Old 15th March 2010, 01:27   #1  |  Link
Foofaraw
Boosting speech in ac3
I have an ac3 I'd like to convert to a stereo (mp3) - it seems the spoken dialog is being almost drowned out by other sounds.
I'm wondering how to do this - ac3 is 5 channels right?
Is there a primary spoken dialog channel one could boost or lower the others?
Foofaraw is offline   Reply With Quote
Old 15th March 2010, 06:55   #2  |  Link
kypec
User of free A/V tools
kypec's Avatar
AC3 can be also 2.0 = stereo only in which case boosting the dialogs is not that easy
kypec is offline   Reply With Quote
Old 15th March 2010, 11:50   #3  |  Link
Limit
AC3 supports different speaker settings. It is hard to boost speech if your source is stereo, but it is usually not needed either. For downmixing (5.1 to 2.0) you should try to increase the volume of the center channel.
Limit is offline   Reply With Quote
Old 15th March 2010, 16:11   #4  |  Link
Foofaraw
Well source is 5, but I'll try boosting the center one and see what happens. Thanks
Old 15th March 2010, 16:21   #5  |  Link
laserfan
Aging Video Hobbyist
Depending on your source and what you are trying to accomplish, you might find that simply using eac3to to convert to WAVs, and then converting the center channel alone to an AC3 1.0 might give you the results you want.
laserfan is offline   Reply With Quote
Old 16th March 2010, 17:24   #6  |  Link
Foofaraw
Well as i said i was trying to convert it to an mp3 - i'll see if i can figure out eac3to
ac3, hard to hear speech
