12th March 2021, 23:10 | #1 | Link |
hevc-aq "production-ready"?
my current goal is to encode my bluray collection with x265 for easier inhouse streaming. Upon research for good baseline settings I stumbled across the "hevc-aq" option of x265. I could find a few sources stating that it is experimental and not suitable for "important" encodes yet. But it's been a while and it doesn't seem to be experimental anymore, but I also couldn't find any real world tests with it. So I decided to take a look myself. I extracted a 5 minute segment from an action movie bluray that contains fast paced action, slow camera movements, dark and bright scenes, landscape shots and close ups. I encoded it with different settings and the results where impressive:
Common settings for all encodes:
After wondering about the huge different in size I did a visual comparison and for me as an average movie watcher the hevc-aq encode looked just like the others. But I wanted to have numbers so I ran a VMAF (vmaf_float_v0.6.1) comparison:
As far as I understand VMAF, these are all really good results. Too good be the true. I mean it's less than 40% of the size/bitrate of the other encodes and still maintains a really high quality. Is there something I'm missing here? Known caveats I didn't notice with my test encode? ... I understand that there is no magic setting that makes all movies look great. Even though I'm currently wondering if I should use hevc-aq to encode my library or not? Out of curiousity I encoded the whole movie with the different settings:
13th March 2021, 01:55 | #2 | Link |
VMAF has been demonstrated to be poor at discriminating between subjective quality of adaptive quantization algorithms. You'd need to look at the samples to really know if the predictions have a good subjective correlation.
13th March 2021, 08:27 | #3 | Link |
Pig on the wing
If I remember correctly, hevc-aq removes quite a lot of details at least at the same CRF level. The reduction in bitrate is most likely a consequence.
13th March 2021, 11:55 | #4 | Link | ||
CRF 20, AQ-Mode 2: CRF 20, HEVC-AQ: Last edited by burban; 13th March 2021 at 12:06. |
14th March 2021, 03:25 | #5 | Link |
If you're encoding your own backup copies to make it easier, then the goal should be acceptable quality loss for size. If you can not see the difference, then that is literally all that matters, as you still have the originals on disc. That's my personal opinion on making a backup that is easier to stream throughout the house/cellphones/tablets. If you're going to backup everything and put it on a Plex/Emby/Jellyfin server, you can remux it and take up lots of space and have the server re-encode it every single time, or you can shrink them down with "acceptable quality loss" in an optimized format to make viewing easier.
In the end, all that matters is what is acceptable to you, as you will be the one watching them. |
15th March 2021, 09:55 | #6 | Link |
Broadcast Encoder
You can see the difference in the clouds and also in sharp edges.
If you take a close look at the top left portion of the screen, for instance, you can see a little bit of ringing when AQ is turned on, but most importantly, as soon as you get away from the edge and closer to the sky, the algorithm assumes that it's uniform and removes the original grain pattern: If we use the subtract function, we can see what AQ got rid off and we can easily see the grain pattern and also some sharp edges around the two main characters: Now, the reason why I'm telling you this is only 'cause you asked if AQ is production ready and hence my reply would be "no, I wouldn't use it the way it is for our customers", but let's be realistic here, we're not talking about high bitrate masterfiles being encoded for millions of VOD customers, we're talking about a user ripping UHD-BDs and re-encoding them for his personal archive to save space, so... you know what, if they look ok and worth it to you, it's fine as you're the only one who's gonna watch them + family and friends eventually, so it's fine. Objectively we can tell you what it does, but ultimately it's up to you. Precisely. It's his own personal backup, so if they're good for him, it's fine. |
15th March 2021, 17:24 | #7 | Link |
Yeah, optimal settings for a mezzanine are very different than for distribution.
Comparing AQ modes at different bitrates is also pretty fraught. I recommend comparing using 2-pass VBR, so you compare the same ABR and source with different AQ parameters. Maybe hevc-aq can give you the same quality at 20% lower bitrate, even if there are some regressions at less than half the bitrate. Could be that --hevc-aq means you can raise CRF by 2 or something. |
19th March 2021, 04:44 | #8 | Link | |
As benwaggoner suggested I'll experiment with CRF values a bit further. CRF18 with AQ on still reduces the file size by about 33% compared to CRF20 w/o AQ on my sample. If I really encode my whole 700+ disc collection that will be a significant storage saver. Alright, thanks for the clarification. I'll try 2-pass VBR encodes as soon as I got a bit of free time :-) |
15th February 2024, 13:46 | #11 | Link | |
Acid fr0g
I am curious anyway about the differences and case use of the 3,4,5 mode. I am currently using aq-mode 5 because it seems the "most complete" but do you have any suggestion about anime vs live action, grainy vs clean, fast motion vs slow motion to apply one of them?
@turment on Telegram |
15th February 2024, 20:26 | #12 | Link | |
Correct.
4 is probably better overall than the others, and benefits from a slightly lower --aq-strength in general. I've found grainy HDR can be better with 2. 5 isn't in MCW x265, so that'll depend on which build you're using and what it does there. |
15th February 2024, 20:48 | #13 | Link | |
Acid fr0g
What mode would you use with anime?
17th February 2024, 12:17 | #17 | Link |
I don't have a Mac and absolutely no knowledge on it...
But the code is on my github to build for those who know how to build for Mac. Sorry, mistake/mix on specific term. What i wanted to say it's indeed that several peoples said to not use on HDR a mode "with bias to dark scene", so 3 and 5.
My github. Last edited by jpsdr; 17th February 2024 at 12:23. |
18th February 2024, 11:13 | #19 | Link |
My advise would be to try auto-aq with hysteresis (i add the hysteresis to avoid a possible risk), and if for HDR, enable the HDR mode, so "--auto-aq 6" (bits 1 & 2 set to 1).
My github. |
18th February 2024, 13:42 | #20 | Link |
Pig on the wing
Edge biased are good to use, but luma biased ones are not (because they are pretty much counterproductive to --hdr10-opt). So modes 3 and 5 should not be used and as you mentioned, the auto mode 6 is the one for HDR.
