Old 18th May 2019, 00:54   #3361  |  Link
aldix
think i've almost everything fixed and set up now the way i need to. sorry about being so dense.
i'm still struggling with core.std.Interleave tho. what's the correct way using it?
i'm getting
vapoursynth.Error: Interleave: the clips' formats don't match
using:
src = core.fmtc.resample(clip,w=1280,h=720, kernel="blackmanminlobe", taps=4)
video = core.f3kdb.Deband(video,sample_mode=2,dynamic_grain=False,keep_tv_range=False,dither_algo=3,output_depth=8,y=48,cb=48,cr=48,grainy=48,grainc=48)
int = core.std.Interleave(clips=[src,video])
int.set_output()
and both are 1280/720.
aldix is offline   Reply With Quote
Old 18th May 2019, 02:11   #3362  |  Link
_Al_
resolution is not enough, comment out that interleave line and add:
src = src.text.ClipInfo()
src.set_output()
to see parameters of that clip and then delete those two lines and add other clip:
video = video.text.ClipInfo()
video.set_output()
_Al_ is offline   Reply With Quote
Old 18th May 2019, 02:25   #3363  |  Link
aldix
| Format: YUV420P16
Format: YUV420P8
hmm, so src clip is 16-bit and filtered is 8? but how do i change the src clip to 8-bit right at the beginning?
and will it mess all the rest up again, or what?
Old 18th May 2019, 02:41   #3364  |  Link
_Al_
don't know , you can change it right after loading src source or just before interleaving
src = core.resize.Bicubic(src, format = vs.YUV420P8)
Old 18th May 2019, 02:51   #3365  |  Link
aldix
think i fixed it with these changes.
src = core.fmtc.resample(clip,w=1280,h=720, kernel="blackmanminlobe", taps=4,css=420)
src = core.fmtc.bitdepth(clip,bits=8,dmode=1)
at least the script runs now. but, um, when i initiate the preview, i've no idea which frames from which i'm looking at?
too used to moving back and forth with keyboard arrows with the regular interleave. what's the how-to here?
Old 18th May 2019, 02:54   #3366  |  Link
aldix
hmm, never mind.
think it does work the same way, though. just the changes are too negligible with finesharp. oh well.
gotta try to get seesaw to work now
Old 18th May 2019, 03:04   #3367  |  Link
_Al_
You could switch to zimg - Vapoursynth's resize, like in my example, that changes resolutions, color spaces and much more. fmtconv is another way to do it though. Zimg is written by myrsloik I think so I'm sure it sits well within Vapoursynth.
Old 18th May 2019, 04:28   #3368  |  Link
edcrfv94
Will vivtc.VFM support ovr text file like tivtc?
edcrfv94 is offline   Reply With Quote
Old 24th May 2019, 04:05   #3369  |  Link
_Al_
If anyone can answer,
why there is kernel or resize method set as resize attribute and not just an argument in core.resize ?
example: clip = core.resize(clip, kernel = Bicubic, ......)
Old 24th May 2019, 11:03   #3370  |  Link
DJATOM
DJATOM's Avatar
Something like that will work:
resizer = {
    'bicubic': core.resize.Bicubic,
    'bilinear': core.resize.Bilinear,
    'spline36': core.resize.Spline36,
    'spline16': core.resize.Spline16
clip = resizer['bicubic'](clip, 960, 540, format=vs.YUV420P8)
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 24th May 2019, 15:16   #3371  |  Link
_Al_
I meant why is that, if author wanted that to look more like Avisynth command, to keep a pattern. Not that it matters.
That example is cool, yes tables with dictionaries, tuples, lists, that's the way to go. :-).
