Thread Tools Display Modes
Old 12th August 2010, 18:21   #9181  |  Link
By-Tor
@By-Tor
I think the problem may be associated with resizing subtitles. Try deselecting them one at a time. Also, do you have "Verbose Status Reporting" turned on? It helps when reporting issues.
I'm also a little confused as to how it is keeping the original on all the titles while it needs to shrink from 42GB to 22.9GB??? Do you have FORCE_NOENCODE set?
no not altered that i'm setting it away again without subs and will report back friday............yes i have verbose set on
thanx
By-Tor is offline   Reply With Quote
Old 12th August 2010, 20:18   #9182  |  Link
drmih
I'm sorry, but it works for everyone else. There has to be something you are doing differently. That's why I asked for more info. Why it would be unsupported in only your TSMUXER is beyond me. There are no issues with DTS-HD XLL tracks of which I am aware unless there is also a DTS-Express secondary track and you are playing the DVD-9 on a Sony player. In that instance the Sony is the issue. But... even in that case, TSMUXER has no issues with the reencoded source.
As I mentioned, I resolved this issue manually so it's not something I'm bothered about and the only reason I mentioned it again was that two other people also said the same regarding The Last Emperor a couple of pages ago. The only thing in common is that they are both DTS-HD XLL 2.0 - I have checked other regions and all say that both are 2.0 - whereas your copy is multi-channel - are we definitely both talking about the original version?
drmih is offline   Reply With Quote
Old 12th August 2010, 20:50   #9183  |  Link
bluerip
Originally Posted by DK View Post
Now that your attachment shows:
have you selected and tried the 2nd entry, which stands for the extended version of A&D?
Hi Dk,
Yes, same result as before.
When I select German language it false.
Any ideas?
bluerip is offline   Reply With Quote
Old 12th August 2010, 21:32   #9184  |  Link
KarstenS
I've tested the fix of the issue "2nd audio DD+ will be flagged as DTS express". Now it gets correct flagged as DD+ in rebuild too.
Playback problem with TMT still there.
But there is a different to before: With old version, I got only sound, when I've selected German. The sound was a mix of the german and the 2nd audiotrack, changing frame by frame (I think). When I selected other language, there was no sound at all.
In the new version, when I select german, I get the same as above. But when I select other language, I get now the comment stream clearly.
Something is also interesting. The comment is detected by BD-RB as 2nd audio, but in TMT it is listendened as regular audio and 2nd audio. More interesting is, when used, it is not selected unter 2nd audio. It is selected in list of regular audio.
To show, what I mean a screenshot of the menu. First of the original disc. Second of the rebuild. In both time I've selected audio comment by using the pop-up menu of the BD itself:
Original:
Rebuild:
Maybe it helps to find a fix for playback. Alternatively it would be nice, to be able to uncheck 2nd audio at all.
KarstenS is offline   Reply With Quote
Old 12th August 2010, 21:32   #9185  |  Link
DK
DK's Avatar
Originally Posted by bluerip View Post
Hi Dk,
Any ideas?
Since you want movie-only try this:
- use MakeMKV with the material and create an MKV form the main title
- next use tsMuxeR to re-create a BD structure from this MKV
- finally try BD RB again
DK is offline   Reply With Quote
Old 12th August 2010, 21:39   #9186  |  Link
DK
DK's Avatar
Original:
Rebuild:
hi KarstenS,
cf this post of mine and the one I posted before it for some mor background information
the problem sounds similar but I wasnt dealing with a software player
Old 12th August 2010, 23:46   #9187  |  Link
KarstenS
hi KarstenS,
Not directly. My problem is, that the main audio is not playing correctly. I've added a little sound sample to show what I mean. It is a really strange mix of movie stream and comment stream. There is no way in TMT to get the movie stream without that comment stream. The onliest, what I can get, is the comment plays alone.
When the 2nd audio is dropped out (for that I used a bug in the last version as an exploit to do this), it plays fine.
Old 13th August 2010, 00:17   #9188  |  Link
jdobbs
@KarstenS
What happens when you play it on a standalone player?
jdobbs.softworks@gmail.com
Old 13th August 2010, 00:41   #9189  |  Link
Capsbackup
@KarstenS
It will work fine with a standalone, the problem is with TMT3. If you use IMGBurn to create an image, then load that image with Virtual Clone Drive and play it with PowerDVD it will work properly then too!!
Capsbackup is offline   Reply With Quote
Old 13th August 2010, 06:41   #9190  |  Link
ftb32
Yes Capsbackup and Corel WinDvd 10 is very importand for play PS3 too..
ftb32 is offline   Reply With Quote
Old 13th August 2010, 08:07   #9191  |  Link
KarstenS
@KarstenS
Sorry. Can't test that. I've got a BD-ROM drive only. No BD burner. And for DVD9 it is a little bit to big (I rebuild with targetsize of 14,5GB). Had no need for this as I can use the original disk in standalone player. Rebuild is for use in driveless HTPC with WMC.
But as the original disk runs without that issue, there must be something, that is not clearly a fault of TMT3.
EDIT: Forgot some little thing. It is not only that strage sound. Also the english subtitle for audio comment is active in the rebuilt version. That is also not by using the original disc.
Old 13th August 2010, 15:12   #9192  |  Link
Capsbackup
I do not deny that the original plays perfectly fine with TMT3, and only the BD-RB backup does not.
