21st August 2024, 18:21 | #941 | Link | |
21st August 2024, 22:19 | #942 | Link | |
The main thing DV does is dynamically adjust scene brightness, so if your RPU is out of sync with the base video layer you may see weird brightness changes slightly before or after scene cuts, depending on the scene of course. One way to check your remux is to extract the RPU from it using the Demuxer script, and then using the Fileinfo script on it. This gives you all the scene cut frames in the RPU, which you can then use to check if they match the actual video. I don't think the L6 data matters, if I remember correcrly that's what quietvoid said a while back in this thread. |
31st August 2024, 08:21 | #943 | Link | ||
Well that's confusing.
Ok...let's say I downloaded a DV Hybrid of a x265 rip and want to only save the DV layer that's already synced to a 4K UHD rip and inject it into a 4K UHD Remux. If the video is cropped but mine is standard 2160p, do I have to enable anything when saving the DV layer? It seems no matter what I select for Convert, or crop rpu it always says the RPU and Video don't match because of the video borders, but the file output says "match with video" Quote:
31st August 2024, 09:29 | #944 | Link |
The RPU contains border information for each frame, what's called L5 data. It doesn't matter if you change it when you are saving it using the demuxer or when injecting it using the injector. At the end of the day the L5 data of the injected RPU should match the borders of the video it's injected into.
In your example above, DDVT is telling you that the borders on the RPU (0) don't match the borders on the video (280), so it will rewrite the L5 data before injecting the RPU so that it matches the video. I generally save the RPU as is and apply necessary changes when injecting it. I suggest looking at dovi_tool's documentation, which is what DDVT uses. Hopefully that can clear things up. |
9th September 2024, 21:32 | #947 | Link | |
QfG Group Germany
Red: This is the section from your RPU with the discovered borders. Green: Your final settings for injecting with corrected borders in the RPU to match the HDR Stream
21st September 2024, 11:53 | #948 | Link |
Dolby Vision Metadata Extraction & Injection
I cannot work with a command prompt interface, but wish to use DDVT tools to extract and later inject the Dolby Vision metadata in my x265 encodes of 4k blu-rays. However, each time I start DDVT_DEMUXER.cmd, the cmd window flashes "waiting for 30 seconds, press a key to continue . . .". Thereafter, when I drag and drop the MKV file onto the DDVT_DEMUXER.cmd window, the cmd window instantly disappears. In fact, all the DDVT_XXX.cmd files, with the exception of DDVT_HYBRID.cmd and DDVT_OPTIONS.cmd, perform the same disappearing act after 30 seconds, or the moment when I drag and drop an MKV file onto the cmd window. Here's how the cmd window looks before disappearing:
I am unable to figure out exactly what it is that I might be doing wrong. Any help would be much appreciated. Thank you. |
21st September 2024, 13:58 | #949 | Link |
Elementary, dear Watson, elementary. Some wonderful, generous, and precisely articulated help in PMs provided the correct diagnosis. I should have dragged the mkv file over the DDVT_DEMUXER.cmd script. Instead, I was double clicking DDVT_DEMUXER.cmd and dragging the file on the cmd window that opened thereafter. That is the first step out of the way; now to the next. Many thanks for helping out.
22nd September 2024, 08:21 | #950 | Link |
I succeeded in getting my first Ripbot encode with Dolby Vision metadata, all thanks to the wonderfully generous forum members walking me through in PMs and, in the Ripbot forum, thanks to Ryushin. Once my elementary but fundamental mistake became clear, the rest was a cakewalk.
Ryushin and my PM-ing friends, much, much gratitude. |
27th September 2024, 09:08 | #952 | Link |
DDVT is for working with Dolby Vision metadata and adding it to HDR10 or extracting it. It can't do what you want. I'm not sure if anything can. HDR10 uses the 10-bit BT.2020 colorspace whereas SDR uses the BT.709 colorspace.
28th September 2024, 06:47 | #953 | Link |
Now that I have had the time to work with DDVT tools, I cannot be thankful enough: these scripts are exactly what so many of us had been missing since the introduction of Dolby Vision. Thank you so very much -QfG- and quietvoid (and that is a lovely nick!). You guys have done such awesome work that even an old dog like me, who has the will but no longer the energy to learn new tricks, can work effortlessly in extracting and injecting Dolby Vision into my encodes. Much, much gratitude for these incredibly useful and awesomely user-friendly batch scripts.
28th September 2024, 10:57 | #954 | Link | |
hdr10(not hdr10+) is not metadata? it's just have 10-bit BT.2020 colorspace |
28th September 2024, 20:16 | #955 | Link |
Technically speaking, it has some overall brightness metadata, but it is part of the whole HDR10 package, it's not something you can take out and put on an SDR video and call it a day. You can Google "how HDR works".
29th September 2024, 01:19 | #956 | Link | |
if i encode hdr10 file (SMPTE ST 2084) to h265 10 bits file why output file information is not show "SMPTE ST 2084" it's not hdr10? but color is like original file! |
29th September 2024, 03:42 | #958 | Link | |
i don't understand why output file color is like original file it should be waste out color? |
