24th February 2022, 17:20 | #1902 | Link | |
I did some benchmarks and reached to that conclusion, but I will rerun them to be sure. These kind of things show up with big filters like QTGMC.
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread Last edited by Dogway; 24th February 2022 at 17:22. |
25th February 2022, 00:44 | #1903 | Link | |||
25th February 2022, 01:11 | #1904 | Link |
Full range gives me 136 .0 with:
ConvertBits(8,fulls=false,fulld=true)
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
25th February 2022, 01:37 | #1905 | Link | |
Unless this is specific to levels, only 8bit 255 is correct and I'm not sure about 255/256 or any of the other 32-bit numbers. |
25th February 2022, 02:23 | #1906 | Link |
I always use n/255 for 32-bit float. You can check my list in ex_dlut().
As you see it depends on clip range. This chart assumes legal range for the values so I guess for Levels() this would have something to do with 'coring'. In my opinion you should set coring to false and treat the clip as full range. The last column seems correct, it's the maximum permitted video signal value for either limited or full range.
25th February 2022, 03:26 | #1907 | Link |
Side announcement/notifications:
x264 had been using AvxSynth on Linux and macOS for a little over nine years (2013-Feb-12). Unlike FFmpeg, x264 ships a local copy of the avisynth_c.h header, so it's much more likely for the average distro's x264 package to just start working with a user's self-built AviSynth+ install, once they catch up to where x264-git is (and assuming they aren't disabling it because users don't understand how the input module selector works and complained about it failing even though it was working as expected). The FFmpeg patches mean that the relevant frame properties (_FieldBased, _Matrix, _ChromaLocation, _Primaries, _Transfer, and _ColorRange) can now be passed through to the output, if the output format supports setting those properties for itself from what FFmpeg reports (HEVC encoding through libx265 does), and libavformat-based decoding has the ability to see those properties and programs using that information can then take appropriate action. mpv, for instance, can now use its autotonemapping for HDR content served through an AviSynth script. Requires a new enough build of FFMS2 or LSMASHSource to populate those properties when opening the source video, as well as AviSynth+ 3.7.1 for libavformat to try reading the frameprops. |
25th February 2022, 03:32 | #1908 | Link |
What I mean by the ffmpeg stuff:
The avs script: Code:
FFmpegSource2("LG New York HDR UHD 4K Demo.ts",atrack=-1) Spline64Resize(1280,720) Code:
$ ffmpeg -i test_hdr.avs ffmpeg version N-105655-ge4ad38d0f7-6ubuntu5 Copyright (c) 2000-2022 the FFmpeg developers built with gcc 11 (Ubuntu 11.2.0-7ubuntu2) configuration: --prefix=/usr --extra-version=6ubuntu5 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --enable-debug --disable-stripping --enable-version3 --enable-mbedtls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libplacebo --enable-libpulse --enable-librabbitmq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-nvenc --enable-chromaprint --enable-frei0r --enable-libx264 --enable-avisynth --enable-vapoursynth --cpu=skylake --extra-cflags='-march=skylake' --extra-ldflags=-pthread --pkg-config-flags=--static libavutil 57. 21.100 / 57. 21.100 libavcodec 59. 21.100 / 59. 21.100 libavformat 59. 17.102 / 59. 17.102 libavdevice 59. 5.100 / 59. 5.100 libavfilter 8. 27.100 / 8. 27.100 libswscale 6. 5.100 / 6. 5.100 libswresample 4. 4.100 / 4. 4.100 libpostproc 56. 4.100 / 56. 4.100 Guessed Channel Layout for Input Stream #0.1 : stereo Input #0, avisynth, from 'test_hdr.avs': Duration: 00:01:12.24, start: 0.000000, bitrate: 0 kb/s Stream #0:0: Video: rawvideo (Y3[11][10] / 0xA0B3359), yuv420p10le(bottom first), 1280x720, 25 fps, 25 tbr, 25 tbn Stream #0:1: Audio: pcm_f32le, 48000 Hz, stereo, flt, 3072 kb/s At least one output file must be specified Code:
