1st August 2009, 18:02 | #8921 | Link |
MPC-HC Project Manager
Please make a screenshot, with CTRL+J active.
And rightmouseclick on the screen with filters opened, and the bottom one (usually the splitter) opened too.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
1st August 2009, 18:13 | #8922 | Link | |
The dll can be downloaded freely here: http://rarlabs.com/rar_add.htm
MPC-HC 2.1.7.2 |
1st August 2009, 20:28 | #8923 | Link | |
clueless n00b
As for the rest here you go.. 32bit and 64bit varieties.. at first glance everything looks the same, I don't see any filters that are or are not there.. yet in the 32bit version the subtitle menu is active and lists all my subs, in the 64bit version it isn't active and I have no subs. @clsid: you that does the trick.. cannot verify for the 64bit version of course since I get no subs there.
1st August 2009, 20:48 | #8924 | Link |
Hello people. I need help. I use MPC-HC 1.2.1161 with Radeon HD 4800 & Catalyst 9.6 & Win7. I watch DVD (MPEG2) and i don't see subtitles. Filter Microsoft DTV-DVD Video decoder (ATI Avivo work fine). Built-in filter work fine with subs. Can I see subs with avivo or not?
1st August 2009, 20:56 | #8925 | Link | |
your using vsfilter external right? You could try checking "autoload subtitles" in the options
1st August 2009, 21:24 | #8928 | Link | ||
1st August 2009, 22:09 | #8929 | Link | ||
clueless n00b
I did the first two now and now the internal subtitle support is working for that particular AVI, both in EVR custom and VMR9 renderless mode. Naturally Quote:
Isn't it a bit weird though that subs work out of the box without DX9 (I get the usual warning message about the missing d3d dll) whereas the 64bit version requires a (32bit?) directx9?
1st August 2009, 23:55 | #8931 | Link |
I used "search" but couldn't find what I was looking for, so I hope this hasn't been asked before...
Embedded DirectVobSub is great of course, but is it normal that I have to setup "Styles..." every time I open a movie? I noticed that just like the external DirectVobSub filter I used in the past, the options window is only accessible while watching a movie. Isn't it possible to fully integrate these style settings into the MPC-HC subtitle settings?
My hobby website |
2nd August 2009, 03:15 | #8933 | Link |
I have created a thread here:
http://forum.doom9.org/showthread.php?t=148667 Explaining a situation with MPC-HomeCinema. Do you guys have any idea if this is some sort of bug? I was using the last version.
"Whoever has not known himself has known nothing. But whoever has known himself has simultaneously achieved knowledge about the depth of all things." |
2nd August 2009, 05:17 | #8934 | Link | |
Do you know about the settings under "View" > "Options" > "Subtitles>Default Style"? |
2nd August 2009, 07:23 | #8935 | Link | |
DSM Converter in MPC
But please don't remove the DSM Converter, I just discovered it and use it for demuxing audio tracks from .flv files which works great in my opinion. In fact I would like to extract audio tracks from .swf files as well which play fine in v6.4.9.1 rev 89 (not MPC-HC, the patched build), but the DSM Converter does not open them. Does anybody know if I need a separate DS filter for .swf files for extracting audio tracks with the DSM Converter? |
2nd August 2009, 10:10 | #8937 | Link |
I don't have that option in v6.4.9.1 rev 89, but maybe you meant "Quick Open File..."? I use it now and then, but it's a bit inconvenient, because you have to mark all files in the chosen directory first, then click "Open" and then activate the Playlist option in the "View" menu as well. Furthermore this playlist only shows the duration of played files, not the size or date.
But maybe that is only the case in the patched build of MPC and not with MPC-HC? |
2nd August 2009, 10:13 | #8938 | Link |
I am getting a signal on the M2TS I was trying to open before.
Now it's showing image, and all sorts of things. The only problem is that the video is running too fast, it can't stay normal at all. The image was showed only after I selected "FFDShow Video Decoder" on "External Filters". I noticed BSPlayer is running the M2TS fine, and the "Haali Media Splitter" logo is being showed on the tray. But if I choose "Prefer" on FFDShow and/or Set Merit for FFDShow Video and Haali, it will not make the M2TS normal. What should I set on External Filters for MPC-HC? I am trying to play all kinds of files here. The K-Lite codec pack was installed (Mega w/ last update). EDIT: Issue solved! I discover the reason for the black screen stated here: http://forum.doom9.org/showthread.php?t=148667 It was necessary to uncheck all the source-filters settings (as you can see, only FLAC is enabled). Then, only FFDShow Video-Decoder with Prefer merit was necessary. Now the extracted M2TS is working fine, normal speed, and only with my desired tracks/subtitles. This is really cool, I thought I wasn't solve this issue at all. ******************* Oh-oh, trouble again! If the source-filter (see picture above) MPEG PS/TS/PVA is disabled (and I checked all the rest), MPC-HC will open "Haali Media Splitter" while the M2TS is running. The problem is when you attempt to change the subtitle embedded on the M2TS file. All attempts will fail and the player WILL crash. Since it was working before, is there a way for me to remove this Haali Media Splitter? I tried to set the filter as "Blocked", but that didn't helped me. If I enable the "MPEG PS/TS/PVA" source filter from MPC, I will have this issue (video running at very fast speed). So far I have solved a problem but caused another. All started when I tried to remove some unwanted tracks from my movie, using TSMuxer. The new M2TS file was not being recognized by MPC-HC (and only him, returning a black-screen).
"Whoever has not known himself has known nothing. But whoever has known himself has simultaneously achieved knowledge about the depth of all things." Last edited by Lincoln Burrows; 2nd August 2009 at 10:49. |
2nd August 2009, 10:22 | #8939 | Link |
Wuahahaha....unbelievable! I can't believe I missed that! Thank you
My hobby website |
