Old 6th October 2014, 06:51   #21  |  Link
gnol009
Thank you very much. Work like a charm
gnol009 is offline   Reply With Quote
Old 30th March 2015, 00:44   #22  |  Link
Prune(), New version v1.11, see 1st post.
27/Mar/2012 - ver 1.10      - Added Nicknames.
30/Mar/2015 - ver 1.11 - Added v2.6 dll. Shows Nicknames when Show.
v2.6 dll allows view metrics on v2.6 colorspace frames.
EDIT: Added to avs files
Avisource("D:\avs\test.avi")
ConvertToYV24       # v2.6
V0 = Last
V1 = FlipVertical
V2 = FlipHorizontal
V3 = TurnRight.BilinearResize(Width,Height)
V4 = TurnLeft.BilinearResize(Width,Height)
V5 = Invert
NickNames ="""  # Psuedonyms for clips (clip index number)
    ButlinsBytheSea_76       = 0
    PontinsRainedOut_77      = 1
    BultinsBognorRegis_78    = 2
    BultinsSkegness_79       = 3
    PontinsCamberSands_80    = 4
    PontinsLowestoft_81      = 5
SCMD="""          # Clip editing commands in string, can also use commands in file
    ButlinsBytheSea_76       500,600
    PontinsRainedOut_77      900,1000
    BultinsBognorRegis_78    1400,1600
    BultinsSkegness_79       2000,2400
    PontinsCamberSands_80    2640,3000
    PontinsLowestoft_81      4400,4800
    PontinsRainedOut_77      5000,5400
    5                        6000,6500    # clip index instead of nickname
    1                        6501,7000
SHOW=True
Prune(V0,V1,V2,V3,V4,V5,scmd=SCMD,nickname=NickNames,show=SHOW,FadeIn=True,FadeSplice=True,FadeOut=True)
return ConvertToRGB32   # For YV24 viewing
EDIT: Also added this [also included in FrameSel() plug zip]
Function RejectRanges(clip c,String "SCmd",String "Cmd",Bool "TrimAudio",Float "FadeMS") {
    # RejectRanges() by StainlessS. Required:- FrameSel, Prune, RT_Stats
    # Wrapper to delete frames/ranges along with audio, can supply frames/ranges in SCmd string And/Or Cmd file.
    #   The wrapper makes for easier usage of Prune() which supports up to 256 input clips, but requires a clip index,
    #   eg '3, 100,200' would specify clip 3, range 100 to 200. The wrapper does away with the necessity for the clip index as we
    #   are only using a single clip here. Prune also does not have a 'reject' arg to delete specified frames rather than select them,
    #   this wrapper also converts a list of frames to delete into a list of frames to select so that we can use Prune and its audio
    #   capability.
    # SCmd: Frames/Ranges specified in String (Frames/Ranges either Chr(10) or ';' separated, infix ',' specifies range, eg 'start,end').
    # Cmd:  Frames/Ranges specified in file (one frame/range per line, comments also allowed, see FrameSel for Further info).
    # TrimAudio:
    #   True(default), deletes audio belonging to deleted frames
    #   False, returns original audio, probably out of sync.
    # FadeMS: (default 1.0 millisec). Linear Audio Fade duration at splices when TrimAudio==true, 0 = dont fade (might result in audio 'clicks/cracks').
    c
    TrimAudio=Default(TrimAudio,True)   # default true trims audio, false returns original audio (audiodubbed, as Framesel returns no audio)
    FadeMS=Float(Default(FadeMS,1.0))   # 1 millisecond linear fadeout/fadein at splices
    PruneCmd = (TrimAudio) ? "~Prune_"+RT_LocalTimeString+".txt" : ""
    (!TrimAudio)
        \ ? FrameSel(scmd=SCmd,cmd=Cmd,reject=true)
        \ : FrameSel_CmdReWrite(PruneCmd,scmd=SCmd,cmd=Cmd,reject=true,Prune=True,range=true)
    (TrimAudio) ? Prune(Cmd=PruneCmd,FadeIn=True,FadeSplice=True,FadeOut=True,Fade=FadeMS) : NOP
    # If TrimAudio==true then delete Prune temp file, Else restore original Audio to the now audio-less clip
    (TrimAudio)
        \ ? RT_FileDelete(PruneCmd)
        \ : (c.HasAudio) ? AudioDub(c) : NOP
    Return Last
Function SelectRanges(clip c,String "SCmd",String "Cmd",Bool "TrimAudio",Float "FadeMS",Bool "Ordered") {