However, that same backup plays fine with PowerDVD, unfortunately for most people that want to play the backup from folders, PowerDVD does not support this option. Thus, an image must be created to be played back by a virtual drive. For some reason, many people object to this.
Even more important, this same backup works perfectly fine if burned to BD-R/RE for playback on a standalone, which I believe was the intent for BD-RB.
Now if the standalone did not play it back correctly, jdobbs would be all over it!! But software players are not the same, hence updates happen all the time to correct issues.
Old 13th August 2010, 15:32   #9193  |  Link
DK
DK's Avatar
KarstenS, if you want to more or less store the content on a PC/HDD why not use makeMKV to create an mkv?
Old 13th August 2010, 15:35   #9194  |  Link
Capsbackup
I am not sure I completely understand. Are you saying that this audio mixing on PiP backups happens when played on a PS3 from BD-R/RE? Or software streaming?
I do not have a PS3, nor Corel WinDvd 10, so for this statement I will assume you are .
I am sure jdobbs would like to have BD-RB work perfectly for all playback options, but I think that would be a tall task even for him!
Old 13th August 2010, 15:50   #9195  |  Link
By-Tor
thanx
well it failed again with subs off
hope this is the info you need?
[18:17:17] BD Rebuilder v0.34.07 (beta)
  - Source:  DOCTOR_PARNASSUS
  - Input BD size: 42.09 GB
  - Approximate total content: [03:00:51.680]
  - Target BD size: 22.90 GB
  - Windows Version: 6.1 [7600]
  - Resize SD to HD 720p enabled
  - SHUTDOWN at completion enabled
  - Quality: High-Speed Option (BD-25), Two Pass
[18:17:20] PHASE ONE, Encoding
 - [18:17:20] Extracting A/V streams [VID_00000]
 - [18:17:26] Reencoding: VID_00000 (1 of 16)
 - [18:17:26] Collecting video information
   - Rate/Length: 23.976fps, 725 frames
   - Bitrate: 9,483 Kbs
 - [18:17:26] Reencoding: VID_00000, Pass 1 of 2
 - [18:17:27] Reencoding: VID_00000, Pass 2 of 2
 - [18:18:28] Video Encode complete
 - [18:18:28] Reencoding audio tracks (if req'd)
 - [18:18:28] Multiplexing M2TS
 - [18:18:30] Extracting A/V streams [VID_00001]
 - [18:36:45] Reencoding: VID_00001 (2 of 16)
 - [18:36:45] Collecting video information
   - Rate/Length: 23.976fps, 176,280 frames
   - Bitrate: 12,857 Kbs
 - [18:36:45] Reencoding: VID_00001, Pass 1 of 2
 - [18:36:47] Reencoding: VID_00001, Pass 2 of 2
 - [23:07:38] Video Encode complete
 - [23:07:38] Reencoding audio tracks (if req'd)
 - [23:07:39] Multiplexing M2TS
 - [23:17:45] Extracting A/V streams [VID_00014]
 - [23:18:12] Reencoding: VID_00014 (3 of 16)
 - [23:18:12] Collecting video information
   - Rate/Length: 23.976fps, 6,343 frames
   - Bitrate: 12,761 Kbs
 - [23:18:12] Reencoding: VID_00014, Pass 1 of 2
 - [23:18:13] Reencoding: VID_00014, Pass 2 of 2
 - [23:28:37] Video Encode complete
 - [23:28:37] Reencoding audio tracks (if req'd)
 - [23:28:37] Multiplexing M2TS
 - [23:28:51] Extracting A/V streams [VID_00015]
 - [23:29:03] Reencoding: VID_00015 (4 of 16)
 - [23:29:03] Collecting video information
   - Rate/Length: 23.976fps, 2,939 frames
   - Bitrate: 12,751 Kbs
 - [23:29:03] Reencoding: VID_00015, Pass 1 of 2
 - [23:29:04] Reencoding: VID_00015, Pass 2 of 2
 - [23:33:42] Video Encode complete
 - [23:33:42] Reencoding audio tracks (if req'd)
 - [23:33:42] Multiplexing M2TS
 - [23:33:46] Extracting A/V streams [VID_00016]
 - [23:34:27] Reencoding: VID_00016 (5 of 16)
 - [23:34:27] Collecting video information
   - Rate/Length: 23.976fps, 10,449 frames
   - Bitrate: 12,847 Kbs
 - [23:34:27] Reencoding: VID_00016, Pass 1 of 2
 - [23:34:28] Reencoding: VID_00016, Pass 2 of 2
 - [23:56:12] Video Encode complete
 - [23:56:12] Reencoding audio tracks (if req'd)
 - [23:56:12] Multiplexing M2TS
 - [23:56:38] Extracting A/V streams [VID_00017]
 - [23:56:57] Reencoding: VID_00017 (6 of 16)
 - [23:56:57] Collecting video information
   - Rate/Length: 23.976fps, 4,978 frames
   - Bitrate: 12,849 Kbs
 - [23:56:57] Reencoding: VID_00017, Pass 1 of 2
 - [23:56:58] Reencoding: VID_00017, Pass 2 of 2
