Old 4th August 2008, 12:13   #1  |  Link
CTYves
mx rider
convert any video format to flv successfully
I'm pretty novice when it comes to mencoder and ffmpeg command lines, so I need some help or suggestions. At the moment my video sharing site is using the command line below to convert many video formats (3gp, 3gpp, mpg, mpeg, mpeg4, mp4, avi, wmv, flv, mov, asf, qt, dat) to flv files. So far I noticed it converts to flv file successfully when the input video is flv, 3pg, mov or mp4. Other formats are not tested yet. What I do know for certain is that wmv files are never successfully converted. The audio is converted propperly, but the video frames aren't. It's like there are 20 frames in total and you see them one after the other in a timespan of 20 seconds.
The bottom line is the code below isn't good enough to convert any video format to an flv successfully. What command line you think would?
I'm also open to use ffmpeg instead of mencoder. I just don't know what command line would be the optimal one to use. All help and suggestions are greatly appreciated.
/usr/local/bin/mencoder video.wmv -o video.flv -of lavf -oac mp3lame -lameopts abr:br=56 -ovc lavc -lavcopts vcodec=flv:vbitrate=800:mbd=2:mv0:trell:v4mv:cbp:last_pred=3 -vf scale=320:240 -srate 22050
Upload your mororized sports video to www.carbtube.com and earn a little money on the side from them.
CTYves is offline   Reply With Quote
Old 4th August 2008, 17:24   #2  |  Link
Red9
Why aren't you using Adobe Flash Encoder? It's very simple and knows a lot of video formats...
Red9 is offline   Reply With Quote
Old 4th August 2008, 17:34   #3  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
You'd probably be better off using H.264, given how much better quality you'll get. FLV1/Sorenson Spark H.263 is a really old and crappy format.
Old 5th August 2008, 09:55   #4  |  Link
CTYves
mx rider
First time I hear about it. Can it run on a linux server? Where can I get more info about it?
What should I do then? I have the latest mencoder and ffmpeg installed. How can I make my script work on H.263?
You see I'm a bit novice to it all. But I'm surely prepared to read up where I have to to get it done.
Old 5th August 2008, 10:21   #5  |  Link
dat720
As far as i can see there is no Adobe Flash Encoder available for linux, i would stick with mencoder and tweak what you have.
Try adding harddup in the filters section....
-vf harddup,scale=320:240
Sometimes wmv files have strange framerate's, i have seen wmv's with 100fps rates, that could explain why mencoder is having a spat!
dat720 is offline   Reply With Quote
Old 5th August 2008, 10:59   #6  |  Link
CTYves
mx rider
I remember trying -vf scale=320:240,harddup but that didn't do it. You suggestions -vf harddup,scale=320:240 did. Great! You recon all video formats will now convert successfully because of the hardup parameter?
Also, I am intriged by what Dark Shikari said. "You'd probably be better off using H.264, given how much better quality you'll get."
How can I take advantage of that?
EDIT: It didn't do it perfectly. It seems the audio is faster or the video is slower (too many frames). Either one of these.
Old 5th August 2008, 21:42   #7  |  Link
dat720
About the only other thing you could do is force a frame rate.
-ofps 23.976
Look at your failed videos and see what frame rate they are, this should give some idea as to what is going on....
PS mencoder did it's job perfectly, but the results are not what you want!
Old 5th August 2008, 21:51   #8  |  Link
Dark Shikari
x264 developer
H.264-in-flash example (280kbps video, 32kbps audio). Another one (1.5 megabit video, 128kbps audio)
For help encoding with x264 through ffmpeg, check out this page and this page.
Old 6th August 2008, 00:24   #9  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Dude.
That game makes my brain short-circuit. I've seen your Touhou samples before, but that's seriously, seriously impressive. 60p, and at 1.5mbps the only problem is a slight blurring / noise in the background. The massive numbers of bullets are perfectly preserved with no blocking anywhere.
~MiSfit
Old 7th August 2008, 14:22   #10  |  Link
CTYves
mx rider
As much as I would like to use H.264, I don't know how. The pages you showed are a bit complicated to me. And the videos you showed are, well..., impressive!
Can you help me get a command line that would be perfect in your eyes? I can uses mencoder or ffmpeg. Both are installed. Or can you setup a commandline that uses H.264 for me?
Old 7th August 2008, 14:53   #11  |  Link
Dark Shikari
x264 developer
If you're on Windows, you can just use MeGUI and output to an mp4 file. If you're on Linux, this page might be useful, though as a general note using ffmpeg to encode H.264 is a bit of a nightmare, and further more you need to remux with mp4box or use qt-faststart after encoding to make the video ready for Flash (you can also mux to FLV instead to avoid this issue).
Old 7th August 2008, 16:26   #12  |  Link
CTYves
mx rider
Again, that's really chinese to me. I appreciate you helping me though.
What I would like if for someone to fill in parameters at the end of this commandline...
... so that when I use that command line on (almost) any video format it outputs a propper flv. Preferably medium to high quality.
Some parameters in the commandline in post 1 must be cuasing some issues with some video formats (like wmv) and I don't know which.
Old 9th August 2008, 11:43   #13  |  Link
CTYves
mx rider
anybody?
Old 9th August 2008, 12:18   #14  |  Link
dat720
Have Patience fella!!!
Not everyone sits here watching the forums 24/7.....
Here is the contents of my youtube.bat:
@echo off
"D:\VidTools\AutoMen\mencoder.exe" %1 -o "%~dpn1.youtube.flv" -of lavf -ovc lavc -oac lavc -lavcopts vcodec=flv:vbitrate=448:autoaspect:mbd=2:mv0:trell:v4mv:cbp:last_pred=3:predia=2:dia=2:precmp=2:cmp=2:subcmp=2:preme=2:turbo:acodec=libmp3lame:abitrate=56 -vf scale=320:240 -srate 22050 -af lavcresample=22050 -sws 9
This spits video out at roughly 3.6mb per minute.
Here is the Transformers trailer i did but it seems youtube totally raped the video, it looks much better from the original flv....
Old 9th August 2008, 12:34   #15  |  Link
CTYves
mx rider
The same thing happens when trying to convert a wmv file. I'm testing to convert a 2 minute wmv file. When converted to flv and I play it, the video flashes by rapidly and ends after 5 seconds. The audio plays propperly for 2 minutes, but on a black background.
Old 9th August 2008, 12:53   #16  |  Link
dat720
can you host the file somewhere so i could download it and have a look
last time i had a strange video like that i used avisynth and forced the framerate......
Old 9th August 2008, 13:24   #17  |  Link
CTYves
mx rider
82.wmv
Thanks, dat720
Old 9th August 2008, 13:51   #18  |  Link
dat720
Use the same command i posted ealier but put -fps 30 on the end.....
Old 9th August 2008, 13:59   #19  |  Link
CTYves
mx rider
Ok. That worked. This is the results here... The sound is a bit stuttery though. But it is better then before. Defenatly. I guess it will do. What do you think?
Old 9th August 2008, 14:03   #20  |  Link
dat720
that could be because 30fps is not the actual frame rate of the video, media info told me 30fps so i just ran with that, and to be honest when i tested it i didn't have the volume loud enough to notice that, it's 11pm here and everyone else is in bed.
Hmm nope i was wrong, the problem is with libmp3lame, it seems to be killing the audio.
Wrong again.... i have absolutely no idea why the audio is doing that....
conversion, convert, flv, mencoder
