Thread Tools Display Modes
Old 2nd May 2014, 18:07   #20181  |  Link
omegaman7
omegaman7's Avatar
Originally Posted by CraigWally View Post
I've tried both 47.04 and 47.05
http://www.amazon.co.uk/African-Safa...ican+safari+3d
I certainly don't expect you to buy this disc - I was just interested as to what could have gone wrong here
All other 3D discs I've tried have worked flawlessly
What happened? Without a log, we're working in the dark
Only one rooster, need be in the hen house...
omegaman7 is offline   Reply With Quote
Old 2nd May 2014, 20:11   #20182  |  Link
jdobbs
He posted a log a couple of pages back.
jdobbs.softworks@gmail.com
Old 2nd May 2014, 20:13   #20183  |  Link
jdobbs
BD-RB recognizes 3D streams by finding extensions that are required for it to exist. That's why I'm scratching my head on this. I'll have to order that disc somehow to find the problem. Unfortunately there isn't a version native to the U.S. -- all I can find is an Italian import.
Old 2nd May 2014, 20:31   #20184  |  Link
omegaman7
omegaman7's Avatar
I wondered about that
But I figured it was possible, you might not remember every post. We are human after all
Old 2nd May 2014, 22:56   #20185  |  Link
jdobbs
Sometimes I seem to be a little more human than I like...
Old 2nd May 2014, 23:35   #20186  |  Link
gonca
You can never be too human
gonca is offline   Reply With Quote
Old 3rd May 2014, 00:03   #20187  |  Link
jdobbs
Found it. That M2TS (00021.M2TS) was referenced in more than one MPLS. The first MPLS was using it as a 2D source and the second as 3D. My code wasn't accounting for that possibility. That's definitely a bug. I've fixed it for the next release. In fact I may create an interim release just to fix that one.
Old 3rd May 2014, 01:43   #20188  |  Link
raul124
raul124's Avatar
intel quick sync
just give a positive to this amazing pcs of Art (BD-rebuilder)
I just completed warZ 3D in under 1 hour, man this intel i7 quick sync HD is fast, im burning it to re-re disc right now and will post results on how it looks. it's amazing 72 fps!!
raul124 is offline   Reply With Quote
Old 3rd May 2014, 01:47   #20189  |  Link
jdobbs
Great news. Thanks.
Old 3rd May 2014, 05:23   #20190  |  Link
AmigaFuture
AmigaFuture's Avatar
We're actually Eternal Energy beings in Human and other forms...but anyway..
I don't have an Intel Quick-Sync which is why my main computer speeds were slower, but from the looks of the posters (not meaning Hosers.. (A Bob a Doug Canadian joke..hehe)) FIRM seems pretty helpful, like DGIndexNV to us nVIDIA users (was ATi).
As for "Cloud Atlas"...until someone else notices challenges with the Subtitles..I don't want to be perceived as annoying...so I'm letting it go (since there is a workaround). If that changes, I'll become annoying. HAHA! In a hopefully friendly way.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!!
AmigaFuture is offline   Reply With Quote
Old 3rd May 2014, 09:58   #20191  |  Link
CraigWally
Good news that you've found (and fixed) the issue
Thanks
Wally
CraigWally is offline   Reply With Quote
Old 3rd May 2014, 15:09   #20192  |  Link
jdobbs
BD Rebuilder v0.47.06 (beta)
I have updated the first post of this thread with a link to the latest version of BD-RB (v0.47.06). Changes for this release:
- Corrected an error in which an M2TS that is
  referenced in a 2D MPLS before a 3D MPLS could
  cause the source to be treated as 2D only.
- Added a new DEINTERLACER_TYPE (see HIDDENOPTS).
  Selecting 5 combines SmoothDeinterlacer and
  Decomb(blend=true).  This can work well on some
  difficult sources.
- Removed the encoder choice menu item.  FRIM as
  an encoder choice for 2D causes too many issues.
  For those who would like to test it further, you
  can reenable it by adding ENCODER_MENU=1 to the
  config/ini file.
- Updated the included version of X264.EXE to the
  latest release (r2431).
- Updated the included version of X264-64.EXE to
  the latest release (r2431).
- Other minor corrections and cosmetic fixes.
Old 3rd May 2014, 15:30   #20193  |  Link
inge70
Thanks
inge70 is offline   Reply With Quote
Old 3rd May 2014, 16:04   #20194  |  Link
Rileyrott
Subtitle problem with Delivery Man
Long time user of BDRB, thanks jdobbs!
A recent problem cropped up with subtitles and the movie Delivery Man. I ripped with AnyDVD HD to ISO, then mounted ISO and used BDRD to downsize to Movie Only BD5. There were 2 m2ts files-- 00006 & 00008, with 00006 being the intro to the movie plus a few minutes of the movie, 00008 being the remainder of the movie. Output to the BD5 was a single 00000.m2ts.