 - [00:09:50] Video Encode complete
 - [00:09:50] Reencoding audio tracks (if req'd)
 - [00:09:50] Multiplexing M2TS
 - [00:10:00] Extracting A/V streams [VID_00018]
 - [00:10:19] Reencoding: VID_00018 (7 of 16)
 - [00:10:19] Collecting video information
   - Rate/Length: 23.976fps, 4,243 frames
   - Bitrate: 12,846 Kbs
 - [00:10:19] Reencoding: VID_00018, Pass 1 of 2
 - [00:10:20] Reencoding: VID_00018, Pass 2 of 2
 - [00:20:09] Video Encode complete
 - [00:20:09] Reencoding audio tracks (if req'd)
 - [00:20:09] Multiplexing M2TS
 - [00:20:19] Extracting A/V streams [VID_00019]
 - [00:20:56] Reencoding: VID_00019 (8 of 16)
 - [00:20:56] Collecting video information
   - Rate/Length: 23.976fps, 8,294 frames
   - Bitrate: 12,853 Kbs
 - [00:20:56] Reencoding: VID_00019, Pass 1 of 2
 - [00:20:57] Reencoding: VID_00019, Pass 2 of 2
 - [00:42:10] Video Encode complete
 - [00:42:10] Reencoding audio tracks (if req'd)
 - [00:42:10] Multiplexing M2TS
 - [00:42:29] Extracting A/V streams [VID_00020]
 - [00:42:47] Reencoding: VID_00020 (9 of 16)
 - [00:42:47] Collecting video information
   - Rate/Length: 23.976fps, 4,525 frames
   - Bitrate: 12,850 Kbs
 - [00:42:47] Reencoding: VID_00020, Pass 1 of 2
 - [00:42:49] Reencoding: VID_00020, Pass 2 of 2
 - [00:54:12] Video Encode complete
 - [00:54:12] Reencoding audio tracks (if req'd)
 - [00:54:12] Multiplexing M2TS
 - [00:54:21] Extracting A/V streams [VID_00021]
 - [00:55:02] Reencoding: VID_00021 (10 of 16)
 - [00:55:02] Collecting video information
   - Rate/Length: 23.976fps, 9,408 frames
 - [00:55:02] Reencoding: VID_00021, Pass 1 of 2
 - [00:55:03] Reencoding: VID_00021, Pass 2 of 2
 - [01:15:48] Video Encode complete
 - [01:15:48] Reencoding audio tracks (if req'd)
 - [01:15:48] Multiplexing M2TS
 - [01:16:20] Extracting A/V streams [VID_00022]
 - Error in attempt to extract audio/subs.
 - Not enought buffer for parse video stream. Current frame num 0
[01:16:21] - Failed to retrieve audio, aborted
hidden ops
[Options]
THREADS=n		n represents the number of threads to use in X264, default is "auto"
FREE_PROCESSOR=n	subtract n from the processor count (leaves n processors free for other tasks)
FIXED_CRF=n		n = 10..50 - force CRF encoding to use this CRF value (output size control disappears)
FIX_CLPI=n		n = 0/1 - if set to 1, BD-RB fixes CLPI file, only useful on old TSMUXER versions
MIN_M2TS_SIZE=n		n = minimum size required for BD-RB processing on BD-25 in MB, default is 100
SHOW_ENCODER=n		n = 0/1 - Default 0.  If set to 1, BD-RB will show the X264 window during encoding
QUICK_CRF=n		n = 10..50 -- CRF value for "Quick Extras" encoding, defaults are BD5=26,BD9=22,BD25=20
QUICK_USE_QUALITY=n	n = 0/1 - if set to 1, BD-RB will use the current quality selection for CRF encodes
SECONDARY_CRF=n		n = 10..50 - force BD-RB to use the specified CRF value for secondary encodings
SECONDARY_USE_QUALITY=n n = 0/1 - 0=OFF (default) - if set to "0" ultrafast is used, "1" uses standard quality
FORCE_ENCODE=n		n = 0/1 - if set to 1, BD-RB will never check to see if original video will fi
FORCE_NOENCODE=n	n = 0/1 - if set to 1, BD-RB will always use original video (sizing will not be checked)
NO_MBTREE=n		n = 0/1 - if set to 1, BD-RB will disable MBTREE in encodes
GROUP_SIZE=n		n = Number of frames in each sample group for CRF estimation
SAMPLE_SIZE=n		n = Number of frames in each sample for CRF estimation (size/group = sample percentage)
HDDVD_COMPLIANT=n	n = 0/1 - if set to 1, the output will be compliant with HD-DVD standards
AUDIO_AMPLIFY=n		n = 0-x - Increase volume of reencoded audio.  Example "1.2" = 20% increase, "2.0" = 2X
KEEP_MBTREE=n		n = 0/1 - 0=Off (default), 1=Keep the stats.mbtree file after encode is complete
TWEAK_PASS_ONE=s	s = X264 pass 1 command line tweak(s)(warning -- for experts only, bugs not supported)
TWEAK_PASS_TWO=s	s = X264 pass 2 command line tweak(s)(warning -- for experts only, bugs not supported)
WEIGHTP=n		n = 0/1 - If set to 1, BD-RB will allow X264 "--weightp", default is "0" (off)
USE_NAL_HRD=n		n = 0/1 - 1=ON (default) 1 = Use "--nal-hrd" in the X264 command line, 0 = Don't use it.
