Old 20th July 2018, 18:05   #51781  |  Link
brazen1
Originally Posted by mclingo View Post
I guess the easiest way to test the hypothesis that this is a screen issue is to setup madvr to play with same res / resfresh as your desktop so it doesnt have to change anything.
Except it introduces lag with everything assuming you set them to 23/24Hz and destroys any Windows desktop usage. Also, what happens if you set to 24Hz and your video refresh rate is 25, 30, 60Hz which often is? Strangely enough, I just set GPU to 24Hz and started 24fps video. Still flashes to black for a few secs and starts MPC player paused. Pressing play starts audio but video is frozen on frame. There is more than meets the eye (pardon the pun) going on.
W10 1909 9604GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit
KODI MPC-HC/BE PDVD19 DVDFab 3 & 5 PotPlayer
65JS8500 UHD HDR 3D
Old 20th July 2018, 18:16   #51782  |  Link
mkohman
Hi Guys.. I have a question that I hope you can help me understand better... I'm moving from 16:9 to a 2.39:1 screen and was wondering what madVR masking does and how it's used? Would appreciate if this could please be explained.. Many thanks
Sent from my moto g(6) using Tapatalk
mkohman is offline   Reply With Quote
Old 20th July 2018, 18:46   #51783  |  Link
changing refreshrats take time that's a fact.
and you can easily test this.
mpc-hc default settigns with madVr as renderer.
reset madVR to defaults.
play a file in window mode.
@mkohman you have to be a lot more price about hat.
I really don't mind the black screen either. I've become used to it yet I cringe every time it happens and noticed it really bothers others. As for the 'delay' setting in MPC, it's greyed out when you don't use the player to do the rate switching and are using madVR to control it instead. Also, I think 'delay' is going to delay the rate change itself which sort of exasperates the problem unless I'm mistaken which I often am.
try it out. never used it myself.
and if i'm not mistaken madshi wants to add soemthign like that too.
who knows whats on this todo list.
you need to disable the madVr dispaly changer for that and it may not work with HDR not sure.
Old 20th July 2018, 20:17   #51784  |  Link
mclingo
yes but the delay is less than a second without MADVR though, this is the point we're discussing.
Old 20th July 2018, 23:22   #51785  |  Link
Asmodian
This simply sets some of the screen area to black. It is intended for projectors which can have some image area overhang the screen.
This is the first example image I found, the blue line on the wall could be eliminated by setting up madVR's masking.
I don't think it is useful for an ideal screen of any aspect ratio.
madVR options explained
Asmodian is online now   Reply With Quote
Old 20th July 2018, 23:28   #51786  |  Link
mkohman
Right.. So its basically for any spillage to the left or right of the screen? I thought it was to do with the black bars on a scope movie..?
Old 20th July 2018, 23:31   #51787  |  Link
Asmodian
It could be the top or bottom too. Zoom Control, with its black bar detection, is for black bars. Masking is for this issue.
Old 20th July 2018, 23:42   #51788  |  Link
mkohman
Ah.. I see. Can you please elaborate on the zoom control feature? I will be using my JVC to zoom in to fill the scope screen and the Black bars will be shooting above and below the screen.. What will the zoom control in madVR do for me? Sorry for the questions and thank you for your help..
Old 21st July 2018, 05:40   #51789  |  Link
SamuriHL
SamuriHL's Avatar
Well that was definitely fun! I clean installed the latest nVidia driver and set up madvr for 4K HDR. WOW! What an absolutely amazing experience that is on the LG C8 OLED! madvr just impresses me more and more. Of course because I've run into some subtitle issues with the later builds of madvr I'm still using a slightly older build so I can't wait for the next build to get all the latest fixes and options. But I'm VERY glad I jumped to 4K. Thank you, madshi, awesome work as always!
HTPC: Windows 10, I9 9900k, RTX 2070 Founder's Edition, Pioneer Elite VSX-LX303, LG C8 65" OLED
Old 21st July 2018, 06:12   #51790  |  Link
Asmodian
It simply crops/zooms the black bars away before the rest of the rending path. When cropping it even improves performance and you can have madVR output to an anamorphic lens at full resolution.
Old 21st July 2018, 06:34   #51791  |  Link
mkohman
Thanks for the reply.. I will be using my projectors zoom and lens memory function to fill out the 2.39:1 screen not an anamorphic lens. Will this feature still be usable for me or not necessary? Thanks
Old 21st July 2018, 16:52   #51792  |  Link
Warner306
You might get a better result if you let madVR handle the zoom. Easy enough to do and worth trying.
Old 21st July 2018, 20:13   #51793  |  Link
Asmodian
I agree, zooming with the lens means the pixels must get bigger on the screen. Better to let madVR do it and keep your PPI up.
Old 21st July 2018, 21:42   #51794  |  Link
Siso
Siso's Avatar
Does anyone know what is causing 1 presentation glitch only? I changed one sharpener in the upscaling refinement options, went from adaptive sharpen to crispen edges, and I got 1 presentation glitch...I didn't have any with adaptive sharpen.
Old 21st July 2018, 21:55   #51795  |  Link
Asmodian
What do you mean by "got 1 presentation glitch?" Do you mean once per playback?
Old 21st July 2018, 22:00   #51796  |  Link
Siso
Siso's Avatar
One presentation glitch during playback of a movie.
Old 21st July 2018, 22:34   #51797  |  Link
Asmodian
And you reset the OSD after playback starts? I would never worry about a single presentation glitch if it only happens during startup.
If it is happening after the first second or two, but only once per movie, it is probably performance related is some way. There are a lot of things that could cause one presentation glitch during a movie. Crispen edges is a tiny bit harder than AdaptiveSharpen (without anti-bloating).
Have your tried enabling/disabling D3D11, present a frame for every v-sync, or windowed overlay (make sure d3d11 is off when enabling overlay)? Those can give you a tiny bit of extra headroom but you cannot use the reported rendering times to judge them. You have to see how many glitches or frame drops you get when using each setting.
Old 21st July 2018, 22:49   #51798  |  Link
Siso
Siso's Avatar
The presentation glitch occurs around 10-20 min during playback, I always reset the stats when I go in fullscreen. I use D3D9, with D3D11 I get triple times higher present stats (0,08 ms in D3D9 vs 0,39 ms). I'm on windows 7 64 bit.
Old 21st July 2018, 23:42   #51799  |  Link
mkohman
Thanks will definitely give it a go
Old 22nd July 2018, 01:44   #51800  |  Link
Asmodian
I would not consider that difference to be at all useful when deciding between D3D9 and D3D11. They are measured in different ways by madVR, anything <1ms is the same as far as we know or care. Even if it was real, why do you care if present takes 300Ás longer if it is more stable?
If using D3D9 let you use higher settings without drops or glitches it would be a good reason to use it but looking at the reported rendering and/or present times is not.
You are sure nothing is using your GPU every 10-20 minutes? No desktop slideshow or anything?
