Thread Tools Display Modes
Old 12th November 2010, 22:22   #10141  |  Link
Nalios
Originally Posted by SpazzHH View Post
Any idea on why I would get the standard AVS error of RenderFile with all correct versions installed and be able to play the file itself with any media player I choose? This has to be something really strange. I've re-installed Haali, ffdshow and AviSynth til I'm blue. Still get the same message with Sound of Music. Only disc to give me problems.
My problem stemmed from attempting to encode Sound of Music as well. I made no version changes at all after posting as it was processing another attempt already. This time it worked successfully without any errors.
However I'm still getting a flag for the incorrect Haali version even though its the one from the link in first post. Green Zone just finshed successfully even with the error flag..
Baffled why it tells me Haali is incorrect. I guess I'll keep going as is til it quits again.
Nalios is offline   Reply With Quote
Old 13th November 2010, 00:50   #10142  |  Link
Capsbackup
Originally Posted by setarip_old View Post
@Capsbackup
Hi! The post this link goes to, as well as the several following, appear to be about menu buttons - which, as far as I know, has nothing to do with what I posted...
You did not read down far enough. Starting from post #8765 I discuss using multiAVCHD to substitute/use an external audio file, the original for the title though, and rebuild it. This only applies to BD5/9 media though!
Capsbackup is offline   Reply With Quote
Old 13th November 2010, 02:09   #10143  |  Link
jdobbs
If you have ever installed a different version of HAALI there are probably files left over that are causing BD-RB to think it is incorrect. HAALI's uninstall doesn't remove everything.
Here's what you can do:
1. Uninstall HAALI.
2. Go to "c:\program files\haali" and delete the "MatroskSplitter" folder
3. Reinstall the HAALI version from the first post.
After that INSPECT should say "Ok" for HAALI.
jdobbs.softworks@gmail.com
Old 13th November 2010, 02:13   #10144  |  Link
omegaman7
omegaman7's Avatar
I never trust uninstallers. For whatever reason, there's usually something left behind in the programs folders. And always left behind in the registry. Gotta be careful with the registry mind you
omegaman7 is offline   Reply With Quote
Old 13th November 2010, 03:46   #10145  |  Link
drackula
I found this problem.
[09:43:08] BD Rebuilder v0.36.01 (beta)
- Source: PIRATES2
- Input BD size: 39.24 GB
- Approximate total content: [03:26:27.541]
- Target BD size: 23.24 GB
- Windows Version: 6.1 [7600]
- Quality: High Quality (Default), ABR
- Audio Settings: AC3=1 DTS=0 HD=1 Kbs=448
- Resuming from previously started job.
[09:43:23] PHASE ONE, Encoding
- [09:43:23] Extracting A/V streams [VID_00001]
- Error in attempt to extract audio/subs.
- AV frame too large (49023 bytes). Increase AV buffer.
[09:54:21] - Failed to retrieve audio, aborted
How do I solve the problem. Thank You.
drackula is offline   Reply With Quote
Old 13th November 2010, 06:18   #10146  |  Link
jdobbs
- Source: PIRATES2
Is this from an original disc? Most of the time that indicates a bad rip. If you ripped it, was it with AnyDVD?
Old 13th November 2010, 09:03   #10147  |  Link
steveg32
FFDSHOW_RAW_AUDIO: Not recommended setting
Originally Posted by Video Dude View Post
Thanks very much for the prompt reply.
steveg32 is offline   Reply With Quote
Old 13th November 2010, 11:57   #10148  |  Link
buerste3
Problem with Windows 7
- WIN7 preferred AVC CODEC: Not Set correctly
- WIN7 preferred VC-1 CODEC: Not Set correctly
- WIN7 preferred MPEG2 CODEC: Not Set correctly
Please tell me what i can do.
I installed the K-Lite Codec Pack.
New system with Windows 7 and i need a little help.
buerste3 is offline   Reply With Quote
Old 13th November 2010, 14:14   #10149  |  Link
Nalios
1. Uninstall HAALI.
I'll try deleting the matroska folder and reinstalling. I know better than to assume that uninstall ever removes all the garbage from the install. I usually manually search and delete all the crap left from an auto uninstall and did not this time, rather just installed over the old folder. Geez, I wonder what my problem is? Lol.