    # SelectRanges() by StainlessS. Required:- FrameSel, Prune, RT_Stats
    # Wrapper to Select frames/ranges along with audio, can supply frames/ranges in SCmd string And/Or Cmd file.
    # Cmd:  Frames/Ranges specified in file (one frame/range per line, comments allowed, see FrameSel for Further info).
    #  *** NOTE ***, If both Cmd and SCmd supplied AND Ordered == False, then will process Cmd file and then SCmd string afterwards, ie
    #    Will select ranges in Cmd file and in order specified (rather than auto ordering ranges) and then append ranges specified in
    #    SCmd string (and in order specified).
    # TrimAudio:
    #   True(default), selects audio belonging to selected frames/ranges
    #   False, returns original audio, probably out of sync (maybe totally out of whack if Ordered == false and selected ranges out of order).
    # Ordered:
    #   True(default), all frames/ranges are returned in sequencial order. Any frame specified more than once will return only 1 instance.
    #   False, All frames/Ranges are returned in specified order, Cmd processed first and then SCmd. Frames/ranges specified more than once
    #     will return multiple instances. Allows out-of-order trimming of clip, eg re-sequencing of scenes in movie.
    # Does not make much sense to select individual frames with audio, best used with ranges.
    # Will coalesce individually selected adjacent frames/ranges before any Fade, ie only audio fade where sensible to do so.
    # TrimAudio==false with non Ordered selection will result in completely out of sync audio.
    c
    Ordered=Default(Ordered,True)       # True (default) frames/ranges will be Ordered and selected only once even if specified more than once.
                                        # False, frames/ranges returned in specified order, Cmd processed 1st and then SCmd.
    (!TrimAudio)
        \ ? FrameSel(scmd=SCmd,cmd=Cmd,Ordered=Ordered)
        \ : FrameSel_CmdReWrite(PruneCmd,scmd=SCmd,cmd=Cmd,Ordered=Ordered,Prune=True,range=true)
    (TrimAudio)
    Return Last
EDIT: Before anyone points it out, I know I've mis-spelt Butlins wrong in 1st script, just a test to see how observant you all are.
StainlessS is online now   Reply With Quote
Old 30th March 2015, 12:56   #23  |  Link
Here frame from supplied avs demo showing audio FadeSplice at 25.0 millisecs (default 1.0 ) duration, using DavidHorman Waveform plug,
3 video frames duration of audio displayed:
FadeSplice avoids 'clicks' and 'cracks' in audio due to splice where significant change in audio phase/amplitude across
the spliced frames. Showing three Tone waveforms Sawtooth, Square and Sine.
FadeSplice implemented due to this thread:- http://forum.doom9.org/showthread.php?t=162907
EDIT: And here script that produced above
# For testing Prune() Fade
# This script can crash in Avisynth v2.58 due to a bug in the audio Cache.
# It is more likely to happen if AudioGraph is used, so this is disabled for v2.58
# Multiple Scriptclip's can produce a RealTime Video Lag behind Audio if the machine is not powerfull enough
# to cope with it, If so, then try with a lower FPS clip. Output to saved file should be fine.
FPS     = 10.0                              # Lower if Video Lags behind Audio
CHANS   = 1
HZ      = 48000
BIT16   = false
SHOW    = true          # true = Show Info
VER     = true          # true = Show Version
NOERR   = true          # true = ignore, Ignorable Errors
DV      = 2             # DebugView, 0=Off, 1=Show Errors, 2=Errors+Warnings,3=Info+Errors+Warnings,4 = Debug ie all
FADE    = 25.0          # Default 1 (1 millisecond)
FADEIN  = true          # default False, Fade in 1st frame (if FADE non zero).
FADESPLICE = true       # default False, Fade out/in splices (if FADE non zero).
