#1 | Link |
Simple User
Removing analog artifacts from video
Hi. Is there a software or hardware way to get rid of these artifacts?
![]() ![]() The problem doesn't seem to be with the capture card. I think the signal is already encoded that way on the laser disk. I've tried googling but can't find anything. This problem shows up the most during the intro like in the picture. I already feel like I have to recreate these segments of video from scratch. Last edited by jefix; 13th July 2022 at 10:27. |
#2 | Link |
Post on Postimage.org, attachments can take forever.
"How To Upload Pictures":- https://forum.doom9.org/showthread.php?t=183538
#3 | Link |
Big Bit Savings Now !
Convolution can be used to get rid of these echoes/ghosts/halos, lots of manual tuning involved.
https://forum.doom9.org/showthread.php?t=182604
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 13th July 2022 at 19:48. |
#4 | Link | |
Simple User
#5 | Link |
All is laid down in great detail within the script.
(I wrote it in German, and you may use a translation machine for that.) It was for a crappy VHS capture 3rd generation, so you can not copy coefficients from that occasion. Restoration sequence: Undo any faults in reverse order as they were introduced. Think about your particular case's original signal chain and you'll find out. First processing should work along CVBS temporal scan, so along x-axis from left to right and then to the next line, so I would call deghosting first. Then deinterlacing (QTGMC) and if still needed, then noise reduction and whatever you may consider helpful.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 14th July 2022 at 17:38. |
#6 | Link |
Edgesidebleed() can reduce that horizontal smearing. You just need to tweak the parameters depending on how far the streaks are extending and how intense they are. You can't get it perfect, but it will be greatly improved.
https://raw.githubusercontent.com/re...Denoising.avsi |
