Old 31st January 2009, 22:10   #1  |  Link
ckopn
x264vfw settings for encode tennis matches
Hello all. What settings do You recommend for encode tennis matches for best quality/compression. Tennis video most time show all court.
ckopn is offline   Reply With Quote
Old 31st January 2009, 22:25   #2  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Old 1st February 2009, 02:01   #3  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Okay since nobody dares to say it, i will.... okay here goes:
I am the best.
bob0r is offline   Reply With Quote
Old 1st February 2009, 02:03   #4  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
I am the best.
The best? Well, perhaps you used to be...
Old 1st February 2009, 12:07   #5  |  Link
ckopn
Originally Posted by Sharktooth View Post
Please, give me the link.
I don't understand what's a problem?
Old 1st February 2009, 12:26   #6  |  Link
J_Darnley
J_Darnley's Avatar
Rule #12 - There is no best
Rule #1 - Read before asking
Rule #1a - Use search
The settings you must use are defined by your playback set up and the others are defined by your preference on speed versus quality.
I use the following on live-action: --crf 22 --bframes 4 --b-adapt 2 --b-pyramid --ref 6 --deblock -1,-1 --partitions all --direct auto --weightb --me umh --subme 9 --psy-rd 1:0.125 --mixed-refs --8x8dct --trellis 2
For other options, use search. The megui presets thread would be a good place to find plenty of pre-made ones that cover everything in terms of content, playback requirements, quality and speed.
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 2nd February 2009, 01:11   #7  |  Link
Jay Bee
For 576i sports I use the DXVA-HD-HQ preset of MeGui with interlaced on and psy-trellis 1.0, at 2000 to 2500 kbps.
Jay Bee is offline   Reply With Quote
settings, tennis, x264vfw