Or checking if kernel exists might be done by checking if it exists as a resize attribute:
my_cool_function(clip, kernel='Bicubic', miracle_settings=True)
try:
     getattr(vs.core.resize, kernel)
except:
      print("Wrong kernel")
edit: fixed missing quotes , because that's the whole point in this example with getattr , getting an object from a string name
Old 26th May 2019, 02:21   #3372  |  Link
aldix
ok, i'm back again so please bear with me here.
maskstars=src.mt_binarize(upper=false)
mt_merge(last,maskstars)
so i went ahead and tried
maskstars = core.std.Binarize(src,threshold=0)
video = core.std.Merge(video,maskstars)
but think i'm doing something wrong, cos "threshold=0" doesn't seem to equal "upper=false" for video picture changes color in weird ways etc. so how should i use the vs binarize? is it even what i'm after here?
merge seems to be mt_merge, though, so at least that is straightforward.
z = 2 # z = zero point
p = 0.9 # p = power
str = 0.9 # str = strength
rad = 1.0 # radius for "gauss"
o = last
g = o.bicubicresize(round(o.width()/rad/4)*4,round(o.height()/rad/4)*4).bicubicresize(o.width(),o.height(),1,0)
mt_lutxy(o,g,"x x y - abs "+string(z)+" / 1 "+string(p)+" / ^ "+string(z)+" * "+string(str)+" * x y - x y - abs 0.001 + / * +",U=2,V=2)
still don't know what to do with ^. as much as i googled, there seems to be some alternative for mt_lutxy under vs, but not like i'd know how to use it.
the resize can be done with core.std.resize etc i suppose. as far as the following calculation goes though, i've no idea. as much as i can recall, this
script snippet is something Didee wrote ages ago (if that helps any).
thanks!
Old 26th May 2019, 18:18   #3373  |  Link
WolframRhodium
in AVS is equivalent to
maskstars=src.std.Binarize(threshold=128+1, planes=[0])
in Vapoursynth.
The equivalent in std.Expr() is "pow".
It could be implemented through std.Lut2() or std.Expr(). The semantics of the later one is more close to mt_lutxy(), e.g.
core.std.Expr([o, g], [f"x x y - abs {z} / 1 {p} / pow {z} * {strength} * x y - x y - abs 0.001 + / * +", ""])
Avisynth functions and their VapourSynth equivalents may be helpful to you.
WolframRhodium is offline   Reply With Quote
Old 27th May 2019, 02:13   #3374  |  Link
aldix
in Vapoursynth.
awesome! thank you so much, i've the maskstars part sorted now.
how would i write this in vs though? with a bunch of different core.resize.Bicubic calls or what? hmm, and what's the equivalent in vs for "round" and "rad"?
thanks a lot in any case. really loving the community here!
Old 27th May 2019, 03:19   #3375  |  Link
WolframRhodium
g = o.resize.Bicubic(round(o.width/rad/4)*4, round(o.height/rad/4)*4).resize.Bicubic(o.width, o.height, filter_param_a=1, filter_param_b=0)
"rad" is a variable in your code,
(Actually "round" should be implemented like this)
_round = lambda x: -int(-x+0.5) if x < 0 else int(x+0.5)
g = o.resize.Bicubic(_round(o.width/rad/4)*4, _round(o.height/rad/4)*4).resize.Bicubic(o.width, o.height, filter_param_a=1, filter_param_b=0)
Old 28th May 2019, 02:58   #3376  |  Link
aldix
thank you so very much!! yes! this works.
and now i've whole of my old avs script working!
Old 28th May 2019, 13:01   #3377  |  Link
bjoker
Python exception: No attribute with the name ffms2 exists. Did you mistype a plugin n
Could anyone please advise on how to link ffms2 plugin to VapourSynth on Ubuntu linux? As there is no VapourSynth FATPACK for linux i had to compile/build ffms2. Please see below and advise, thanks!
vspipe /root/MyMovie.vpy - --y4m | x265 --crf 22 --preset slow --output-depth 10 --ctu 32 --max-tu-size 16 --analysis-reuse-level 8 --no-rect --b-intra --aq-mode 3 --subme 5 --merange 60 --max-merge 4 --weightb --bframes 8 --rc-lookahead 80 --ref 5 --colorprim bt709 --colormatrix bt709 --transfer bt709 --deblock -2:-1 --no-sao --no-strong-intra-smoothing --y4m --output /root/MyMovie-out.mkv -
Script evaluation failed:
Python exception: No attribute with the name ffms2 exists. Did you mistype a plugin namespace?
