Old 23rd March 2012, 14:06   #1  |  Link
GEfS
What different between x264 offical, kMod, tMod
x264 Offical by JEEB
x264 kMod by Komisar
x264 tMod by astrataro
It's what i know about 3 versions.
Who can tell me what different between 3 versions
GEfS is offline   Reply With Quote
Old 23rd March 2012, 14:34   #2  |  Link
J_Darnley
J_Darnley's Avatar
Various patches. I'm sure the patches used are listed next to downloads.
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 23rd March 2012, 17:22   #3  |  Link
upyzl
zj262144
upyzl's Avatar
for kMod, see The list "Used patches for builds"
for tMod, see 06_taro's Blog
P.S. JEEB also compiling Mod ver
and it's better say "vanilla" than "official" for x264's builds
MPC-HC 1.7.8 / LAV Filters 0.64+ (tMod) / XySubFilter 3.1.0.705 / madVR 0.87.14
Direct264 Mod (src & win32 builds): code.google.com/p/direct264umod (maybe outdated)
upyzl is offline   Reply With Quote
Old 23rd January 2015, 16:16   #4  |  Link
Ajvar
I know it's old thread but...
Who knows why Clear Builds (claimed so) on Komisar's site are 8-10MB size while on videolan's site they are just 1-3MB?
I just don't get what exe files to put in Xvid4PSP 5 directory as update.
Ajvar is offline   Reply With Quote
Old 23rd January 2015, 17:45   #5  |  Link
kabelbrand
Compression mode: Lousy
kabelbrand's Avatar
Theo videolan builds are compressed with upx and should be roughly the same size as komisars builds if uncompressed.
kabelbrand is offline   Reply With Quote
Old 24th January 2015, 12:46   #6  |  Link
komisar
komisar's Avatar
no... because videolan-build without ffmpeg/libav/lsmash/gpac/ffms library compiled
64-bit:
x264 core:144 r2525 40bb568
Syntax: x264 [options] -o outfile infile
Infile can be raw (in which case resolution is required),
or YUV4MPEG (*.y4m),
or Avisynth if compiled with support (yes).
or libav* formats if compiled with lavf support (no) or ffms support (no).
Outfile type is selected by filename:
.264 -> Raw bytestream
.mkv -> Matroska
.flv -> Flash Video
.mp4 -> MP4 if compiled with GPAC or L-SMASH support (no)
Output bit depth: 8 (configured at compile time)
32-bit:
x264 core:142 r2491 24e4fed
or libav* formats if compiled with lavf support (yes) or ffms support (no).
.mkv -> Matroska
.flv -> Flash Video
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline   Reply With Quote
Old 25th January 2015, 13:31   #7  |  Link
kabelbrand
kabelbrand's Avatar
The videolan builds are compressed with upx and should be roughly the same size as komisars builds if uncompressed.
Wait a minute! The libraries might differ too but at least the win32 videolan build is also UPX compressed:
upx -d x264-r2491-24e4fed.exe
                       Ultimate Packer for eXecutables
                          Copyright (C) 1996 - 2013
UPX 3.09w       Markus Oberhumer, Laszlo Molnar & John Reiser   Feb 18th 2013
        File size         Ratio      Format      Name
   8667136 <-   4033024   46.53%    win32/pe     x264-r2491-24e4fed.exe
Unpacked 1 file.
Old 25th January 2015, 14:13   #8  |  Link
Groucho2004
I can't understand why people still do that. It may have been useful when hard drives were smaller than 1GB but nowadays it just is ridiculous, not to mention a potential bug source and the cause of several virus scanners going nuts.
Old 25th January 2015, 21:46   #9  |  Link
benwaggoner
Perhaps the more interesting question is "what is each build optimized for/what are its goals?"
For my personal stuff I tend to use kMod since it's got all kinds of other useful libraries compiled into it, and probably inertia. I don't know what other ones might have to offer these days. Stuff compiled in Intel's ICC for better performance versus GCC used to be a thing, but I not heard much about that lately.
Do folks have other recommendations based on features/performance/reliability/correctness?
Ben Waggoner
My Compression Book
Old 12th February 2023, 12:35   #10  |  Link
PoeBear
Can someone smarter than I break down the actual differences between the builds: kMod?, tMod?, LigH and videolan's builds?, jpsdr's build? I see mention of the patches, but what are they actually adding? Are some builds missing certain useful/important patches? New commands, like the aq-mode 4/5 in the custom x265 builds? Are they just further optimized for newer compilers and architectures? Or maybe a little of both? Patch merges are bit beyond my reading comprehension
LigH, VideoLAN, and jdspr's x264s still seem to be updated regularly and I'm just wondering which one I should be using, if there's even a feature difference, or perhaps there's even another build I've missed (those 3 are just the ones in the x264 thread OP). Since this thread still comes up when Google searching for info on them, I figured I may as well just bump it for others like me
PoeBear is offline   Reply With Quote