FADEOUT = true          # default False, Fade out last frame (if FADE non zero).
R0=ColorBars(512,384).AssumeFPS(FPS)
R3=R0.FlipHorizontal().FlipVertical().AudioDub(Tone(3600.0,77.6,HZ,CHANS,"Square",level=0.55)).Trim(0,9999)
R2=R0.FlipVertical().AudioDub(Tone(3600.0,63.5,HZ,CHANS,"Sawtooth",level=0.65)).Trim(0,9999)
R1=R0.FlipHorizontal().AudioDub(Tone(3600.0,59.2,HZ,CHANS,"Triangle",level=0.75)).Trim(0,9999)
R0=R0.AudioDub(Tone(3600.0,53.7,HZ,CHANS,"sine",level=0.95)).Trim(0,9999)
R0=(BIT16) ?R0.ConvertAudioTo16bit(): R0
R1=(BIT16) ?R1.ConvertAudioTo16bit(): R1
R2=(BIT16) ?R2.ConvertAudioTo16bit(): R2
R3=(BIT16) ?R3.ConvertAudioTo16bit(): R3
R0=R0.ScriptClip("""subtitle(Align=5,size=48,"R0("+string(current_frame)+")")""")
R1=R1.ScriptClip("""subtitle(Align=5,size=48,"R1("+string(current_frame)+")")""")
R2=R2.ScriptClip("""subtitle(Align=5,size=48,"R2("+string(current_frame)+")")""")
R3=R3.ScriptClip("""subtitle(Align=5,size=48,"R3("+string(current_frame)+")")""")
cmd="Prune_Fade_Test_Cmd.txt"
SCmd="
    R0 1
    R1 2
    R2 3
    R3 4
    R0 5,6
    R1 7,10
    R2 12,17
    R3 2
#cmd=""                 # Uncomment to switch Off Command file
#scmd=""                # Uncomment to switch Off Command String
Prune(R0,R1,R2,R3,CMD=Cmd,SCmd=SCmd,show=SHOW,ver=VER,Noerr=NOERR,dv=DV,fade=FADE,FadeIn=FADEIN,FadeSplice=FADESPLICE,FadeOut=FADEOUT)
# Not very interesting without the below Audio Graph in v2.58.
#(VersionNumber<> 2.58)?AudioGraph(1):Last       # AudioGraph more likely exposes Avisnynth v2.58 Audio Cache Bug
(VersionNumber<> 2.58)?waveform(1):Last            # waveform more likely exposes Avisnynth v2.58 Audio Cache Bug
Contents of additional file, Prune_Fade_Test_Cmd.txt
R0 77,-1
R1 34,-2
R2 150,-3
R3 66,-4
Old 1st April 2015, 19:16   #24  |  Link
Prune v1.12, see 1st post.
Minor mod, Display NickNames in original casing when Show=true (was all uppercased).
Old 21st December 2018, 00:24   #25  |  Link
Prune v1.13, see first post.
Moved to VS2008, added version resource, and x64.
Old 22nd December 2018, 00:36   #26  |  Link
gispos
Very nice that you reworked your plugins and you now also offer in 64bit.
Thank you.
Live and let live
gispos is offline   Reply With Quote
Old 27th July 2021, 21:41   #27  |  Link
Prune v1.14, see 1st post.
[Available only on MediaFire in sig below this post, having problems getting into my SendSpace account].
	01/Apr/2015 - ver 1.12 - Display Nicknames in original casing when Show.
	20/Dec/2018 - ver 1.13 - Moved to VS2008, Add x64.
	27/Jul/2021 - ver 1.14 - Add HBD text render [Show/Ver] using DDigit v2.0.
Would previously work just fine with HBD clips, except where Show = true OR Ver = True, ie printing metrics text on frame.
Old 28th July 2021, 12:41   #28  |  Link
Just a heads up,
the 3 recently updated plugs, FrameSel, Prune, and ClipClop,
all show an older version and date in forum [Avisynth Usage] lists,
when thread is older than some age, thread titles cannot be updated, however shows
correct version and date on the first thread post.
Forum VBulletin software problem.
editing, range, splice, trim