FIX_MOVIEONLY=n		n = 0/1 - 1=ON (default) - If set to "0", BD-RB will not add ExtensionData() to CLPI/MPLS
PASS_TWO_STATS_UPDATE=n n = 0/1 - 0=OFF (default) - if set to "1", BD-RB uses "--pass 3" for second pass
REMOVE_WORKING=n	n = 0/1 - 0=OFF (default) - if set to "1", the WORKFILES folder is removed after rebuild
REMOVE_OUTPUT=n		n = 0/1 - 0=OFF (default) - if set to "1", the OUTPUT folder is removed after burning
MKV_INTERMEDIATE=n	n = 0/1 - 0=OFF (default) - if set to "1", .MKV files are used instead of .264
B_PYRAMID=n		n = 0/1 - 1=On (default) - if set to "0", " --b-pyramid none" is used, else "strict"
ALTCRF=n		n = 0-50 - CRF value to use for Alternate Movie-Only encodes (default=20)
AUTO_BIAS=n		n = 0/1/2 - Default= 1, Auto Quality bias, 0=higher speed, 1=normal, 2=higher quality
IMGBURN_TARGET_DEVICE=s s = Drive to use for burning with ImgBurn (ex: e:, f:, etc)
SHUTDOWN_SLEEP=n        n = 0/1 - Default=0, Setting to "1" changes "SHUTDOWN after Rebuild" option to "SLEEP..."
DISABLE_FFMS=n		n = 0/1 - Default=0, Set to "1" to use AVISYNTH for seamless-branched titles
RESET_PERMISSION = n	n = 0/1 - Default=1, When set to "1", tells ImgBurn to reset permission flag during burn
COLOR_BOOST=n           n = 0/1 - Default=0, When set to "1" BD-RB will boost color levels by 10% (slow)
KEEP_HD_LPCM=n		n = 0/1 - Default=1, When set to "0", BD-RB reencodes LPCM even for "Keep HD Audio"
[Paths]
NICAUDIO=		Change the path for NICAUDIO.DLL
TSMUXER=		Change the path for TSMUXER.EXE
WAVI=			Change the path for WAVI.EXE
AFTEN=			Change the path for AFTEN.EXE
DECOMB=			Change the path for DECOMB521.DLL
MKVMERGE=		Change the path for MKVMERGE.EXE
last command was
"D:\RTER\WORKFILES\VID_00021.AVS" --preset ultrafast --cabac --bframes 3
--b-pyramid strict --weightp 0 --open-gop bluray --qpmin=0 --bitrate 12853 --level 4.1
--qpfile "D:\RTER\WORKFILES\VID_00021.CHP" --sar 1:1 --aud --nal-hrd vbr --pic-struct
--vbv-bufsize 30000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1
--vbv-maxrate 35000 --threads auto --slices 4 --thread-input
--output "D:\RTER\WORKFILES\VID_00021.AVS.264"
further info
[Options]
MODE=0
ENCODE_QUALITY=5
ONEPASS_ENCODING=0
AUTO_QUALITY=0
TARGET_SIZE=23450
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=
SD_CONVERT=1
OPEN_GOP=1
RESIZE_1080=0
DEINTERLACE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=0
REMOVE_WORKFILES=1
MOVIE_ONLY_LOOP=0
REMOVE_OUTPUT=0
USE_FILTERS=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=23450
QUICK_EXTRAS=0
VERBOSE_STATUS=1
[Paths]
SOURCE_PATH=D:\DOCTOR PARNASSUS\
WORKING_PATH=D:\RTER\
LABEL=DOCTOR_PARNASSUS
VERSION=v0.34.07 (beta)
SOURCE_SIZE=45194686690
SOURCE_VIDEO_SIZE=44071815168
TARGET_SIZE=24589107200
REDUCTION=.532454485674067
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=
BACKUP_MODE=0
MOVIEONLY_TYPE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=10
[00000]
AUDIO=111
PGS=0
M2TS_TARGET=56415299
RATE=9483
NSIZE=52058112
FLINK=0
MLINK=0
[00001]
AUDIO=111
PGS=0
M2TS_TARGET=17597114434
RATE=12857
NSIZE=16827635712
FLINK=0
MLINK=0
[00014]
AUDIO=11
PGS=
M2TS_TARGET=468778586
RATE=12761
NSIZE=460210176
FLINK=0
MLINK=0
[00015]
AUDIO=11
PGS=
M2TS_TARGET=217037785
RATE=12751
NSIZE=207974400
FLINK=0
MLINK=0
[00016]
AUDIO=1
PGS=
M2TS_TARGET=765059502
RATE=12847
NSIZE=738729984
FLINK=0
MLINK=0
[00017]
AUDIO=1
PGS=
M2TS_TARGET=364522328
RATE=12849
NSIZE=350490624
FLINK=0
MLINK=0
[00018]
AUDIO=1
PGS=
M2TS_TARGET=310632550
RATE=12846
NSIZE=302813184
FLINK=0
MLINK=0
[00019]
AUDIO=1
PGS=
M2TS_TARGET=607531761
RATE=12853
NSIZE=586266624
FLINK=0
MLINK=0
[00020]
AUDIO=1
PGS=
M2TS_TARGET=331376499
RATE=12850
NSIZE=318720000
FLINK=0
MLINK=0
[00021]
AUDIO=1
PGS=
M2TS_TARGET=689159743
RATE=12853
NSIZE=667502592
FLINK=0
MLINK=0
[00022]
AUDIO=1
PGS=
hope this is enough thanx
Old 13th August 2010, 16:05   #9196  |  Link
jdobbs
That is incorrect. If something plays on a standalone and doesn't play on TMT -- it absolutely is the player.