*sigh* shortcuts always end up taking longer..
Thanks for setting me straight.
Old 13th November 2010, 14:58   #10150  |  Link
jdobbs
To avoid problems you have to follow the directions in the first post of this thread or in the README files that is included in the BD Rebuilder zip file.
The first time you run BD-RB you have to "Run as Administrator" and BD Rebuilder will update those settings in the registry.
Old 13th November 2010, 15:26   #10151  |  Link
Ch3vr0n
What jdobss said, and uninstall that codec pack. Its bound to create problems with BDRB
Ch3vr0n is offline   Reply With Quote
Old 13th November 2010, 19:54   #10152  |  Link
Acerjen
I used the same settings as the ones you posted and it seems to have completed correctly. Not sure what I can do except to recommend that you try it again.
In the meantime, I'll do some testing on the output to make sure everything is right.
I appreciate you looking into it. I will re-rip it and try again with the new version. Thanks. Later.
magpowerzip
Acerjen is offline   Reply With Quote
Old 14th November 2010, 17:00   #10153  |  Link
red23wolf
Same error with different Blu-ray rips
Good morning all, I have been having the same error with 3 different movies, Getting into the Greek, Toy Story 3 and Robin Hood. I'm just a novice so I will try to give as much detail as I can. First I use AnyDvd to rip the Blu-rays. When I use BD Rebuilder to convert to fit on a DVD (movie only) when it gets to multiplexing it aborts. Here is the log when I did Robin Hood. All 3 movies aborted at the same spot
[23:05:45] - Failed to build structure, aborted
I attached the log to show, seems it was to big to fit in a post. Any help would be much appreciated.
red23wolf is offline   Reply With Quote
Old 14th November 2010, 17:12   #10154  |  Link
jdobbs
Could be any of a lot of reasons. BD-RB goes through that exact same sequence for all M2TS files, in yours if finishes 38 successfully before hitting it. Are you sure you're not running out of disc space? Is your source corrupted?
BTW, I've done all three of those discs with no problems.
Old 14th November 2010, 17:58   #10155  |  Link
micflair
Originally Posted by micflair View Post
no its not mate! I had no problems at all untill the last build. Trying a different image now to see if its a problem in that area! Hope it is, sorta!
I tried a different image mate and it worked 100% fine the first try, must be something on that disc it does not like.. wierd!
micflair is offline   Reply With Quote
Old 14th November 2010, 21:08   #10156  |  Link
alluringreality
Is it possible to set the following x264 items? I have tried some other options that work, but these seem to be ignored:
--colorprim "bt709" --transfer "bt709" --colormatrix "bt709"
alluringreality is offline   Reply With Quote
Old 14th November 2010, 21:30   #10157  |  Link
jdobbs
I'll do a little research -- but I really think they are unnecessary since those are the ones that are and will be used in the source and the destination.
You can add them if you want with the pass one and two tweak commands (see HIDDENOPTS.TXT).
Old 14th November 2010, 21:49   #10158  |  Link
alluringreality
That's what I was trying. I was able to get other settings to work, but after trying the syntax a few different ways I couldn't get those settings. I couldn't think of what else to try, and they work fine using MeGUI.
Old 14th November 2010, 22:04   #10159  |  Link
jdobbs
You should be able to enter them like this:
TWEAK_PASS_ONE=--colorprim bt709 --transfer bt709 --colormatrix bt709
TWEAK_PASS_TWO=--colorprim bt709 --transfer bt709 --colormatrix bt709
[EDIT]
Ok, I went and looked and I've put these in the "restricted" list. But I can't remember why... I'll go through my old notes and see if I can remember why I restricted their use.
Old 14th November 2010, 23:26   #10160  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
[EDIT]
Because depend of resolution, look here http://forum.doom9.org/showthread.php?t=154533 at section 1.4. Anyway color characteristics are not mandatory for BD, and decoder in BD device will automaticlly assume characteristics based on resolution. that is specified in specs.
shon3i is offline   Reply With Quote
Thread Tools
