Old 28th September 2021, 04:24   #1  |  Link
markfilipak
markfilipak's Avatar
Location: Mansfield, Ohio (formerly San Jose, California)
motion vector interpolation
Are the calling parameters for these:
  • vapoursynth.core.svp1.Super()
  • vapoursynth.core.svp1.Analyse()
  • vapoursynth.core.svp2.SmoothFps()
identical to the calling parameters for these:If not, are the vapoursynth svp1 & svp2 namespace functions documented? Where?
If so, is there any other place where the functions are documented/discussed. I ask because I find the svp-team docs to be somewhat vague and would appreciate a different perspective.
Also:
What is your opinion of the Super()-Analyse()-SmoothFps() workflow?
What are some other workflows I should consider?
Apparently, no one uses the motion vectors stored in the source frames. Do you know why?
Note: I'm not streaming and don't need/don't want motion vector interpolation in real time.
Thanks for guidance,
Mark.
markfilipak is offline   Reply With Quote
Old 29th September 2021, 22:43   #2  |  Link
Milardo
Also:
Mark.
Hi, although not complete: this site gives a bit of explanation and sample scriipts auto generated:
https://bare7a.github.io/SVP-Flow-Sc...generator.html
Milardo is offline   Reply With Quote
Old 29th September 2021, 23:36   #3  |  Link
ChaosKing
Why not simply ask the creator of SVP? https://www.svp-team.com/forum/viewforum.php?id=7
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
Old 30th September 2021, 16:06   #4  |  Link
Selur
Selur's Avatar
There's no SVConvert in Vapoursynth, but the mentioned parameters are the same as SV.. ones.
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
analyse, mv interpolation, smoothfps, super