Old 13th August 2010, 16:14   #9197  |  Link
Capsbackup
@By-Tor;
I made a full disc backup to BD-R of this movie, region A, and it is perfect, no problems. Sorry, I know that does not help you though.
Perhaps try to delete the BD-RB .ini, or unzip a fresh downloaded one, and run it from there, letting BD-RB create a new .ini.
Then use only the defaults, no resizing at all. Keep all subs, HD audio if you like, and try again.
What is the specs of your VID_00022, the one yours is crashing on?
EDIT:
Mine is: 00:00:05, 645,120 bytes, MPEG-2 Video, 1080P/23.976fps/16:9 - per BDInfo.( no audio present )
Old 13th August 2010, 18:53   #9198  |  Link
KarstenS
Because of missing extras. No need for my movies. But the animation movies of my son contains extras, the we use mostly.
Ok. I belive you.
By the way. May it be possible, that you allow to disable 2nd audio for rebuilding please? As I already tested, it is a working workaround.
EDIT: Were my logs of cars helpful to explain why I got this oversize? As I didn't checked any HD audio, it should not be the reason, or?
Old 13th August 2010, 20:00   #9199  |  Link
ebjones
Originally Posted by ebjones View Post
I've ran into a problem backing up "The Warlords". My PS3 recognizes my BD-R and it appears to start, but then the screen goes blank/black and I'm unable to do anything except quit the movie. I have used the same settings for all my jobs and have backed up other titles since "The Warlords". I ripped the contents to the harddrive w/ AnyDVD 6.6.8.0.
[04:09:07] BD Rebuilder v0.34.04 (beta)
  - Source:  THE_WARLORDS
  - Input BD size: 40.03 GB
  - Approximate total content: [04:39:47.445]
  - Target BD size: 23.24 GB
  - Audio Settings: AC3=1 DTS=0 HD=1 Kbs=640
[04:09:07] PHASE ONE, Encoding
 - [04:09:07] Extracting A/V streams [VID_00021]
 - [04:09:11] Reencoding: VID_00021 (1 of 38)
 - [04:09:11] Collecting video information
   - Rate/Length: 23.976fps, 417 frames
 - [04:09:11] Reencoding: VID_00021, Pass 1 of 1
 - [04:09:24] Video Encode complete
 - [04:09:24] Reencoding audio tracks (if req'd)
 - [04:09:24] Multiplexing M2TS
 - [04:09:31] Extracting A/V streams [VID_00031]
 - [04:09:33] Reencoding: VID_00031 (2 of 38)
 - [04:09:33] Collecting video information
   - Rate/Length: 23.976fps, 562 frames
 - [04:09:33] Reencoding: VID_00031, Pass 1 of 1
 - [04:09:50] Video Encode complete
 - [04:09:50] Reencoding audio tracks (if req'd)
 - [04:09:50] Multiplexing M2TS
 - [04:09:51] Extracting A/V streams [VID_00011]
 - [04:09:53] Reencoding: VID_00011 (3 of 38)
 - [04:09:53] Collecting video information
   - Source Video: MPEG-2, 720x480
   - Rate/Length: 29.970fps, 2,529 frames
 - [04:09:53] Reencoding: VID_00011, Pass 1 of 1
 - [04:09:59] Video Encode complete
 - [04:09:59] Reencoding audio tracks (if req'd)
 - [04:09:59] Multiplexing M2TS
 - [04:10:00] Extracting A/V streams [VID_00009]
 - [04:10:03] Reencoding: VID_00009 (4 of 38)
 - [04:10:03] Collecting video information
   - Rate/Length: 29.970fps, 2,559 frames
 - [04:10:03] Reencoding: VID_00009, Pass 1 of 1
 - [04:10:08] Video Encode complete
 - [04:10:08] Reencoding audio tracks (if req'd)
 - [04:10:08] Multiplexing M2TS
 - [04:10:09] Extracting A/V streams [VID_00010]
 - [04:10:14] Reencoding: VID_00010 (5 of 38)
 - [04:10:14] Collecting video information
   - Rate/Length: 29.970fps, 2,970 frames
 - [04:10:14] Reencoding: VID_00010, Pass 1 of 1
 - [04:10:19] Video Encode complete
 - [04:10:19] Reencoding audio tracks (if req'd)
 - [04:10:19] Multiplexing M2TS
 - [04:10:20] Extracting A/V streams [VID_00006]
 - [04:10:23] Reencoding: VID_00006 (6 of 38)
 - [04:10:23] Collecting video information
   - Rate/Length: 29.970fps, 3,040 frames
 - [04:10:23] Reencoding: VID_00006, Pass 1 of 1
 - [04:10:29] Video Encode complete
 - [04:10:29] Reencoding audio tracks (if req'd)
 - [04:10:29] Multiplexing M2TS
 - [04:10:31] Extracting A/V streams [VID_00013]
