Old 16th May 2008, 00:51   #1  |  Link
FortyFootPianist
Problems With MKV2VOB And Converting HD In General
I have some movies in MKV format, x264, ac3, about 8gb. I want to convert them and split them to 4gb or smaller pieces so I can put them on my iPod and play them on my PS3.
I used mkv2vob on one of them and it worked perfectly to convert it to MPG and split it in 3 parts.
Then I tried using it again and it gave me a "Besplitt Crashed" error after the AC3 to AAC conversion. I tried using different files, unistall/reinstalling, nothing works.
I tried alot of other apps that each had problems.
Tsmuxer couldn't detect the audio stream. I clicked add, chose the file, it said a stream could not be detected or something like that, and only added the video stream. So I used RipBot264 to extract the audio, video, and subtitle tracks. Tsmuxer worked with the video and subtitles, but said it couldn't detect stream when I tried to add the audio.
River Past Video Cleaner only converted the first 11 minutes and I have the Pro version, not the freeware version.
PS3 Video 9 converter said it couldn't sample.
Puma MKV converter wouldn't even do anything. I clicked convert, then 2 seconds later it said complete, but nothing happened.
And there were many others
So I was hoping that someone could help me to fix mkv2vob or my computer (I'm thinking it has something to do with this). If not then recommend another converter and splitter (preferably an app that does both). So can anyone help me out?
If a fan gives off cool air when spun in one direction, then it makes perfect sense that if spun in the opposite direction, it would give off heat.
FortyFootPianist is offline
Old 16th May 2008, 16:18   #2  |  Link
gu8lal8
I've had the same problem, you need to go back to mkv2vob 2.2.1 and then before you start mkv2vob you need to disconnect your internetconnection otherwise it will automatically update to version 2.2.3 (do not reconnect until you've closed mkv2vob)
gu8lal8 is offline
Old 16th May 2008, 16:38   #3  |  Link
Why don't you re-encode from your original DVDs?
Guest is offline
Old 18th May 2008, 05:58   #4  |  Link
FortyFootPianist
It works perfect now. Thanks alot!
Old 26th May 2008, 17:13   #5  |  Link
FortyFootPianist
Crap, another problem came up. I'm getting this error, Could not parse mkv file. I've tried adding the directory, and separately adding the mkv files (2 files). I've tried using versions 2.2.1, 2.2.2, 2.2.3, 2.1.0, and 2.05. (Decided to randomly try different versions). Nothing works.
This is the configuration:
Preferred Audio Language: English
Video Transcoding: Automatic
Preferred Subtitle Language: None
File Splitting: FAT32 (4GB)
Output File Extension: MPG
Transcoding Codec: x264
Top 2 boxes on the right are checked
Old 26th May 2008, 18:11   #6  |  Link
Where did you get the MKV files?
Guest is offline
Old 27th May 2008, 17:29   #7  |  Link
FortyFootPianist
I got them from a friend. He transferred them to my computer with his external HDD.
Old 27th May 2008, 17:37   #8  |  Link
setarip_old
setarip_old's Avatar
Hi!
(cough, cough) Rule #6?
setarip_old is offline
convert, mkv, ps3, split, x264
