Old 26th August 2024, 10:19   #1  |  Link
XadoX
XadoX's Avatar
Recode Content with Dolby Vision
I am a longtime user of MeGUI to re-encode video content.
More and more content has Dolby Vision and it is not clear to me how this should be handled.
Since Kodi is now also able to handle the FEL layer, I would like to keep it.
Is it enough to just demux the content via eac3to and then reinject the RPU afterwards?
Do you have a tutorial to hand, maybe?
XadoX is offline   Reply With Quote
Old 27th August 2024, 22:42   #2  |  Link
benwaggoner
I'm not aware of MeGUI having any native support for any HDR format.
Ben Waggoner
My Compression Book
Old 28th August 2024, 06:44   #3  |  Link
XadoX
XadoX's Avatar
It does not necessarily have to be realized with MeGUI. If other tools are suitable for this, I would also be grateful for suggestions.
Old 28th August 2024, 07:30   #4  |  Link
rwill
For Profile 5 you can just demux the RPU, re-encode the video and then remux the RPU with the new video stream. Same for Profile 8.x.
For Profile 7 with FEL you cannot do that because you would need the original source to generate the enhancement layer from the new encoded base layer. I am also not aware of publicly available tools that can do that.
My github...
Old 28th August 2024, 08:09   #5  |  Link
XadoX
XadoX's Avatar
Thank you very much. That makes it clearer for me now.