 - [04:10:34] Reencoding: VID_00013 (7 of 38)
 - [04:10:34] Collecting video information
   - Rate/Length: 29.970fps, 3,127 frames
 - [04:10:34] Reencoding: VID_00013, Pass 1 of 1
 - [04:10:40] Video Encode complete
 - [04:10:40] Reencoding audio tracks (if req'd)
 - [04:10:40] Multiplexing M2TS
 - [04:10:41] Extracting A/V streams [VID_00007]
 - [04:10:46] Reencoding: VID_00007 (8 of 38)
 - [04:10:46] Collecting video information
   - Rate/Length: 29.970fps, 3,257 frames
 - [04:10:46] Reencoding: VID_00007, Pass 1 of 1
 - [04:10:52] Video Encode complete
 - [04:10:52] Reencoding audio tracks (if req'd)
 - [04:10:52] Multiplexing M2TS
 - [04:10:54] Extracting A/V streams [VID_00012]
 - [04:10:59] Reencoding: VID_00012 (9 of 38)
 - [04:10:59] Collecting video information
   - Rate/Length: 29.970fps, 3,355 frames
 - [04:10:59] Reencoding: VID_00012, Pass 1 of 1
 - [04:11:05] Video Encode complete
 - [04:11:05] Reencoding audio tracks (if req'd)
 - [04:11:05] Multiplexing M2TS
 - [04:11:07] Extracting A/V streams [VID_00008]
 - [04:11:12] Reencoding: VID_00008 (10 of 38)
 - [04:11:12] Collecting video information
   - Rate/Length: 29.970fps, 3,450 frames
 - [04:11:12] Reencoding: VID_00008, Pass 1 of 1
 - [04:11:18] Video Encode complete
 - [04:11:18] Reencoding audio tracks (if req'd)
 - [04:11:18] Multiplexing M2TS
 - [04:11:20] Extracting A/V streams [VID_00030]
 - [04:11:24] Reencoding: VID_00030 (11 of 38)
 - [04:11:24] Collecting video information
   - Rate/Length: 23.976fps, 930 frames
 - [04:11:24] Reencoding: VID_00030, Pass 1 of 1
 - [04:11:52] Video Encode complete
 - [04:11:52] Reencoding audio tracks (if req'd)
 - [04:11:52] Multiplexing M2TS
 - [04:11:53] Extracting A/V streams [VID_00016]
 - [04:11:58] Reencoding: VID_00016 (12 of 38)
 - [04:11:58] Collecting video information
   - Rate/Length: 29.970fps, 4,341 frames
 - [04:11:58] Reencoding: VID_00016, Pass 1 of 1
 - [04:12:05] Video Encode complete
 - [04:12:05] Reencoding audio tracks (if req'd)
 - [04:12:05] Multiplexing M2TS
 - [04:12:07] Extracting A/V streams [VID_00005]
 - [04:12:10] Reencoding: VID_00005 (13 of 38)
 - [04:12:10] Collecting video information
   - Rate/Length: 29.970fps, 6,605 frames
 - [04:12:10] Reencoding: VID_00005, Pass 1 of 1
 - [04:12:22] Video Encode complete
 - [04:12:22] Reencoding audio tracks (if req'd)
 - [04:12:22] Multiplexing M2TS
 - [04:12:25] Extracting A/V streams [VID_00018]
 - [04:12:30] Reencoding: VID_00018 (14 of 38)
 - [04:12:30] Collecting video information
   - Rate/Length: 29.970fps, 4,560 frames
 - [04:12:30] Reencoding: VID_00018, Pass 1 of 1
 - [04:12:37] Video Encode complete
 - [04:12:37] Reencoding audio tracks (if req'd)
 - [04:12:37] Multiplexing M2TS
 - [04:12:39] Extracting A/V streams [VID_00015]
 - [04:12:44] Reencoding: VID_00015 (15 of 38)
 - [04:12:44] Collecting video information
   - Rate/Length: 29.970fps, 4,590 frames
 - [04:12:44] Reencoding: VID_00015, Pass 1 of 1
 - [04:12:53] Video Encode complete
 - [04:12:53] Reencoding audio tracks (if req'd)
 - [04:12:53] Multiplexing M2TS
 - [04:12:55] Extracting A/V streams [VID_00023]
 - [04:13:00] Reencoding: VID_00023 (16 of 38)
 - [04:13:00] Collecting video information
   - Rate/Length: 23.976fps, 1,246 frames
 - [04:13:00] Reencoding: VID_00023, Pass 1 of 1
 - [04:13:37] Video Encode complete
 - [04:13:37] Reencoding audio tracks (if req'd)
 - [04:13:37] Multiplexing M2TS
 - [04:13:39] Extracting A/V streams [VID_00029]
 - [04:13:45] Reencoding: VID_00029 (17 of 38)
 - [04:13:45] Collecting video information
   - Rate/Length: 23.976fps, 1,402 frames
 - [04:13:45] Reencoding: VID_00029, Pass 1 of 1
 - [04:14:26] Video Encode complete
 - [04:14:26] Reencoding audio tracks (if req'd)
 - [04:14:26] Multiplexing M2TS
 - [04:14:27] Extracting A/V streams [VID_00017]
 - [04:14:34] Reencoding: VID_00017 (18 of 38)
 - [04:14:34] Collecting video information
   - Rate/Length: 29.970fps, 5,510 frames
