#1761 | Link |
Please note that this is on build 10051 of the Windows 10 TP, running Windows 8.1 drivers. It would be interesting to see whether those running the Windows 10 drivers (which are feature incomplete) have any better performance.
I'm not using the Windows 10 drivers as I require the feature in the CCC where you set the screen resolution and overscan etc. Without this the image has a small black border around it (only on the connected TV) which is annoying! The driver does seem to be quite 'different' in many ways. |
#1763 | Link | ||
. I'm guessing that is restricted to when SharpDX is updated, which going by the commitlog has had some major rework done in preparation for version 3.Then there's this: Quote:
#1764 | Link |
Suptitle, MediaPlayer.NET
MPDN v2.25 OpenCL Support
Hi all,
Thanks again for helping to test DX-OpenCL interop on the various GPUs. MPDN v2.25.0 has been released with OpenCL support via RenderScript. I've added an example OpenCL script on GitHub that functions as a blue tint filter. If you want to test it out, simply copy the RenderScripts folder in Examples to your MPDN Extensions folder. I'd be interested to see if it works on the GPUs you have tested DxClTest on. Cheers. |
#1765 | Link | |
MPDN now also allows you to access its render queue in RenderScripts (spatiotemporal image processing is now possible). Or in your case, you'd probably want to use it as a scratch pad for the odd frames before you stack the corresponding even frame on top of it. Last edited by Zachs; 14th April 2015 at 07:36. |
#1768 | Link |
Whoops, moving Example.*.cs into Renderscripts folder as well as Examples folder which contains the .hlsl and .cl solves the problem. Thanks. I put Example.*.cs into another Example folder under Renderscripts folder previously. All four of blue tint scripts work.
#1771 | Link |
NNEDI3 testing
Hi everyone,
Shiandow has kindly ported NNEDI3 to MPDN. It's currently in my nnedi3 branch on GitHub so if anyone wants to give it a test, feel free to do so. We need AMD card users especially to test it as we don't have an AMD card to work with and would appreciate your feedback on the following. It currently only upscales luma and uses MPDN's upscaler for chroma. 1) GPU name5) Render quality settings * Note1: If you start dropping frames, don't include the result with that neuron setting. * Note2: We would appreciate if you could test it on sources with different resolutions too. e.g. Code:
1) Intel HD P4600 2) 16: 41%/600Mhz, 32: 34%/600, 64: 47%/600Mhz, 128: 72%/800Mhz, 256: 71%/1150Mhz 3) 320x180 23p 4) 1280x720 5) Max Performance 2) 16: 42%/600Mhz, 32: 35%/600, 64: 49%/600Mhz, 128: 74%/800Mhz, 256: 73%/1150Mhz 5) Image Quality 1) Disable fluid motion9) Make sure no other apps are running - treat it like a benchmark run Links (not compatible with MPDN v2.25.3): MPDN test build v2.25.4 Last edited by Zachs; 23rd April 2015 at 02:05. |
#1772 | Link |
r9 270
640x480 -> 1440x1080 256 950/1400 49% 31ms (close to the limited) 128 950/1400 32% 22ms 64 950/1400 21% 18ms 32 can't tset on my AMD you need a dual monitor system to test this. the GPU clock is totally unstable. BTW. i still didn't get proper audio/stable playback with this player. |
#1773 | Link | |
And what do you mean you can't get proper audio/stable playback? Does audio stutter or something? |
#1775 | Link | |
Did you have the audio problem from the very first version or was it a recent release that caused this? |
#1776 | Link | |||
http://forum.doom9.org/showpost.php?...postcount=1274 the DWM problem is gone i'm not on windows 7 anymore. |
#1777 | Link | |
And what do you mean it did a real world fullscreen test? Are you saying 32 neurons and below don't work at all? |
#1778 | Link | |
i3 4130
asus essence stx Quote:
nothing for you to bother simply no 32 neuron and lower numbers that's all. your program is not the problem here. |
#1779 | Link | |
Have you tried using MPC Audio Renderer with WASAPI instead just to see if it helps? Just trying to isolate the problem. |
#1780 | Link | |
i try AC3 filter. |
| Tags |
| direct3d, mpdn, nnedi3, opencl, reclock |
| Display Modes | |
