Old 13th August 2024, 10:03   #1  |  Link
LigH
LigH's Avatar
Modifications of x265
A little overview over modifications of x265:
Yuuki-Asuna mod by msg7086 - appears to be obsolete, last release: Feb. 2019
aMod by DJATOM
Patman mod by Patman86
both with: extended progress bar; XLENGTH y4m tag support; Avisynth scripts reader; Vapoursynth scripts reader
Did I miss any?
New German Gleitz board
Old 13th August 2024, 17:25   #2  |  Link
Boulder
Pig on the wing
Boulder's Avatar
jpsdr's mod has some more things on top of Patman86's mod.
https://github.com/jpsdr/x265/tree/x265_mod
Then there's the "Kyouko" branch forked from the Yuuki-Asuna mod, which has some experimental stuff.
https://github.com/AmusementClub/x265/tree/Kyouko
I posted a patch earlier in the x265 thread to use with MABS containing changes from both of these branches, I don't know if it applies to the most recent sources as there's plenty of changes now.
Old 13th August 2024, 21:53   #3  |  Link
qyot27
qyot27's Avatar
I mean, the Patman mod is just a combination of patches from the Yuuki branch and DJATOM, squashed into a single commit with no proper attribution or history.
I've largely kept the Yuuki patches refreshed¹ against current master (publicly at https://github.com/qyot27/x265/commits/Yuuki). I think there might have been a small handful that were so broken it made no sense to continue limping them along, but I can't remember which ones.
¹generally this happens every six months or so, while I'm rebuilding my cross compilation environment after moving to the latest version of Ubuntu.
Originally Posted by LigH View Post
Yuuki-Asuna mod by msg7086 - appears to be obsolete, last commit Feb. 2019
Releases aren't commits (and the builds were Asuna, anyway, not Yuuki).
Old 15th August 2024, 21:03   #4  |  Link
benwaggoner
y4m tag support
x265 has always had solid y4m support in my use, correctly reading frame size, bit depth, etc. Is there something that didn't work that other builds have made possible?
Ben Waggoner
My Compression Book
Old 15th August 2024, 21:11   #5  |  Link
LigH
LigH's Avatar
The Y4M header tag XLENGTH has been explained by DJATOM once, it's like a vague suggestion how many frames should be expected. This helps a progress estimation for piped input.
Multimedia Wiki: YUV4MPEG2 mentions tags starting with an X to be comments or private extensions.
Old 15th August 2024, 21:32   #6  |  Link
qyot27
qyot27's Avatar
It's referring to this:
https://github.com/qyot27/x265/commi...6b14d5810a1dff
If an application writes the framecount of the stream to the XLENGTH tag in the y4m stream, this patch allows x265 to read said value when intaking y4m as a pipe from that application, so that you get the normal % display and frame progress counter. Compare against piping out of FFmpeg to x265, where the framecount is unknown and there is no progress counter.
ffmpeg -v 0 -i test.ext -f yuv4mpegpipe - | x265 --preset ultrafast --tune zerolatency --crf 18 -o testframecount.ext - --y4m
vs
vspipe test.vpy - -c y4m | x265 --preset ultrafast --tune zerolatency --crf 18 -o testframecount.ext - --y4m
or
avs2yuv test.avs -o - | x265 --preset ultrafast --tune zerolatency --crf 18 -o testframecount.ext - --y4m
(avs2yuv here is https://github.com/DJATOM/avs2yuv, since it has native *nix support)
Old 15th August 2024, 22:49   #7  |  Link
benwaggoner
Ah, that would be helpful!
Ben Waggoner
My Compression Book
Old 26th August 2024, 18:18   #8  |  Link
LigH
LigH's Avatar
https://github.com/DJATOM/avs2yuv/releases/tag/0.30 does not produce an XLENGTH flag.
Old 31st August 2024, 18:52   #9  |  Link
Z2697
My "updated Yuuki mod"
I got new aq-modes too! Yay!
https://github.com/Mr-Z-2697/x265-Yuuki-Asuna
Z2697 is offline   Reply With Quote
Old 1st September 2024, 05:19   #10  |  Link
Selur
Selur's Avatar
Good to know, thanks.
Old 1st September 2024, 12:08   #11  |  Link
Posts: n/a
So where is this file ??
The only one I could find was from back in May....
Sorry, found it...x265-Yuuki-3.6+84-lol.7z
