31st May 2021, 14:38 | #21 | Link |
Images are allowed! I can send you an example / small tut later.
31st May 2021, 15:01 | #22 | Link |
Look here is your html code + a image on github: https://thechaoscoder.github.io/pagestest/
Image url https://thechaoscoder.github.io/pagestest/unnamed.png I added a branch "homepage". You just choose this branch in your github repo settings and github will use it as the root folder to serve html pages. Repo: https://github.com/theChaosCoder/pag.../tree/homepage I will upload a short video later on how to do it. EDIT You could also stay on avisynth.nl but host only the images on github. Basically what zorr suggested with an external img hoster.
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 31st May 2021 at 15:14. |
31st May 2021, 23:13 | #23 | Link | |
And like Chaos said Github is also an option. But you just need to figure out what works best for you. |
4th June 2021, 10:35 | #24 | Link |
Took a bit longer but here's a quick how to setup github pages.
https://www.dropbox.com/s/q6ue2r2p8b...tpage.mp4?dl=0 or direct download link https://www.dropbox.com/s/q6ue2r2p8b...tpage.mp4?dl=1 * The "myhomepage" branch is optional, you could also just use "main". * I just found out you can even drag and drop a folder with all your images in the upload box thingy! * There a some good and free git GUIs like "GitHub Desktop" where you can clone, pull and push with just a mouse click. Editing in ScreenToGif is not the best experience
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 4th June 2021 at 10:39. |
6th July 2021, 21:41 | #25 | Link |
Some PNGs could be reduced in size with some PNG Optimizer - but 100MB eventually will be not enough
If you want something traditional, I could give you some space to host stuff - not using it myself, so what better use than to support such fine filters I would gladly help you out! |
17th July 2021, 10:28 | #27 | Link |
@vcmohan: Any hint in how to convert a defish(fov=114,scaling="fitxy") in an equivalent vcm.DeBarrel(..) call?
17th July 2021, 13:57 | #28 | Link |
I have not really thought about that. But may be try with a square sized frame and debarrel with relatively higher values for a and b. I am not sure it will work. I will try.
17th July 2021, 16:10 | #29 | Link | |
Cu Selur |
18th July 2021, 12:37 | #30 | Link |
The problem with the input is the center of frame is not the center of the fish eye. Need to correct for that first. As the fish eye looks like a circular photo, the value of c be 0.5 with a and b at zero. Sorry I misguided you. I also added borders on left, top, bottom and right for centering and for accommodating the corrected image. Finally I cropped to be equal to that of the defish_eye image seen in the link.
the script used is <code> ret = core.std.AddBorders(ret,left = 100, right = 100, top = 100, bottom = 740) ret = core.vcm.DeBarrel(ret,abc =[ 0.0, 0.0, 0.5],pin = 0) ret=core.std.Crop(ret,left = 60, right = 60, top = 40, bottom = 740) </code> |
18th July 2021, 14:07 | #32 | Link |
defish looks extremly cropped, is this normal?
18th July 2021, 14:22 | #34 | Link | ||
28th July 2021, 20:11 | #37 | Link |
I'm testing vcm.F1QLimit and noticed some oddities.
2nd August 2021, 13:27 | #38 | Link |
As my laptop was and still down since last week, I did not see this comment. It looks like the problem is in floating point and integer conversion. I will rectify It as soon as I get either a new battery pack for my laptop or buy a new one(Expensive)
29th August 2021, 00:19 | #39 | Link |
Pajas Mentales...
Hi seems the latyest source code fail build for me
In file included from vcm.cpp:79: F2Quiver.cpp:203:10: fatal error: hammingCodeInsert.cpp: No such file or directory 203 | #include "hammingCodeInsert.cpp" | ^~~~~~~~~~~~~~~~~~~~~~~ compilation terminated. |
29th August 2021, 13:24 | #40 | Link |
[QUOTE=zorr;1948668]I'm testing vcm.F1QLimit and noticed some oddities.[?QUOTE}
At last I could get most of data into my new laptop. The documentation for these two filters (F1QClean and F1QLimit) are revised. Please check now. Thanks for pointing out the errors. regards. @sl1pkn07: The missing file is inserted now. |
