31st August 2021, 12:08 | #142 | Link | |
Zorr,
I note that in a number of posts in spotless related thread eg here:- https://forum.doom9.org/showthread.p...87#post1944487 Code:
function RemoveSmallSpots(clip mask, int spotSize) { mask_orig = mask # remove too small spots ---------------------------------------------------- for (i = 1, spotSize) { mask = mask.mt_inpand() } mask = mt_hysteresis(mask, mask_orig, chroma="-127") return mask } Appears quite a few times in the linked thread. From Masktools 2 original docs. Quote:
chroma="128" [instead of chroma="-128"] and it now throws a wobbly, says should be setting chroma to -ve ie -128 [although original script did seem to work OK in older masktools]. EDIT: To below: Thankyou kind sir [you've gotta develop thick skin on the D9]
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 31st August 2021 at 12:49. |
17th September 2021, 14:48 | #144 | Link |
Many times I had spots around the edges of the frames and always put back in by delta restore.
Check the coding and zpadding seems to be responsible for it. Don't know why it was there but I had changed it to zeros. Spots now removed. Yippeeeee. |
6th October 2021, 20:13 | #147 | Link |
It is the overlap parameter used by the MAnalyze function of MVTools2, which is the motion estimation plugin that is at the heart of Spotless. In MVTools2 you can specify the size of the block used to "track" objects in the video. Typical sizes are 4, 8, and 16. To improve the quality of certain operations the algorithm can overlap adjacent blocks. This sometimes improves noise reduction or synthesis of intermediate frames, but you don't know until you try, as you did in fact do.
6th October 2021, 20:20 | #148 | Link |
OLap is the block [Blksz] Overlap.
Popular choices are sometimes BlkSz/2 or 2.
6th October 2021, 20:23 | #150 | Link | |
However I have to point out that it is very dangerous to try out Spotless whilst you are driving. EDIT: Especially at higher speed! EDIT: Zorr added some recovery stuff for disappearing trees, arms, legs, balls, etc, here:- https://forum.doom9.org/showthread.php?t=182831
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 6th October 2021 at 20:32. |
6th October 2021, 21:34 | #151 | Link |
Soul Architect
That ain't faster anymore. Waiting half-an-hour for the first frame of a 5K clip to come out. I give up.
Another way to restore details: run this as a prefilter to BM3D. Edit: LOL it was resizing up by a factor of 3x |
6th October 2021, 21:45 | #152 | Link |
Soul Architect
I'm comparing this to xClean. I'm very surprised by the results. Trees are back but....... look different. They actually look more like trees than in the source??? How is that possible? Image details are also a lot clearer. This is looking damn good. It's just that -- the way it completely alters moving trees is a bit risqué
Runs at 0.4fps on 5K Compared to xClean, noise is about the same, image is clearer/sharper, and moving objects are... transformed, for better or worse. Haven't tested whether it works well for all types of content. On this test clip, Spotless gives better visible result (perhaps a bit too sharp), while xClean better respects the source.
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 6th October 2021 at 21:58. |
6th October 2021, 21:55 | #153 | Link | |
Are you saying that if a block is currently analyse the overlap can do the next block to exist the current block. How does BlkSz/3 do a better job than BlkSz/2 - assuming / means divide. |
6th October 2021, 22:25 | #155 | Link | |
https://forum.doom9.org/showthread.p...686#post564686 Search them both for "overlap." |
7th October 2021, 02:37 | #156 | Link |
Assuming just 8 bit depth,
I nearly always avoid LSMash and ffms2, too many probs. Maybe this of use [in a demo format] DEMO.BAT Code:
REM https://forum.doom9.org/showthread.php?p=1908619#post1908619 REM We DO NOT LIKE SPACES IN FILE NAMES (REM == REMark ie comment) REM We DO NOT LIKE ACCENTS IN FILE NAMES. setlocal REM Where to Find ffmpeg set FFMPEG="C:\BIN\ffmpeg.exe" REM Where to get INPUT files, No terminating Backslash, "." = current directory (ie same as dir .bat file) set INDIR="." REM Where to place OUTPUT files, No terminating Backslash. "." would be same as .bat file, ".