$ ffmpeg -i test_hdr.avs ffmpeg version N-105655-ge4ad38d0f7-6ubuntu5 Copyright (c) 2000-2022 the FFmpeg developers built with gcc 11 (Ubuntu 11.2.0-7ubuntu2) configuration: --prefix=/usr --extra-version=6ubuntu5 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --enable-debug --disable-stripping --enable-version3 --enable-mbedtls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libplacebo --enable-libpulse --enable-librabbitmq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-nvenc --enable-chromaprint --enable-frei0r --enable-libx264 --enable-avisynth --enable-vapoursynth --cpu=skylake --extra-cflags='-march=skylake' --extra-ldflags=-pthread --pkg-config-flags=--static libavutil 57. 21.100 / 57. 21.100 libavcodec 59. 21.100 / 59. 21.100 libavformat 59. 17.102 / 59. 17.102 libavdevice 59. 5.100 / 59. 5.100 libavfilter 8. 27.100 / 8. 27.100 libswscale 6. 5.100 / 6. 5.100 libswresample 4. 4.100 / 4. 4.100 libpostproc 56. 4.100 / 56. 4.100 Guessed Channel Layout for Input Stream #0.1 : stereo Input #0, avisynth, from 'test_hdr.avs': Duration: 00:01:12.24, start: 0.000000, bitrate: 0 kb/s Stream #0:0: Video: rawvideo (Y3[11][10] / 0xA0B3359), yuv420p10le(tv, bt2020nc/bt2020/smpte2084, progressive), 1280x720, 25 fps, 25 tbr, 25 tbn Stream #0:1: Audio: pcm_f32le, 48000 Hz, stereo, flt, 3072 kb/s At least one output file must be specified before: Code:
Stream #0:0: Video: rawvideo (Y3[11][10] / 0xA0B3359), yuv420p10le(bottom first), 1280x720, 25 fps, 25 tbr, 25 tbn Code:
Stream #0:0: Video: rawvideo (Y3[11][10] / 0xA0B3359), yuv420p10le(tv, bt2020nc/bt2020/smpte2084, progressive), 1280x720, 25 fps, 25 tbr, 25 tbn |
25th February 2022, 09:53 | #1909 | Link | ||
Broadcast Encoder
'cause I noticed that when I use: propclearall() in Avisynth, FFMpeg gets bogus properties, but it's not like before, like it used to be. I expected propclearall() to clear all frame properties and therefore make FFMpeg behave like it used be, but it doesn't, that only works from the Avisynth point of view, but now instead of not passing any properties it's passing the WRONG properties, which is even worse. On the other hand, I can't make use of frame properties in any way in Avisynth and make sure that everything is always correct 'cause many filters just don't modify them, so I end up with the wrong properties anyway, hence the propclearall(). As I stated in the other topic, I very much believe that there should be a way, like a command, in FFMpeg to disable frame properties and go back to the way it was before. This way, users can decide whether to use them or not. On the Avisynth side we have propclearall() which has been my most used function and I've spread it everywhere in every script I made, but now we need something on the FFMpeg side to instruct it not to read any of what Avisynth is passing. The reason why I've been so keen on insisting on this is that I've got lots of issues with some workflows that have been working for years and then stopped due to frame properties (like the top left chroma location thingy for XDCAM-50, remember?). In this very moment in time it's much much better not to have frame properties than to have them for me. |
25th February 2022, 20:53 | #1910 | Link | |
st->codecpar->field_order = AV_FIELD_UNKNOWN st->codecpar->color_range = AVCOL_RANGE_UNSPECIFIED st->codecpar->color_primaries = AVCOL_PRI_UNSPECIFIED st->codecpar->color_trc = AVCOL_TRC_UNSPECIFIED st->codecpar->color_space = AVCOL_SPC_UNSPECIFIED st->codecpar->chroma_location = AVCHROMA_LOC_UNSPECIFIED What it seems is happening, is that propDelete and propClearAll either remove the value, or set the value to 0 and treat that as implicitly having removed it. The problem is that the enums that set those properties consider 0 a valid number or somehow interpret the missing value to be equivalent to the value being 0. Which means it selects `case 0` instead of the default UNSPECIFIED case. These are the values for `case 0`: Code:
