Old 16th June 2011, 04:11   #1  |  Link
GG-Xtreme
MeGui 1st-pass stats file?
I need to create a .stats file from an input video in order to get keyframes for using in another program. However, when I specify "2pass - 1st pass" and the output log filename in the Xvid window and run the analysis pass, no files are created. I also have "Delete intermediate files" unchecked in the settings. The MeGui log shows no errors. What am I missing?
I'm using the latest development server build of MeGUI and Windows 7 64-bit.
GG-Xtreme is offline   Reply With Quote
Old 17th June 2011, 02:05   #2  |  Link
GG-Xtreme
bumptenchars
Old 18th June 2011, 03:37   #3  |  Link
GG-Xtreme
Really? No one at all?
Old 19th June 2011, 11:36   #4  |  Link
GG-Xtreme
Last try...
Any suggestions of where I can get help with this if not here?
Old 20th June 2011, 00:08   #5  |  Link
AMED
AMED's Avatar
You should be able to copy and paste the first pass commandline from the MeGUI log and manually run it in a CMD window.
Post a copy of your log please and i'll try to help.
A Man Eating Duck
AMED is offline   Reply With Quote
Old 20th June 2011, 01:16   #6  |  Link
GG-Xtreme
Thanks a lot for the response.
http://pastebin.com/eJBk2zyj (The text you have entered is too long (209328 characters).)
At no point during the process running did there appear any .stats or .pass file in the encoder program folder or the specified output folder. Searching the entire computer for such a file after the process was run yielded no results.
Old 20th June 2011, 01:29   #7  |  Link
AMED
AMED's Avatar
Can you edit the below to fix the paths to the avs and the location where you want to save the stats and the log at the end and copy and paste it into run or an open CMD window.
"C:\Program Files (x86)\MeGUI\tools\xvid_encraw>xvid_encraw" -i "C:\path\to\folder\test.mkv.avs" -pass1 "C:\path\to\folder\video.pass" -bitrate 700 -kboost 100 -nopacked -lumimasking >> "C:\path\to\folder\log.log"
I'm at work at the moment so i can't test it.
A Man Eating Duck
Old 20th June 2011, 03:17   #8  |  Link
GG-Xtreme
I can't put quotes before the command line. The line I'm using is
xvid_encraw -i "C:\path\to\folder\test.mkv.avs" -pass1 "C:\path\to\folder\video.pass" -bitrate 700 -kboost 100 -nopacked -lumimasking >> "C:\path\to\folder\log.log"
from already inside the "C:\Program Files (x86)\MeGUI\tools\xvid_encraw" directory.
Old 20th June 2011, 07:20   #9  |  Link
AMED
AMED's Avatar
i have just tested something similar
"C:\Program Files (x86)\MeGUI\tools\xvid_encraw\xvid_encraw.exe" -i "D:\Bluray Backup\Movies\VTS_01_1.avs" -pass1 "D:\Bluray Backup\Movies\VTS_01_1.stats" -bitrate 2319
and the stats file is in D:\Bluray Backup\Movies\
A Man Eating Duck
Old 20th June 2011, 09:38   #10  |  Link
GG-Xtreme
I ran the same exact command, both with and without the bitrate argument (except specifying folders that exist on my end and my own avs file). Still no files being created at all =/
Old 20th June 2011, 21:05   #11  |  Link
AMED
AMED's Avatar
Can you post the exact commandline you are trying to run pls.
A Man Eating Duck
Old 20th June 2011, 22:00   #12  |  Link
GG-Xtreme
"C:\Program Files (x86)\MeGUI\tools\xvid_encraw\xvid_encraw.exe" -i "C:\testfolder\testraw.avs" -pass1 "C:\testfolder\testraw.stats"
The contents of my avs file:
LoadPlugin("C:\Program Files (x86)\Haali\MatroskaSplitter\avss.dll")
LoadPlugin("C:\Program Files (x86)\MeGUI\tools\ffms\ffms2.dll")
FFVideoSource("C:\testfolder\testraw.mkv").AssumeFPS(24000,1001)
#deinterlace
#crop
#resize
#denoise
The command runs successfully with no errors, the command window if filled with frame info (like in the log I posted) but testraw.stats never appears.
Old 20th June 2011, 22:11   #13  |  Link
AMED
AMED's Avatar
hmm, well I'm starting to run out of ideas.
Do you have another partition or drive you can output the stats file to?
A Man Eating Duck
Old 21st June 2011, 01:22   #14  |  Link
GG-Xtreme
Yea, but I highly doubt that's the issue. I'll give it a try anyway when I get the chance. Maybe I'll just give up on this soon.
Old 21st June 2011, 02:22   #15  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
Maybe if you disable option "delete intermediate files", will can copy stats file.
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 21st June 2011, 04:29   #16  |  Link
GG-Xtreme
Thanks for the response. I already have that disabled. That shouldn't affect anything when invoking the Xvid encoder from the commandline, since it bypasses MeGUI anyway.
.stats, analysis pass, keyframes, megui, xvid
