Old 1st June 2024, 01:59   #1  |  Link
smaiderman
Staxrip slower every second
Hi!
Im trying to encode an h265, and Im trying to determine how long I would like to wait.
I tried the slower preset and I gave me 24 hours ETA.
When trying the slow preset, it said 7 hours. Nice.
But as iI'm wathcing, the ETA gets longer every second.
Its been 7 minutes enconding, and it is now saying it will take 15 Hours and 30 mins.
Will it eventually give an accurate ETA? or is it a bug? thank you
smaiderman is offline   Reply With Quote
Old 1st June 2024, 18:49   #2  |  Link
Asmodian
Encoding speed is content dependent, so it can never be 100% accurate. However, as it encodes more of the video it tends to converge on a more accurate estimate. If the last bit of the video is very different (like credits, etc.) it can still change a lot even near the end.
It is not a bug, just normal progress bar behavior.
madVR options explained
Old 1st June 2024, 19:52   #3  |  Link
RanmaCanada
Slower is usually twice as slow as slow but as mentioned it also depends on the content. What kind of CPU do you have?
Old 3rd June 2024, 14:51   #4  |  Link
smaiderman
its a 5950X amd
I understand. Thank you