 - [04:14:34] Reencoding: VID_00017, Pass 1 of 1
 - [04:14:43] Video Encode complete
 - [04:14:43] Reencoding audio tracks (if req'd)
 - [04:14:43] Multiplexing M2TS
 - [04:14:45] Extracting A/V streams [VID_00027]
 - [04:14:52] Reencoding: VID_00027 (19 of 38)
 - [04:14:52] Collecting video information
   - Rate/Length: 23.976fps, 1,508 frames
 - [04:14:52] Reencoding: VID_00027, Pass 1 of 1
 - [04:15:37] Video Encode complete
 - [04:15:37] Reencoding audio tracks (if req'd)
 - [04:15:37] Multiplexing M2TS
 - [04:15:38] Extracting A/V streams [VID_00508]
 - [04:15:45] Reencoding: VID_00508 (20 of 38)
 - [04:15:45] Collecting video information
   - Rate/Length: 29.970fps, 1,859 frames
 - [04:15:45] Reencoding: VID_00508, Pass 1 of 1
 - [04:16:39] Video Encode complete
 - [04:16:39] Reencoding audio tracks (if req'd)
 - [04:16:39] Multiplexing M2TS
 - [04:16:41] Extracting A/V streams [VID_00014]
 - [04:16:49] Reencoding: VID_00014 (21 of 38)
 - [04:16:49] Collecting video information
   - Rate/Length: 29.970fps, 6,705 frames
 - [04:16:49] Reencoding: VID_00014, Pass 1 of 1
 - [04:17:02] Video Encode complete
 - [04:17:02] Reencoding audio tracks (if req'd)
 - [04:17:02] Multiplexing M2TS
 - [04:17:04] Extracting A/V streams [VID_00020]
 - [04:17:14] Reencoding: VID_00020 (22 of 38)
 - [04:17:14] Collecting video information
   - Rate/Length: 29.970fps, 9,272 frames
 - [04:17:14] Reencoding: VID_00020, Pass 1 of 1
 - [04:17:31] Video Encode complete
 - [04:17:31] Reencoding audio tracks (if req'd)
 - [04:17:31] Multiplexing M2TS
 - [04:17:34] Extracting A/V streams [VID_00032]
 - [04:17:44] Reencoding: VID_00032 (23 of 38)
 - [04:17:44] Collecting video information
   - Rate/Length: 23.976fps, 2,538 frames
 - [04:17:44] Reencoding: VID_00032, Pass 1 of 1
 - [04:18:54] Video Encode complete
 - [04:18:54] Reencoding audio tracks (if req'd)
 - [04:18:54] Multiplexing M2TS
 - [04:18:56] Extracting A/V streams [VID_00019]
 - [04:19:06] Reencoding: VID_00019 (24 of 38)
 - [04:19:06] Collecting video information
   - Rate/Length: 29.970fps, 10,470 frames
 - [04:19:06] Reencoding: VID_00019, Pass 1 of 1
 - [04:19:25] Video Encode complete
 - [04:19:25] Reencoding audio tracks (if req'd)
 - [04:19:25] Multiplexing M2TS
 - [04:19:29] Extracting A/V streams [VID_00024]
 - [04:19:42] Reencoding: VID_00024 (25 of 38)
 - [04:19:42] Collecting video information
   - Rate/Length: 23.976fps, 2,863 frames
 - [04:19:42] Reencoding: VID_00024, Pass 1 of 1
 - [04:21:09] Video Encode complete
 - [04:21:09] Reencoding audio tracks (if req'd)
 - [04:21:09] Multiplexing M2TS
 - [04:21:13] Extracting A/V streams [VID_00521]
 - [04:21:26] Reencoding: VID_00521 (26 of 38)
 - [04:21:26] Collecting video information
 - [04:21:26] Reencoding: VID_00521, Pass 1 of 1
 - [04:22:31] Video Encode complete
 - [04:22:31] Reencoding audio tracks (if req'd)
 - [04:22:31] Multiplexing M2TS
 - [04:22:35] Extracting A/V streams [VID_00522]
 - [04:22:50] Reencoding: VID_00522 (27 of 38)
 - [04:22:50] Collecting video information
   - Rate/Length: 23.976fps, 3,117 frames
 - [04:22:50] Reencoding: VID_00522, Pass 1 of 1
 - [04:24:08] Video Encode complete
 - [04:24:08] Reencoding audio tracks (if req'd)
 - [04:24:08] Multiplexing M2TS
 - [04:24:11] Extracting A/V streams [VID_00028]
 - [04:24:26] Reencoding: VID_00028 (28 of 38)
 - [04:24:26] Collecting video information
   - Rate/Length: 23.976fps, 3,601 frames
 - [04:24:26] Reencoding: VID_00028, Pass 1 of 1
 - [04:26:11] Video Encode complete
 - [04:26:11] Reencoding audio tracks (if req'd)
 - [04:26:11] Multiplexing M2TS
 - [04:26:14] Extracting A/V streams [VID_00523]
 - [04:26:30] Reencoding: VID_00523 (29 of 38)
 - [04:26:30] Collecting video information
   - Rate/Length: 23.976fps, 3,105 frames
 - [04:26:30] Reencoding: VID_00523, Pass 1 of 1
 - [04:27:54] Video Encode complete
 - [04:27:54] Reencoding audio tracks (if req'd)
