Old 3rd June 2025, 21:55   #1  |  Link
Busty
Does this video have field issues?
I captured a video which plays fine in VLC, but as soon as I switch on Yadif2 deinterlacing, it stutters. This does not happen with another capture I did, the other one plays smoothly at 50 fps with those settings. I cannot make out a recording or encoding difference between the two, so I don't know what difference results in this stuttering.
I tried swapping fields and delaying fields with VirtualDub filters, but the stuttery behaviour remains.
Can this video be changed so it runs smoothly with Yadif2? Is this even caused by a video error or maybe a bug of Yadif2?
stuttery sample: https://limewire.com/d/OYyXz#K7tu3yBp3Q
smooth sample: https://limewire.com/d/gnkVw#2kCAj6IaY2
Busty is offline   Reply With Quote
Old 4th June 2025, 13:40   #2  |  Link
Busty
It seems that this is introduced while converting the capture from Apple 8bit lossless to utvideo lossless with ffmpeg.
It happens when I use "ffmpeg -i input.mov -c:v utvideo -an output.avi"
input.mov plays fine with yadif2 while output.avi does not.
Old 4th June 2025, 17:58   #3  |  Link
Busty
I found a workaround here:
https://forum.videohelp.com/threads/...n-using-ffmpeg
It says, I can trim the first field in avisynth like this:
Avisource"mysource.avi")
AssumeTFF()
SeparateFields()
Trim(1,0)
Weave()
AssumeTTF()
I changed the last line from AssumeBFF() to TFF(). Both work for me, I see no difference. It also works without the last Assume line.
If anyone sees a problem with this workaround please let me know.
Also, if anyone knows a way to encode to utvideo avi without the field problem to begin with.
Old 5th June 2025, 13:33   #4  |  Link
cubicibo
FFmpeg sometime gets the field order wrong. There are various ways to address the issue, it depends of the source idiosyncrasy.
Here's a subset:
flags:
-top 0 (BFF)/1 (TFF)/-1 (auto/none)
filters:
phase
fieldorder
setfield
Any of these shall preceed the deinterlacer in the filter chain. Tweak them and encode small samples to verify you get the desired result.
Few more things:
- You should always tip FFmpeg everything you know about your source. Automatic detection can go wrong at anytime.
- FFmpeg has better deinterlace filters over yadif. Consider estdif or bwdif.
cubicibo is offline   Reply With Quote
