15th November 2022, 14:35 | #2181 | Link | |
15th November 2022, 15:17 | #2182 | Link | |
15th November 2022, 17:42 | #2184 | Link | |
Is this wrong? Either way I think this CUDA/whatever problem is not intended behavior so a fix would probably be nice to have. I guess it's possible that the problem is in some of the plugin code elsewhere, like accidentally overwriting some property due to overflow or bad pointer handling, but I wouldn't even know where to start looking since I don't understand the feature. I'm also not the original author of the plugin, I just made changes. |
15th November 2022, 17:47 | #2185 | Link |
Probably best to use AvisynthPluginInit3 when using AviSynth 2.6/AviSynth+ headers.
See here: https://github.com/pinterf/TNLMeans/...1556f25441502a |
23rd November 2022, 14:42 | #2186 | Link | |
https://gitlab.com/uvz/AviSynthPlus-Builds |
3rd December 2022, 16:08 | #2187 | Link |
Since Avisynth 3.7.3 or the extra builds from GS (https://gitlab.com/uvz/AviSynthPlus-Builds) I get error messages every now and then that are not present in Avisynth 3.7.2
Either no clip can be created (without error message) or the error message 'Function not found' appears (v3.7.3). And in both cases: If the same script is loaded again, no error occurs. If I go back to 3.7.2 everything is fine again. I load some dll's and scripts via an avsi, has anything changed in the plugin loading order?
Live and let live Last edited by gispos; 3rd December 2022 at 16:23. |
3rd December 2022, 23:36 | #2188 | Link |
Yeah I decided to test the test build as well and just got nothing out the other end, I don't think test builds should be that broken
Basically an alpha, so I wasn't concerned and just went back to 3.7.2 as well, figuring something so broken would be identified soon enough. Clang build wasn't any better either. |
4th December 2022, 15:56 | #2189 | Link | |
I would like to provide more detailed information, but it is completely random and also not so often.
Live and let live |
4th December 2022, 17:05 | #2190 | Link |
Banana User
Report: I still had no issues with Avisynth+ 3.7.3 test 2 (20221114)
InpaintDelogo, DoomDelogo, JerkyWEB Fixer, Standalone Faster-Whisper - AI subtitling |
5th December 2022, 04:51 | #2191 | Link | |
For the people having issues, post your script(s) maybe some clues there |
19th December 2022, 20:17 | #2192 | Link |
Since I changed my avsi file to load my filters and dll's, there have been no problems with Avisynth 3.73 so far.
Before everything was listed randomly, now I load all dll's first and only then the scripts. Something must have changed because 3.72 had no problems with the mixed loading order. As long as it works now all is good.
Live and let live |
18th January 2023, 15:59 | #2193 | Link |
Happy New Year!
Let's start the year with some cosmetic and other changes and fixes in "Text" filter: Avisynth+ 3.7.3 test 3 (20230118) Code:
- Fix: "Text" filter negative x or y coordinates (e.g. 0 instead of -1) - Fix: "Text" filter would omit last character when x<0 - Fix: "Text" halo_color needs only MSB=$FF and not the exact $FF000000 constant for fade - "Text" ``halo_color`` allows to have both halo and shaded background - "Text" much nicer rendering of subsampled formats |
18th January 2023, 17:34 | #2195 | Link |
Also, 32-bit AviSynth+ now supports non-decorated export names in C-plugins. This is something that was missing since the beginning of avs+.
By the way, this is how the Text filter on YUV420 looks like now, and how it used to look. New Old Last edited by Reel.Deel; 18th January 2023 at 17:55. |
18th January 2023, 20:04 | #2196 | Link |
Big Bit Savings Now !
Ah, welcome back, Ferenc !
(Was trying uvx 3825 and both 32 and 64 bit failed instantly...)
18th January 2023, 20:08 | #2197 | Link |
Welcome home P, and Happy New Year to U 2.
18th January 2023, 21:08 | #2198 | Link | |
Where is the Text filter in wiki?
I get error trying to use "Arial" as the font. Quote:
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
18th January 2023, 21:16 | #2199 | Link | |
Text, is meant for bdf fonts. It comes with "Terminus" (available in different sizes) and "Info.h" that is a fixed dimension. --- PS, if someone wants to update the wiki, go for it. Updating the actual avs docs was a large task, and I don't feel like doing double work . |
19th January 2023, 01:38 | #2200 | Link | |
