#2561 | Link |
Is there any way to support GPU acceleration via integrated GPUs like I do with MPC and LAV? On MPC I set LAV to use QuickSync instead of CUDA, that makes my GTX 770 sleepy and silent at 135 MHz Core and uses my HD4600, which has no monitor output (I believe you guys call that "headless GPU"?), to decode everything, . Any way to do that with MPDN so the GTX770 won't go full clock and noisy every time I boot it up? The iGPU doesn't even show up on the Adapters list.
#2563 | Link |
MPDN Extensions Dev
I did think of file hashing instead of Timestamp comparison (as how the uninstaller is done for now). Until now I couldn't find a plugin/script for NSIS to generate hash. Now I found a basic CRC32 that should be enough to check for modification.
I can later on make an installer for the source version, but I think this would get a little complicate for the user (and also could lead to some conflict when the framework get changed/refactored). Anyway I'm open to any ideas ! |
#2564 | Link | |
i saw again high interrupt to process values so the asus soundcard isn't the problem. but the real issue is that the values are way way higher with MPDN. and this is on a completely reinstalled system. the next thing i will try is switch out the GPU and have a look at the results. |
#2566 | Link |
Suptitle, MediaPlayer.NET
DXVA HD Scaler
I've just pushed the DXVA HD Scaler render script to github. This is unreleased yet but I'll be making a new MPDN_Extensions release shortly.
For more info, see https://github.com/zachsaw/MPDN_Exte...DXVA-HD-Scaler Anyway, not sure why anyone would want to use it, but you're the boss! |
#2567 | Link | |
#2569 | Link |
Do you see only one adapter on your drop down list? You should see 2. On my Win7 machine, I have the iGPU setup as a headless output and I can switch between the two easily. Are you sure MPC even supports using the headless iGPU to render your video? I certainly can't find an option to allow that.
#2570 | Link | |
I have activated debanding and hopefully it would address any banding issues |
#2572 | Link | |
#2575 | Link |
Does AMD implement DXVA HD now? A few years back when I investigated that API, they didn't offer DXVA HD at all.
#2576 | Link |
Well it doesn't work on my old 4350 and I haven't bought an AMD product since so I'm not sure really.
EDIT: Anyway, the DXVA HD scaler seems to only benefit Intel GPUs. They can do Bicubic 100 no AR with a bit less power than MPDN (by exactly 0.2W on both up and downscaling on my Intel HD 3000). Even Nvidia is simply using bilinear when scaling and is identical to MPDN's hardware bilinear. Last edited by Zachs; 30th June 2015 at 07:28. |
#2577 | Link |
madVr had problems using the better DXVA scaler too.
intel should be like lanczos 3 ar (8 bit) and amd and nvidia should be better than bilinear too even through amd is bilinear in madVR for me and something better in EVR. but i'm not even sure if you try to use the same API and i don't think they are useful too. my GPU driver are software suite 15.20-150522a-184226e. the default WDDM 2.0 driver. these are not the 15.20 driver that promise a huge performance boost. the audio problem was older than preview windows 10 so not sure if a driver can be the reason. |
#2578 | Link | ||
at least he was talking about decoding not rendering. in headless mode the video is still rendered by the other GPU but EVR doesn't have an impact on them. |
#2579 | Link | |
It would make more sense if Microsoft simply allowed you to choose an adapter that isn't connected to a display to do the rendering. That's simply how Optimus works anyway. |
#2580 | Link |
the comparison was with MPC-HC and there was no word about rendering what so ever.
in the end very high settings are needed to get a 770 gtx to high power state and the intel wouldn't be able to handle it. do you really think it is a good idea to render frames on a GPU that isn't presentation them. just look at optimus system and there high present times. and 8bit UHD@60 would be about 1.4 gigabytes per sec that needs to be transferred to the presentation GPU. |
| Tags |
| direct3d, mpdn, nnedi3, opencl, reclock |
| Display Modes | |