 - [04:27:54] Multiplexing M2TS
 - [04:27:59] Extracting A/V streams [VID_00520]
 - [04:28:14] Reencoding: VID_00520 (30 of 38)
 - [04:28:14] Collecting video information
   - Rate/Length: 23.976fps, 3,020 frames
 - [04:28:14] Reencoding: VID_00520, Pass 1 of 1
 - [04:29:31] Video Encode complete
 - [04:29:31] Reencoding audio tracks (if req'd)
 - [04:29:31] Multiplexing M2TS
 - [04:29:35] Extracting A/V streams [VID_00026]
 - [04:29:56] Reencoding: VID_00026 (31 of 38)
 - [04:29:56] Collecting video information
   - Rate/Length: 23.976fps, 3,703 frames
 - [04:29:56] Reencoding: VID_00026, Pass 1 of 1
 - [04:31:54] Video Encode complete
 - [04:31:55] Reencoding audio tracks (if req'd)
 - [04:31:55] Multiplexing M2TS
 - [04:31:58] Extracting A/V streams [VID_00003]
 - [04:32:22] Reencoding: VID_00003 (32 of 38)
 - [04:32:22] Collecting video information
   - Rate/Length: 29.970fps, 31,963 frames
 - [04:32:22] Reencoding: VID_00003, Pass 1 of 1
 - [04:33:21] Video Encode complete
 - [04:33:21] Reencoding audio tracks (if req'd)
 - [04:33:21] Multiplexing M2TS
 - [04:33:29] Extracting A/V streams [VID_00004]
 - [04:34:01] Reencoding: VID_00004 (33 of 38)
 - [04:34:02] Collecting video information
   - Rate/Length: 29.970fps, 8,346 frames
 - [04:34:02] Reencoding: VID_00004, Pass 1 of 1
 - [04:38:06] Video Encode complete
 - [04:38:06] Reencoding audio tracks (if req'd)
 - [04:38:06] Multiplexing M2TS
 - [04:38:16] Extracting A/V streams [VID_00001]
 - [04:38:58] Reencoding: VID_00001 (34 of 38)
 - [04:38:58] Collecting video information
   - Rate/Length: 29.970fps, 49,040 frames
 - [04:38:58] Reencoding: VID_00001, Pass 1 of 1
 - [04:40:19] Video Encode complete
 - [04:40:19] Reencoding audio tracks (if req'd)
 - [04:40:19] Multiplexing M2TS
 - [04:40:31] Extracting A/V streams [VID_00025]
 - [04:41:17] Reencoding: VID_00025 (35 of 38)
 - [04:41:17] Collecting video information
   - Rate/Length: 23.976fps, 7,962 frames
 - [04:41:17] Reencoding: VID_00025, Pass 1 of 1
 - [04:45:20] Video Encode complete
 - [04:45:20] Reencoding audio tracks (if req'd)
 - [04:45:21] Multiplexing M2TS
 - [04:45:30] Extracting A/V streams [VID_00002]
 - [04:46:30] Reencoding: VID_00002 (36 of 38)
 - [04:46:31] Collecting video information
   - Rate/Length: 29.970fps, 63,636 frames
 - [04:46:31] Reencoding: VID_00002, Pass 1 of 1
 - [04:48:26] Video Encode complete
 - [04:48:26] Reencoding audio tracks (if req'd)
 - [04:48:26] Multiplexing M2TS
 - [04:48:40] Extracting A/V streams [VID_00022]
 - [04:50:02] Reencoding: VID_00022 (37 of 38)
 - [04:50:02] Collecting video information
   - Rate/Length: 23.976fps, 15,628 frames
 - [04:50:03] Reencoding: VID_00022, Pass 1 of 1
 - [04:58:00] Video Encode complete
 - [04:58:00] Reencoding audio tracks (if req'd)
 - [04:58:00] Multiplexing M2TS
 - [04:58:37] Extracting A/V streams [VID_00000]
 - [05:13:11] Reencoding: VID_00000 (38 of 38)
 - [05:13:11] Collecting video information
   - Rate/Length: 23.976fps, 163,008 frames
   - Bitrate: 16,370 Kbs
 - [05:13:11] Reencoding: VID_00000, Pass 1 of 2
 - [05:13:11] Reencoding: VID_00000, Pass 2 of 2
 - [06:34:41] Video Encode complete
 - [06:34:41] Reencoding audio tracks (if req'd)
 - [06:34:41] Multiplexing M2TS
[06:42:55]PHASE ONE complete
[06:42:55]PHASE TWO - Rebuild Started
 - [06:42:55] Rebuilding BD file Structure
[06:43:14] - Encode and Rebuild complete
 - WORKFILES folder removed.
[06:43:16]JOB: THE_WARLORDS finished.
ebjones is offline   Reply With Quote
Old 13th August 2010, 23:54   #9200  |  Link
jdobbs
@ebjones
Please note this quote from the first post of this thread:
If you decide to download and test -- please post any errors you find in this thread. Don't push bug resolution or keep asking for a fix. I will get to the reported bugs, but only when I can find the time.
Continually posting to try and give your problem priority will simply get it ignored.
Thread Tools
