Old 3rd June 2024, 15:02   #1  |  Link
smaiderman
How can I encode to HEVC
Hi.
Im demuxing some movies, and using gmkvxtrac gets me a HEVC video file.
I wonder how can I encode to this format using staxrip.
My procedure to tonemap from HDR to SDR is:
Obtain the master MKV from the bluray.
Extract the video with gMKVxtract: -> .hevc file
"Encode" with StaxRip to ProRes.
Modify the color with DaVinci
Then export again to ProRes.
Then use Staxrip again to H265. But here is where I would like to have the HEVC file again, but I dont know what do I need to choose to encode to V_MPEGH/ISO/HEVC
smaiderman is offline   Reply With Quote
Old 3rd June 2024, 17:39   #2  |  Link
Kuler087
Kuler087's Avatar
You'll probably have to add something that can convert 422 to 420
right click on ffms2 / add / color / convert / convert to
DoVi_Scripts
Kuler087 is offline   Reply With Quote
Old 3rd June 2024, 19:54   #3  |  Link
smaiderman
What I can't find (or don'tunderstand) is that I cant choose V_MPEGH/ISO/HEVC when I click on x265.
Is this an option?
I know how to do the color grading from HDR to SDR in DaVinci.
What I can't find out is how to export to .HEVC file. (not .mp4, .mov, etc)
Old 3rd June 2024, 20:05   #4  |  Link
Kuler087
Kuler087's Avatar
Look at my picture again and click on where the arrows point...
left = video codec
right = container
DoVi_Scripts
Old 3rd June 2024, 20:50   #5  |  Link
smaiderman
Sorry. I did understand you.
I dont know why i cant link images,
I write the link.
https://ibb.co/MhS8kFz
I cant find the option im looking for.
Nither V_MPEGH/ISO/HEVC codec
nor HEVC container
Maybe do I need to instal some addons?
Old 3rd June 2024, 21:01   #6  |  Link
lvqcl
right image: "No Muxing".
lvqcl is offline   Reply With Quote
Old 3rd June 2024, 21:06   #7  |  Link
Kuler087
Kuler087's Avatar
Clearly you did not understand me. Everything you asked for is shown in the picture I posted... Just try it!!
HEVC = x265 (left)
no muxing = no container = .hevc (right)
DoVi_Scripts
Old 3rd June 2024, 22:06   #8  |  Link
smaiderman
Thank you both
