3rd May 2008, 01:14 | #2043 | Link |
hi
thanks for your great program is it possible you you could put a cutting feature in your program so we could cut off the credits so we could fit the movie on a dvd5 thanks
nuff respect |
3rd May 2008, 08:01 | #2045 | Link | |
I think I know what the problem is, I use the hebrew regional settings and it didnt work before. The thing is when I changed the "Display leading zeros" from ".7" to "0.7" it statrted working I hope it helps, good day |
3rd May 2008, 09:13 | #2046 | Link |
hi
is it possible with your program to cut the credits from the movie with a movie like twister for example and put it on 1 dvd5 when i try your splitting feature it puts the 1st disc at 4.27gb if it used more of the dvd5 or if i could cut the credits some of the mkvs would fit your up there with great dvdshrink programmer maybe nero will steal u away aswell is there any site that hosts all your previous versions of your program thanks again
nuff respect |
3rd May 2008, 15:38 | #2047 | Link |
Error Getting MKV Info
I posted this a week ago and would really like some help! I'm not going to stop till I get your program to work I've tried it on numerous files and It won't work I get "Error Getting MKV Info" This is becoming very frustrating. Now when I use Tmuxer alone I have no problem with any files..I'm running Vista 32. Can someone at least suggest a solution?
Jeff |
3rd May 2008, 17:40 | #2048 | Link |
Same here Jeff. The program doesn't execute when I double-click on the "mkv2vob" shortcut, which actually refers to "loader.exe" file. Nothing happens and I'm suspecting this is a dormant (trojan) virus or some malignant form of spy/mal-ware. So instead I execute the "mkv2vob.exe" file and it works but I'm getting the same "Error Getting MKV Info" problem you're having whenever I load up an MKV file.
3rd May 2008, 21:14 | #2049 | Link |
Well I hope someone can tell us why the program won't work why we keep getting this error. Like I said TMuxer is no problem at all,but I really want to use this program..Thanks for validating my problem......Jeff
4th May 2008, 10:58 | #2053 | Link |
3r1c,
Would it be possible to implement an ABORT button in the main program window that would kill all processes so that if I decide I want to NOT continue I can quit the process easily (right now you have to use Task Manager to kill all the individual processes). Also, would it be possible to implement some way of notifying the users PRIOR TO starting the process that a particular MKV is going to need to be transcoded? At times if a movie needs to be transcoded I just assume not do so and move on to something else. Aside from these two points, so far this application has worked wonderfully! Thank you very much. |
4th May 2008, 11:53 | #2054 | Link | |
and an esteminated time that the transcode process need would be great as well. And a question to all. What is faster for transcoding? Windows XP (32bit) Windows Vista 32bit or 64bit? And what performanceboost would I have if I sell my AMD x2 BE-2350 and buy a Quad Core either an AMD or an Intel Q9300/Q9450 ... take the transcode process advantage of the 4 cores and the L2 Memory? |
4th May 2008, 12:43 | #2055 | Link |
Hello,
I wanted to say i love this program. I can finally see my MKVs on my PS3. This prog is so cool !! But i've an issue with two files. The last version resolves one files but i've always a problem with the other. I've a MKV with these specs : General #0 Complete name : E:\Next.2007.1080p.HDDVD.x264.VO-VF.mkv Format : Matroska File size : 8.37 GiB PlayTime : 1h 36mn Bit rate : 12.5 Mbps Encoded date : UTC 2008-04-03 19:14:08 Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video #0 Codec : AVC Codec/Family : AVC Codec/Info : Advanced Video Codec Codec profile : High@L5.1 Codec settings, CABAC : Yes Codec_Settings_RefFrames : 8 PlayTime : 1h 36mn Bit rate : 10.7 Mbps Width : 1920 pixels Height : 800 pixels Display Aspect ratio : 2.400 Frame rate : 23.976 fps Chroma : 4:2:0 Interlacement : Progressive Title : Next (2007) Language : English Audio #0 Codec : AC3 PlayTime : 1h 36mn Bit rate mode : CBR Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Rear: L R, LFE Sampling rate : 48.0 KHz Title : AC3 5.1 640 Kb/s Language : English Audio #1 Codec : AC3 PlayTime : 1h 36mn Bit rate mode : CBR Bit rate : 640 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Rear: L R, LFE Sampling rate : 48.0 KHz Language : French Text #0 Codec : SSA Codec/Info : Sub Station Alpha Language : English Text #1 Codec : SSA Codec/Info : Sub Station Alpha Language : French When i use MKV2VOB. It transcodes the video into MPEG2 and tell me the conversion was successfull. But when i play it on the PS3, it doesn't work. I've a black screen, it seems to recognize the AC3 stream but not the MPEG2 stream. But nothing is played. I've also tested to transcode into x264 but the problem is the same. On my PC the VOB plays correctly. |
5th May 2008, 00:57 | #2056 | Link | |
The first thing i can sugest on trying here is to remove part of the movie. Say the end credits or maybe the Title sequence at the beginning. I have had a similar problem with 720p, 1080p, DTS and non-DTS tracks and for some rason when i chop a few seconds off or in the case of Equilibrium (search the thread) we had to chop the first 31secs (title stuff) and it all worked ok. As to why you need to do this i', not sure and maybe one of the other guys could answer that. Cheers |
5th May 2008, 01:00 | #2057 | Link | |
5th May 2008, 01:47 | #2058 | Link | |
Curious. The mkv files I generate using Handbrake are done so by selecting the 5.1 track from my DVD source and then have it "passthrough". The result is a high-quality 5.1 audio mkv file with the video compression only slightly increased. The files are playable using VLC and possibly other media players but mkv2vob is needed for PS3 compatibility. No transcoding is required.
5th May 2008, 02:56 | #2059 | Link |
3r1c thanks so much for the program!
I was wondering if there have been any developments with the installations problems? I have read all 103 pages just to find an answer and did not find any thing other than redownload and install. I have two computers and one seems to install it fine while the other gives me problems( they both run xp however one has service pack 2 and the other has service pack 3( this is one I am having the problem with)). I also read what you said about bootleg versions of windows. Also other programs seems to work ie mkvextract, h264info, tsmuxer and of course I haven't had any problems installing anything else. If you have any ideas they would be greatly appreciated btw the error that i am getting when I try to install is this is not a valid win 32 application, I think it might just be a installation conflict with service pack 3. Can anyone verify that they are using xp pro w/ service pack 3 and mkv2vob? |
5th May 2008, 03:24 | #2060 | Link | |
here is what happens. loader.exe starts, it immediately runs mkv2vob.exe and continues in the background to check for updates. mkv2vob.exe runs other tools such as mkvinfo.exe which you are getting errors. something is preventing these program executions from working, possibly some kind of antivirus. can you try download this http://www.microsoft.com/downloads/d...displaylang=en it should be in included in windows xp, but its the only thing i can think of. Last edited by 3r1c; 5th May 2008 at 03:35. |
