Old 4th September 2024, 03:10   #1  |  Link
djesteban
djesteban's Avatar
Edit max-cll metadata in hevc stream
Anyone know if there's a way to edit the max-cll value from a hevc stream? I know FFmpeg as a hevc_metadata bitstream filter, but it doesn't seem to have the specific argument to modify this value.
Thanks in advance
djesteban is offline   Reply With Quote
Old 4th September 2024, 13:46   #2  |  Link
djesteban
djesteban's Avatar
Actually max-cll is only the option passed to x265, but when encoded they are two separate values:
- Max Content Light Level
- Max Frame-Average Light Level
There's a way to edit these values inside a mkv with mkvpropedit, but I'd rather edit then directly in the hevc stream
Old 9th September 2024, 16:56   #3  |  Link
benwaggoner
Particularly for adaptive streaming, the values need to be included again for every fragment.
That said, I'm not aware of any real-world player that uses MaxFALL, and only a few that use MaxCLL. Knowing the brightness of the brightest single pixel in a two hour movie really isn't that useful in figuring out how to tone map any given scene.
Ben Waggoner
My Compression Book
Old 11th September 2024, 04:11   #4  |  Link
djesteban
djesteban's Avatar
I realize that; I was simply wondering if it is possible to edit these values in an HEVC stream. From what I’ve read (here (Annex D) and here), MaxFALL and MaxCLL are stored as Supplemental Enhancement Information (SEI) data, but I’m not sure if it’s possible to manipulate these SEI message payloads. Additionally, I noticed that the HEVC metadata FFmpeg can modify, seems to be limited to VUI parameters (according to ITU-T H.265 Annex E), so perhaps that’s the extent of what can be easily edited.
Thanks for your input though, appreciated!
Old 11th September 2024, 18:29   #5  |  Link
Ritsuka
It's possible, but I don't know (and never checked) if there is already some program to do so.
Ritsuka is offline   Reply With Quote
Old 12th September 2024, 00:44   #6  |  Link
Z2697
If it's SEI, then perhaps you can encode a dummy stream with the correct value, then swap the corresponding NALU.
Z2697 is offline   Reply With Quote
