Old 3rd September 2022, 06:50   #1  |  Link
Rozzy85
Difference between CE310B and C725B/C725D
Are there any major quality differences between these AVerMedia cards? I'd like to get the CE310B but it's quite expensive at over $100 on Alibaba while these other cards are a bit cheaper. The latter cards seem to be know as "EZMaker SDK Express" cards.
Rozzy85 is offline   Reply With Quote
Old 4th September 2022, 13:05   #2  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
CE310: Conexant CX23888 with 3D Y/C, can do YUV 422 10bit, but datasheet does not tell if 10bit are available as capture format.
C725: older chipset, no 3D Y/C, I guess 8bit only
