Old 31st May 2024, 11:17   #1  |  Link
smaiderman
Limit CPU usage
Hello.
Is there a way to let some cpu cores free for other stuff?
I have a 5950X and rtx 3090 and I would like to be able to use the computer while it is encoding.
Im using StaxRip, but I cant find an option to limit the used threads.
I tried adding -threads 28 but it wont work, causing an error.
Thank you
smaiderman is offline   Reply With Quote
Old 1st June 2024, 00:50   #2  |  Link
benwaggoner
Normally you'd use "--threads" with two hyphens. What's the error message you're getting.
You can also use the --pools parameter to pin x264 to specific cores or NUMA nodes. This can be a big help on Intel, and might help a bit on AMD, as the OS can then put other tasks on unused nodes.
Ben Waggoner
My Compression Book
Old 1st June 2024, 01:55   #3  |  Link
smaiderman
The error is the program just crashing.
I used only one "-". Thank you