st->codecpar->field_order = AV_FIELD_PROGRESSIVE st->codecpar->color_range = AVCOL_RANGE_JPEG st->codecpar->color_space = AVCOL_SPC_RGB st->codecpar->chroma_location = AVCHROMA_LOC_LEFT All the charts have a specific number of options corresponding to the cases in the switcher: _FieldBased has three (0-2) _ColorRange has two (0, 1) _Primaries has twelve (1, 2, 4-12, 22) _Transfer has seventeen (1, 2, 4-18) _Matrix has fourteen (0-2, 4-14) _ChromaLocation has six (0-5) What am I getting at here? Well, if you happen to set a value for one of those properties to a number which does not coincide with one of the cases, it falls back to UNSPECIFIED, which would be the same as pre-frameprop treatment behavior. So a safe value for all of them could be, say, -1. Or one way outside the boundaries, like 100. Or for _Primaries, _Transfer, and _Matrix, 3. Does propClearAll actually remove the value entirely (propShow would imply that it does), or just set it to 0? Does FFmpeg (or more precisely, the compiler or C language itself) interpret the absense of a value to be equivalent to 0 when dealing with the switch-case? I have no clue. Those are areas that need to be explored when trying to figure it out, but what this does uncover is simple: if you want it to go back to how it was before, just use a function like this: Code:
function propUnsetAll(clip c) { c.propClearAll() last.propSet("_FieldBased",-1) last.propSet("_ColorRange",-1) last.propSet("_Primaries",-1) last.propSet("_Transfer",-1) last.propSet("_Matrix",-1) last.propSet("_ChromaLocation",-1) return last } Code:
Import("../propunset.avsi") FFmpegSource2("LG New York HDR UHD 4K Demo.ts",atrack=-1) Spline64Resize(1280,720) propUnsetAll() Code:
ffmpeg version N-105655-ge4ad38d0f7-6ubuntu5 Copyright (c) 2000-2022 the FFmpeg developers built with gcc 11 (Ubuntu 11.2.0-7ubuntu2) configuration: --prefix=/usr --extra-version=6ubuntu5 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --enable-debug --disable-stripping --enable-version3 --enable-mbedtls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libplacebo --enable-libpulse --enable-librabbitmq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-nvenc --enable-chromaprint --enable-frei0r --enable-libx264 --enable-avisynth --enable-vapoursynth --cpu=skylake --extra-cflags='-march=skylake' --extra-ldflags=-pthread --pkg-config-flags=--static libavutil 57. 21.100 / 57. 21.100 libavcodec 59. 21.100 / 59. 21.100 libavformat 59. 17.102 / 59. 17.102 libavdevice 59. 5.100 / 59. 5.100 libavfilter 8. 27.100 / 8. 27.100 libswscale 6. 5.100 / 6. 5.100 libswresample 4. 4.100 / 4. 4.100 libpostproc 56. 4.100 / 56. 4.100 Guessed Channel Layout for Input Stream #0.1 : stereo Input #0, avisynth, from '/home/qyot27/Videos/test_hdr.avs': Duration: 00:01:12.24, start: 0.000000, bitrate: 0 kb/s Stream #0:0: Video: rawvideo (Y3[11][10] / 0xA0B3359), yuv420p10le, 1280x720, 25 fps, 25 tbr, 25 tbn Stream #0:1: Audio: pcm_f32le, 48000 Hz, stereo, flt, 3072 kb/s At least one output file must be specified Code:
AviSynth+ native Linux/macOS/BSD support | AviSynth+ utilities and plugins for non-Windows and non-x86(-64) Last edited by qyot27; 25th February 2022 at 21:05. |
26th February 2022, 00:02 | #1911 | Link |
Broadcast Encoder
Ahhhh, I get it now!
So that's why it didn't go back to unspecified when I was trying! Setting them all to -1 is indeed a nice trick. I'm gonna try to play with it on Monday as I get back to work, but I'm sure it's gonna work 'cause you already tried eheheheh. It's incredible that I've never thought about setting them to impossible values! Thanks for the tip, Stephen!! |
26th February 2022, 05:07 | #1912 | Link |
It certainly needs to be documented in a table, considering that it required taking a dive into FFmpeg's source code to even figure out what the entries in, to quote, "[X] as specified in ITU-T H.265 Table E.[Y]" were, and then compare it to the VapourSynth documentation on Resize to make sure they were using the same values.