Upon playback of the BD5, the subtitles would work fine at first, then disappear after a few minutes. I discovered this would happen at the exact spot the movie switched from 00006.m2ts to 00008.m2ts (I used a WDTV Live SMP to watch each m2ts file from the original disc-saved as BDMV & Certificate).
Thinking this was a problem with downsizing to BD5, I also used BDRB to make a Movie-Only BD25 and Movie Only BD50 (see log and ini file). The results were the same....no subtitles after the first few minutes at the same spot (where Vince Vaughan first drives the delivery truck).
So, I took the original BDMV & Certs from the BD rip and remuxed the 00006.m2ts and 00008.m2ts in a separate tsMuxeR (v2.6.12), saved as an ISO, then used BDRB to make a BD5....no more subtitle problem.
This is the first time I've had this problem and was wondering if this was an isolated issue, or not.
[Status]
LABEL=DELIVERY_MAN
VERSION=v0.47.05 (beta)
SOURCE_SIZE=29352351744
SOURCE_VIDEO_SIZE=29352351744
TARGET_SIZE=49666850816
REDUCTION=1.69209102048024
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=2
REBUILD_COMPLETE=1
[00006]
USE_ORIGINAL=1
AUDIO=1100
PGS=10000
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=1998982726
NSIZE=0
FLINK=-1
MLINK=0
[00008]
USE_ORIGINAL=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=47667868090
AUDIO=1000
NSIZE=0
FLINK=0
MLINK=0
[04/28/14] BD Rebuilder v0.47.05 (beta)
[23:27:31] Source: DELIVERY_MAN_00100
- Input BD size: 27.34 GB
- Approximate total content: [01:44:47.322]
- Target BD size: 46.26 GB
- Windows Version: 6.1 [7601]
- MOVIE-ONLY mode enabled
- Auto Quality: Good (Very Fast), ABR
- Decoding/Frame serving: DirectShow
[23:27:31] PHASE ONE, Encoding
- [23:27:31] Processing: VID_00006 (1 of 2)
- [23:27:31] Extracting A/V streams [VID_00006]
- [23:32:20] Reencoding video [VID_00006]
- [23:32:20] Keeping original video (no reencode)
- [23:32:20] Processing audio tracks
- [23:32:20] Processing: VID_00008 (2 of 2)
- [23:32:20] Extracting A/V streams [VID_00008]
- [23:38:07] Reencoding video [VID_00008]
- [23:38:07] Keeping original video (no reencode)
[23:38:07]PHASE ONE complete
[23:38:07]PHASE TWO - Rebuild Started
- [23:38:07] Rebuilding BD file Structure
[23:47:36] - Encode and Rebuild complete
[23:47:36] JOB: DELIVERY_MAN finished.
[04/28/14] Checking System Settings
- BD-Rebuilder v0.47.05 (beta)
- Working Path Free Space: 1,064.06GB
- AVISYNTH Version: 2.5.8.0, Ok
- HAALI Splitter: 1.9.42.1, Ok
- FFDSHOW: 4504, Ok
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[04/28/14] Systems Settings Check complete
Any ideas?
Rileyrott is offline   Reply With Quote
Old 3rd May 2014, 16:08   #20195  |  Link
jdobbs
@Rileyrott
I'll check it out and see what I can find.
Old 3rd May 2014, 16:14   #20196  |  Link
Rileyrott
Thanks jdobbs!
Old 3rd May 2014, 17:50   #20197  |  Link
soneca
I had this problem too with that title.
The subtitles disappear and the audio loses sync from the same point.
Solved the problem similarly, re-authoring (demuxing/muxing) using tsMuxeR to be converted with the BD Rebuilder.
soneca is offline   Reply With Quote
Old 3rd May 2014, 19:12   #20198  |  Link
jdobbs
What makes that odd is that BD Rebuilder also uses TSMUXER when it demuxes and remuxes the subtitles.
Old 3rd May 2014, 20:36   #20199  |  Link
Ch3vr0n
jdobbs about
Removed the encoder choice menu item.  FRIM as an encoder choice for 2D causes too many issues.
For those who would like to test it further, you can reenable it by adding ENCODER_MENU=1 to the config/ini file.
The option is still there in the settings menu to use in 47.06 (Use FRIMSource for frame serving). Forgot to remove it in the GUI or will it when selected on a 2D source automatically use x264 or DGdecNV instead?
Ch3vr0n is offline   Reply With Quote
Old 3rd May 2014, 20:41   #20200  |  Link
raul124
raul124's Avatar
Intel Quick-Sync
sorry it took me a while to post my results, i had to burn it to three re-re writable disc i purchase from "china" cheap. the last one of the three burn all the way through but with bad pixelation on the right eye, the left eye no pixelation..maybe i'll try a different setup with BD rebuilder...will see...
Thread Tools