\OUT" = OUT folder in same directory as bat file. set OUTDIR="D:" REM Below, can add INPUT extensions as eg *.WEBM (SPACE separated, Batch Processes all INPUT type files in INDIR) FOR %%A IN (*.AVI *.MKV *.MP4 *.MOV *.QT *.3GP *.DVB *.VOB *.MPG *.MPEG *M2P *.PS *.TS *.DIVX *.XVID *.FLV *.WMV *.ASF *.MXF) DO ( REM ****** Un-REM [ie SELECT] ONLY one of below lines, Comment out ie REM the remaining lines. %FFMPEG% -i "%INDIR%\%%A" -vcodec utvideo -acodec pcm_s16le "%OUTDIR%\%%~nxA.AVI" REM %FFMPEG% -i "%INDIR%\%%A" -vcodec huffyuv -acodec pcm_s16le "%OUTDIR%\%%~nxA.AVI" REM %FFMPEG% -i "%INDIR%\%%A" -vcodec magicyuv -acodec pcm_s16le "%OUTDIR%\%%~nxA.AVI" REM %FFMPEG% -i "%INDIR%\%%A" -vcodec v410 -acodec pcm_s16le "%OUTDIR%\%%~nxA.AVI" REM %FFMPEG% -i "%INDIR%\%%A" -vcodec r210 -acodec pcm_s16le "%OUTDIR%\%%~nxA.AVI" REM %FFMPEG% -i "%INDIR%\%%A" -vcodec copy -acodec copy -sn "%OUTDIR%\%%~nxA.MKV" REM %FFMPEG% -i "%INDIR%\%%A" -vcodec utvideo -acodec copy "%OUTDIR%\%%~nxA.MKV" REM %FFMPEG% -i "%INDIR%\%%A" -vn -acodec pcm_s16le "%OUTDIR%\%%~nxA.WAV" REM %FFMPEG% -i "%INDIR%\%%A" -vcodec rawvideo -f rawvideo -an "%OUTDIR%\%%~nxA.rawvideo" REM *****************************************************************************************. ) Pause REM ... Above Command lines, What they do if UnREM'ed (and all others REM'ed, UnREM=UnCOMMENT ) : REM (1) Convert Video to UtVideo lossless, Convert Audio to 16 bit PCM audio (output AVI). REM (2) Convert Video to HuffYUV lossless, Convert Audio to 16 bit PCM audio (output AVI). REM (3) Convert Video to MagicYUV lossless, Convert Audio to 16 bit PCM audio (output AVI). REM (4) Convert Video to v410 Uncompressed 4:4:4 10-bit lossless, Convert Audio to 16 bit PCM audio (output AVI). REM (5) Convert Video to r210 Uncompressed RGB 10-bit lossless, Convert Audio to 16 bit PCM audio (output AVI). REM (6) Remux NO SUBTITLES, copy both video and audio but NOT subtitles(output MKV - see file extension at the end of the Remux line, ie MKV). REM (7) Convert Video to UtVideo lossless, copy audio (output MKV). REM (8) Skip any video, Convert Audio to 16 bit PCM (output WAV). REM (9) Convert Video to rawvideo uncompressed, Convert Audio to 16 bit PCM audio (output y4m). REM *****************************************************************************************. REM In the UnREM'ed command Line [ie without a preceding REM]:- REM '-vcodec utvideo' means convert video using utvideo codec. REM '-vcodec copy' means copy video rather than convert. REM '-vn' means no video output, use instead of eg '-vcodec utvideo' REM '-acodec pcm_s16le' means convert audio using pcm_s16le codec. REM '-acodec copy' means copy audio rather than convert. REM '-an' means no audio output, use instead of eg '-acodec pcm_s16le' REM The file extension at end of the line determines output container, eg '.AVI' REM REM From Command line with ffmpeg somewhere in your environment PATH:- REM 'ffmpeg -codecs >D:\ffmpeg_codecs.txt' REM Writes a txt file of ffmpeg available codecs to D:\ REM At start of txt file it shows a 'legend' or 'key' for codecs that can be used for video and audio, REM use only ENCODING SUPPORTED codecs, prefereably LOSSLESS. REM Supported codecs will vary with ffmpeg version. REM *****************************************************************************************. Copy video files to that directory. Click the bat, batch converts all in directory. Job done. Use reliable AviSource for the lot.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 7th October 2021 at 02:41. |
7th October 2021, 02:41 | #157 | Link |
Soul Architect
I had accidently posted the ffsm2 issue in the wrong thread; but since you answered... not sure converting 5K video to UT Video is a great idea. It would need enormous space!
Edit: for a 94MB video of 12 seconds, it produces a 2.2GB video and lists these errors: - Using non-standard frame rate 29/1 - deprecated pixel format used, make sure you did set range correctly - Duplicate POC in a sequence - Error parsing NAL unit #0 - Error while decoding stream #0:0: Invalid data found when processing input Video is only missing the last frame and colours are wrong. lol.
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 7th October 2021 at 02:54. |
7th October 2021, 02:45 | #158 | Link |
Maybe, but they would work without problems.
I think GoPro would be mp4, just use LSmashVideoSource, that one is usually fine.
7th October 2021, 03:02 | #159 | Link | |
Soul Architect
Also taking GoPro pictures -- need to set sharpening to LOW, and then add sharpening and contrast with Photoshop and it then looks as good or better than my cellphone. GoPro is peculiar to use... |
7th October 2021, 04:43 | #160 | Link |
Soul Architect
I tried Spotless+DR on other clips. As I suspected, it works great on some content and not so great on other types (by the nature of MVTools). Main issue is that MVTools blurs out what I call "fine textures", which is why xClean passes MVTools through BM3D which restores the textures; and then through KNLMeans which always improves upon the prefilter.
Other than lost textures, Spotless has nearly identical noise reduction as xClean. Sharpening is too high! |
denoise, despot, prefilter |