Just so it actually is somewhere, here you go, in table form: Code:
+---------------------------------------+ | _FieldBased | +------------------+--------------------+ | Value | Meaning | +------------------+--------------------+ | 0 | Progressive | +------------------+--------------------+ | 1 | Bottom field first | +------------------+--------------------+ | 2 | Top field first | +------------------+--------------------+ | All other values | Unknown / unset | +------------------+--------------------+ Code:
+-----------------------------------------------+ | _ColorRange | +------------------+----------------------------+ | Value | Meaning | +------------------+----------------------------+ | 0 | Full range, a.k.a. JPEG | +------------------+----------------------------+ | 1 | Limited range, a.k.a. MPEG | +------------------+----------------------------+ | All other values | Unknown / unset | +------------------+----------------------------+ Code:
+------------------------------------+ | _Primaries | +------------------+-----------------+ | Value | Meaning | +------------------+-----------------+ | 1 | BT709 | +------------------+-----------------+ | 2 | Unspecified | +------------------+-----------------+ | 4 | BT470M | +------------------+-----------------+ | 5 | BT470BG | +------------------+-----------------+ | 6 | SMPTE170M | +------------------+-----------------+ | 7 | SMPTE240M | +------------------+-----------------+ | 8 | FILM | +------------------+-----------------+ | 9 | BT2020 | +------------------+-----------------+ | 10 | SMPTE428 | +------------------+-----------------+ | 11 | SMPTE431 | +------------------+-----------------+ | 12 | SMPTE432 | +------------------+-----------------+ | 22 | EBU3213 | +------------------+-----------------+ | All other values | Unknown / unset | +------------------+-----------------+ Code:
+------------------------------------+ | _Transfer | +------------------+-----------------+ | Value | Meaning | +------------------+-----------------+ | 1 | BT709 | +------------------+-----------------+ | 2 | Unspecified | +------------------+-----------------+ | 4 | GAMMA22 | +------------------+-----------------+ | 5 | GAMMA28 | +------------------+-----------------+ | 6 | SMPTE170M | +------------------+-----------------+ | 7 | SMPTE240M | +------------------+-----------------+ | 8 | LINEAR | +------------------+-----------------+ | 9 | LOG | +------------------+-----------------+ | 10 | LOG_SQRT | +------------------+-----------------+ | 11 | IEC61966_2_4 | +------------------+-----------------+ | 12 | BT1361_ECG | +------------------+-----------------+ | 13 | IEC61966_2_1 | +------------------+-----------------+ | 14 | BT2020_10 | +------------------+-----------------+ | 15 | BT2020_12 | +------------------+-----------------+ | 16 | SMPTE2084 | +------------------+-----------------+ | 17 | SMPTE428 | +------------------+-----------------+ | 18 | ARIB_STD_B67 | +------------------+-----------------+ | All other values | Unknown / unset | +------------------+-----------------+ Code:
+---------------------------------------+ | _Matrix | +------------------+--------------------+ | Value | Meaning | +------------------+--------------------+ | 0 | RGB | +------------------+--------------------+ | 1 | BT709 | +------------------+--------------------+ | 2 | Unspecified | +------------------+--------------------+ | 4 | FCC | +------------------+--------------------+ | 5 | BT470BG | +------------------+--------------------+ | 6 | SMPTE170M | +------------------+--------------------+ | 7 | SMPTE240M | +------------------+--------------------+ | 8 | YCGCO | +------------------+--------------------+ | 9 | BT2020_NCL | +------------------+--------------------+ | 10 | BT2020_CL | +------------------+--------------------+ | 11 | SMPTE2085 | +------------------+--------------------+ | 12 | CHROMA_DERIVED_NCL | +------------------+--------------------+ | 13 | CHROMA_DERIVED_CL | +------------------+--------------------+ | 14 | ICTCP | +------------------+--------------------+ | All other values | Unknown / unset | +------------------+--------------------+ Code:
+------------------------------------+ | _ChromaLocation | +------------------+-----------------+ | Value | Meaning | +------------------+-----------------+ | 0 | LEFT | +------------------+-----------------+ | 1 | CENTER | +------------------+-----------------+ | 2 | TOPLEFT | +------------------+-----------------+ | 3 | TOP | +------------------+-----------------+ | 4 | BOTTOMLEFT | +------------------+-----------------+ | 5 | BOTTOM | +------------------+-----------------+ | All other values | Unknown / unset | +------------------+-----------------+ |
26th February 2022, 10:12 | #1913 | Link | |
Avisynth and other plugin developers who use frame properties should agree on a consistent standard. Without the user having to assign a value to the properties themselves if they don't want to use them or delete them. If everyone agrees that -1 is unspecified, then it would probably work.
Live and let live Last edited by gispos; 26th February 2022 at 10:24. |
26th February 2022, 11:26 | #1914 | Link |
Some properties have no "Unspecified" value, such as _ColorRange: 0, 1, or does not exist at all. |
26th February 2022, 12:19 | #1916 | Link | ||
edit: left the post in edit for about an hour and did not notice pinterf's reply. Quote:
But yes, I agree they need to be documented and formatted nicely. Once I get done with the internal filters rst docs I'll move onto the syntax portion and will include this info there. Hopefully by summer time Last edited by Reel.Deel; 26th February 2022 at 12:27. |
26th February 2022, 13:40 | #1918 | Link |
Pig on the wing
I agree with that idea, just a little cumbersome as of now. I always thought propClearAll deletes properties, but apparently a propDeleteAll would be very useful for backward compatibility cases.
26th February 2022, 18:29 | #1919 | Link | |
"All (developers) should agree on a standard" and there the value -1 would be useful. If now -1 would be considered as not existing, there would be no problems here.
Live and let live |
26th February 2022, 22:24 | #1920 | Link |
Formerly davidh*****
I tried PropClearAll and sure enough, no properties. All deleted. PropShow shows nothing and my own program, assuming I've written it correctly which I think I have, shows nothing.
If ffmpeg is getting spurious values from somewhere, is that not an ffmpeg problem? |
