23rd September 2021, 08:24 | #1381 | Link | |
Broadcast Encoder
Still, I gotta be fair, having an indexer that doesn't create an index file means that it's faster to open in AVS however I wouldn't take the risk on MP4 files from somewhere from the web 'cause bad things can happen like in this case. On the other hand, when I receive .mxf files of 1.3 TB as UHD Masterfiles it could be useful as it would save hours of indexing time (assuming that the index inside the container is correct). So, in a nutshell, I'd like LSMASH to support MXF as well one day, but for anything that doesn't come from a professional studio, I wouldn't take any chances and I would use an indexer that indexes the file. |
7th October 2021, 02:38 | #1382 | Link | |
Soul Architect
He did investigate the issue.
Is there any way I can open GoPro videos without such glitches? |
7th October 2021, 02:47 | #1383 | Link | |
Useful n00b
7th October 2021, 03:17 | #1384 | Link |
Soul Architect
Here's a sample video
I just converted a GoPro 5K HEVC video to UT Video with FFMPEG and it gave this list of errors: - Using non-standard frame rate 29/1 - deprecated pixel format used, make sure you did set range correctly - Duplicate POC in a sequence - Error parsing NAL unit #0 - Error while decoding stream #0:0: Invalid data found when processing input ... |
25th October 2021, 13:40 | #1386 | Link |
Broadcast Encoder
Who's the current maintainer of LSMASH and in which repository can I open an issue on Github about LWLibavAudioSource?
It used to be HollyWu but if I remember correctly last time he retired... so... who's handling this now? Last edited by FranceBB; 25th October 2021 at 13:43. |
25th October 2021, 16:51 | #1388 | Link |
Broadcast Encoder
Yes, but I didn't know where, I mean in which repository xD
In the end, I figured it out and I opened it here: https://github.com/AkarinVS/L-SMASH-Works/issues/17 I feel like I'm always the only one who comes up with Indexing bugs on weird audio codecs like last time with IPCM. This time is DolbyE ehehehehehe |
25th October 2021, 17:15 | #1389 | Link | |
https://github.com/HomeOfAviSynthPlu...H-Works/issues |
10th November 2021, 14:47 | #1390 | Link |
Broadcast Encoder
Opened a new bug about a ZLog2 HDR H.265 UHD file (yes, there's more than just PQ and HLG in the world ehehehe): https://github.com/AkarinVS/L-SMASH-Works/issues/18
7th April 2022, 06:30 | #1391 | Link |
L-SMASH-Works (20220406)
https://github.com/HomeOfAviSynthPlu...Works/releases |
9th April 2022, 22:03 | #1392 | Link | |
Broadcast Encoder
I have a question, or rather a feature request: when an .xml is given to the indexer like LWLibavVideoSource("CPL.xml") and LWLibavAudioSource("CPL.xml") please try to use the IMF decoder built into FFMpeg rather than return an error. That would be really cool as this way we're gonna have IMF support inside Avisynth! |
9th April 2022, 22:11 | #1394 | Link |
Broadcast Encoder
20th April 2022, 18:54 | #1395 | Link |
Big Bit Savings Now !
Tiny cosmetics, don't remember when it sneaked in.
At first opening and indexing the resampler rate default seems to be uninitiated: Code:
a=LWLibavAudioSource("F:\file.avi" but indexes anyway. Reloading after indexing throws no error.
28th April 2022, 19:04 | #1396 | Link | |
Have reported this here: https://github.com/HomeOfAviSynthPlu...orks/issues/20
Live and let live |
28th April 2022, 22:29 | #1397 | Link |
Yes, confirmed: In my case PCM Codec ID "twos" Big Endian/Signed 16bps@48kHz wrapped in .MP4 from a Panasonic DC-GH5.
5th May 2022, 19:12 | #1398 | Link |
L-SMASH-Works 20220505
https://github.com/HomeOfAviSynthPlu...Works/releases If FranceBB rep issue quickly, we will have IMF support function |
5th May 2022, 19:14 | #1399 | Link | |
Broadcast Encoder
