#20161 | Link |
Is BD-RB about to make a good MKV for you using the workaround as I described? Thanks.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
#20162 | Link |
I usually don't keep subtitles, so it isn't a problem for me.
As far as workarounds >>> Use TsMuxer to create a new movie-only BD from the original and then run through BD_RB. It will take the two parts and make one m2ts file in the new BD. This might resolve the "discontinuity" in the PGS streams. |
#20163 | Link |
I recall you'd typed that before...you don't use Subtitles. I was wondering if you'd be willing to do the workaround. The way I described. Using Movie Only BD or AVCHD then using that Movie Only to create an MKV also produces an output that shows the movie is 5 plus hours.. Since you might have the same version I do, which JDobbs doesn't seem to...looking for confirmation.
#20165 | Link |
![]() Join Date: Oct 2001
Thanks. But it's already on its way.
jdobbs.softworks@gmail.com |
#20167 | Link | |
You say "rly fast" -- are you personally seeing faster speeds? So far the only feedback I've gotten with HW encoding is that there seems to be a higher probability of glitches in the output. In SW mode FRIM is actually slower than X264.
jdobbs.softworks@gmail.com Last edited by jdobbs; 30th April 2014 at 16:46. |
#20168 | Link | |
Same question, what would be good 3D Full Backup CONFIGURATION for me no matter how long I prefer quality. Last edited by Guest; 30th April 2014 at 22:37. Reason: rule 12: don't ask what's best |
#20169 | Link |
AmigaFuture
Tried both workarounds and it seems that as long as the PGS streams are present the time displays wrong. I don't think that there are any actual PGS streams in the second m2ts, just pointers or references because of the first m2ts, which causes some kind of discontinuity to the time codes |
#20170 | Link |
@ Gonca
Thanks for checking. There is a Subtitle end the very end of the movie for each of the 3 languages. Funny, I wonder if it was intentional? Pretty sure. Enough to cause something like this. Hmm...the workaround I described (processed without reencode 1st time, and making MKV 2nd time) should have produced a good MKV. Anyway, there are indeed PGS streams.
#20171 | Link | |
Additionally the output was undersized quite a bit at 3.63 GB - usually I get around 4.2 GB in a BD-5 encode. The bitrate chosen for the encode is a bit low for a 2h movie. This happens for me from time to time on multipart sources. If the main movie consists of a single m2ts the output size is always fine. I've attached the log of the encode. Code:
[05.01.14] BD Rebuilder v0.47.05 (beta) [12:05:14] Source: THE_COUNSELOR_00800 - Input BD size: 33,72 GB - Approximate total content: [01:57:14.026] - Target BD size: 4,36 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Resize: 1920 to 1440 enabled - Auto Quality: High Quality (Default), ABR - X264 Tweak(s) enabled - Decoding/Frame serving: FRIMSource - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [12:05:21] PHASE ONE, Encoding - [12:05:21] Processing: VID_00500 (1 of 3) - [12:05:21] Extracting A/V streams [VID_00500] - [12:12:31] Reencoding video [VID_00500] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 153.339 frames - Bitrate: 2.793 Kbs - Using FRIMEncoder for AVC encoding - [12:12:32] Reencoding: VID_00500, Pass 1 of 1 - [12:34:04] Video Encode complete - [12:34:05] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - Track 4354 (deu): Reencoding audio to AC3... - [12:38:16] Processing: VID_00501 (2 of 3) - [12:38:16] Extracting A/V streams [VID_00501] - [12:38:23] Reencoding video [VID_00501] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 889 frames - Bitrate: 2.827 Kbs - Using FRIMEncoder for AVC encoding - [12:38:23] Reencoding: VID_00501, Pass 1 of 1 - [12:38:31] Video Encode complete - [12:38:31] Processing: VID_00502 (3 of 3) - [12:38:31] Extracting A/V streams [VID_00502] - [12:39:08] Reencoding video [VID_00502] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 14.420 frames - Bitrate: 2.478 Kbs - Using FRIMEncoder for AVC encoding - [12:39:08] Reencoding: VID_00502, Pass 1 of 1 - [12:41:04] Video Encode complete [12:41:04]PHASE ONE complete [12:41:04]PHASE TWO - Rebuild Started - [12:41:04] Rebuilding AVCHD file Structure [12:42:14] - Encode and Rebuild complete [12:42:14] JOB: THE_COUNSELOR finished. Last edited by Starfiresg1; 1st May 2014 at 12:18. |
#20173 | Link |
What are you using to play it back? From the log it looks like it encoded in 3D.
#20174 | Link | |
If you fail to plan; you plan to fail, would you not agree? Think about it. |
#20175 | Link |
@HWK: flok isn't asking about 3D, he's asking about 2D and in that case all tests indicate x264 is better, faster & more stable than FRIM when it comes to final output. In fact jdobbs has stated he'll probably remove the possibility of using frim for 2D sources
#20178 | Link | |
'm Tratanto to make real 3D in my case I do not use 3D SBS, but I'm having a problem when playing my player Pioneer when starting 3D reproduction appears black screen when complete disc with menus, but when you only use film Home 3D does not happen that problem. Excuse my language |
#20179 | Link | |
Also, can you point me to the disc (on Amazon or Best Buy preferably) that you are attempting to back up?
jdobbs.softworks@gmail.com Last edited by jdobbs; 2nd May 2014 at 15:32. |
#20180 | Link |
I've tried both 47.04 and 47.05
http://www.amazon.co.uk/African-Safa...ican+safari+3d I certainly don't expect you to buy this disc - I was just interested as to what could have gone wrong here All other 3D discs I've tried have worked flawlessly |
| Thread Tools | |
| Display Modes | |
