Selecting a URL based IPTV playlist or EPG entry in the options dialog, now displays the full text in a hover-hint. + Using Zoom Player to browse the web (for example, using the "/browse" command line parameter) now uses Microsoft's Chromium based WebView2 browser engine and only falls back to the old Chakra engine is WebView2 is not installed (available on the install center, comes preinstalled in Windows 11). You can see me code this feature here: https://www.youtube.com/watch?v=bs2QS5gd4VU - The Play History editor and fullscreen navigation interface can now re-play files with a path longer than 255 characters. - The playlist entries in the IPTV stream list drop-down would get duplicated after updated playlists were downloaded in the background. - Pressing Alt+S to bring up the subtitle component's configuration dialog did not show the correct window title in some cases. - Pressing Shift+"B" to disable the subtitles caused the subtitles to remain enabled when reloading the media, even if the setting to restore the previous subtitle track was enabled in the advanced options dialog. You can see me fix this code here: https://www.youtube.com/watch?v=bs2QS5gd4VU - Fixed a really weird stability issue with the IPTV window that could have caused a freeze when trying to close the window and stream logos to never appear. - Detaching the control bar, moving it to another monitor and then hovering with the mouse pointer over the timeline area would show the current position indicator window on the wrong monitor. - With the "Show all filters in Stream Selection sub-menu" setting enabled, the right-click's "Stream Selection" section would show a small cosmetic glitch (an empty section). - Setting the YouTube Channel media library plugin's "channel list strategy" to "Use 'upload' playlist" did not list the videos returned by YouTube in the correct air date order and the air date was not displayed at all. Previous beta changes since the release of version 18: http://inmatrix.com/files/zoomplayer..._beta_19.shtml |
1st May 2024, 14:03 | #200 | Link |
Version 19 release candidate 1 has been released
Version 19 release candidate 1 has been released.
Download: http://inmatrix.com/files/zoomplayer_beta.shtml Changes in this beta: * New feature! + Changed feature! - Fixed feature! * MPC-VR can now be selected as a Video Renderer for media playback. Some of this video renderer's features are not yet supported (e.g. pixel-shaders). But subtitles and Dolby Vision support do work thanks to the help of Chetan Ullal and his work on the MPC-VR Subtitle Helper component: https://github.com/Chetan-Ullal/MPC-...elper/releases * Added support for 2 more IPTV archive playback modes. * The IPTV EPG (Electroic Program Guide) will now add EPG "No Info" entries for missing time blocks, allowing archived playback for these time blocks. You can see me live coding this feature here: https://www.youtube.com/watch?v=mQldufSuJfU * Enabling IPTV's "Safe Mode" now hides the IPTV settings button shortcut from the IPTV interface. * New "exSetAudioBalance" extended function (not assigned to any key) that can be used to specify an exact balance percent value from "-100" (left) to "100" (right). A value of "0" resets the balance changes. Please note that using this function will not update the balance widget in the user interface, only the actual audio balance on the output device. * New setting on the media library's YouTube plugins (disabled by default) to filter videos shorter than a specified number of seconds with a default value of 62 seconds (to hide shorts). You can see me live coding this feature here: https://www.youtube.com/watch?v=r7V_F62j4C4 * New "Activities" search strategy option on the media library's YouTube plugins. I was hopeful the "Activities" entry point into YouTube's DATA v3 API would provide more reliable results, but it seems limited to uploads in the last 2 months and some uploads will simply not show up. + The media library's YouTube Playlist plugin now retrieves the playlist, channel name and thumbnail automatically. Since the playlist image usually reflects the last uploaded video, the plugin will use the channel's thumbnail for the playlist instead, but you can disable this behavior in the plugin's configuration dialog. Previously you had to manually specify the playlist name and a generic thumbnail was used. You can see me live coding a portion of this feature here: https://www.youtube.com/watch?v=r7V_F62j4C4 + The options window's search feature does a better job at highlighting the selected element from the search result. + Opening the play history dialog (Alt+"H") for the very first time now uses reasonable initial values for the columns. + The default mouse wheel function on new install is now set to volume adjustments instead of the previous default that Zoomed in/out. + The "Please upgrade" dialog now shows the current Zoom Player version. - Fixed a bug introduced in one of the v19 betas that prevented a URL from being replayed through the play history interfaces. - When creating a media library YouTube channel with an "@" channel name prefix, for example "https://www.youtube.com/@zptechnology", YouTube can return multiple channels if they share the same name. The fix now checks all the channel to make sure their customURL field matches the name in the specified URL. - The Setting (Adv. Options / Interface / On Screen Display / Actions) that allows to force the OSD Actions (Play, Pause, Volume, etc) to appear on a monitor of your choice did not work correctly, showing the OSD on the same monitor as the player window instead. - Using Shift+"/" to Cast a video using libVLC accidentally forced all the next videos to play using the libVLC media engine until Zoom Player was restarted. - Fixed a few cases where changing the current play position was not shown correctly in the active playlist entry. - When playing media of unknown video resolution, the timeline will no longer display "0x0" if you enabled resolution display on the timeline. - Playing audio-only media files using the libVLC engine did not show the audio mode TAG display. Please note that audio-only media detection using the libVLC engine is based on the media file's extension, for example ".mp3" or ".wav". Previous beta changes since the release of version 18: http://inmatrix.com/files/zoomplayer..._beta_19.shtml |
dvd, htpc, media player, tablet, zoom player |