Traceback (most recent call last):
File "src/cython/vapoursynth.pyx", line 1937, in vapoursynth.vpy_evaluateScript
File "src/cython/vapoursynth.pyx", line 1938, in vapoursynth.vpy_evaluateScript
File "/root/MyMovie.vpy", line 8, in <module>
clip = core.ffms2.Source(r"/root/MyMovie-1min.mkv", cachefile = r"/root/MyMovie-1min.mkv.ffindex")
File "src/cython/vapoursynth.pyx", line 1532, in vapoursynth.Core.__getattr__
AttributeError: No attribute with the name ffms2 exists. Did you mistype a plugin namespace?
x265 [error]: unable to open input file <->
root@ubuntu19:~# cat MyMovie.vpy
import os
import sys
ScriptPath = '/root/VS/Scripts'
sys.path.append(os.path.abspath(ScriptPath))
import vapoursynth as vs
core = vs.get_core()
clip.set_output()
root@ubuntu19:~# python -V
Python 3.7.3
root@ubuntu19:~#
root@ubuntu19:~# vspipe --version
VapourSynth Video Processing Library
Copyright (c) 2012-2018 Fredrik Mellbin
Core R45
API R3.5
Options: -
root@ubuntu19:~# x265 --version
x265 [info]: HEVC encoder version 2.9
x265 [info]: build info [Linux][GCC 8.2.0][64 bit] 8bit+10bit+12bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
root@ubuntu19:~# ffmpeg --version
ffmpeg version 4.1.3-0ubuntu1 Copyright (c) 2000-2019 the FFmpeg developers
built with gcc 8 (Ubuntu 8.3.0-6ubuntu1)
configuration: --prefix=/usr --extra-version=0ubuntu1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 22.100 / 56. 22.100
libavcodec 58. 35.100 / 58. 35.100
libavformat 58. 20.100 / 58. 20.100
libavdevice 58. 5.100 / 58. 5.100
libavfilter 7. 40.101 / 7. 40.101
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 3.100 / 5. 3.100
libswresample 3. 3.100 / 3. 3.100
libpostproc 55. 3.100 / 55. 3.100
Unrecognized option '-version'.
Error splitting the argument list: Option not found
root@ubuntu19:~#
root@ubuntu19:~# uname -a
Linux ubuntu19 5.0.0-15-generic #16-Ubuntu SMP Mon May 6 17:41:33 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
root@ubuntu19:~#
I did set these below:
LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH; export LD_LIBRARY_PATH
PYTHONPATH=/usr/local/lib/python3.7/site-packages/; export PYTHONPATH
PKG_CONFIG_PATH=$PKG_CONFIG_PATH:/usr/local/lib/pkgconfig; export PKG_CONFIG_PATH
LD_RUN_PATH=$LD_RUN_PATH:/usr/local/lib; export LD_RUN_PATH
and tried this too..
root@ubuntu19:~/.config/vapoursynth# cat /root/.config/vapoursynth/vapoursynth.conf
SystemPluginDir=/usr/local/lib/pkgconfig
fms2 install log:
root@ubuntu19:~/ffms2# make install
make[1]: Entering directory '/root/ffms2'
/usr/bin/mkdir -p '/usr/local/lib'
/bin/bash ./libtool --mode=install /usr/bin/install -c src/core/libffms2.la '/usr/local/lib'
libtool: install: /usr/bin/install -c src/core/.libs/libffms2.so.4.0.0 /usr/local/lib/libffms2.so.4.0.0
libtool: install: (cd /usr/local/lib && { ln -s -f libffms2.so.4.0.0 libffms2.so.4 || { rm -f libffms2.so.4 && ln -s libffms2.so.4.0.0 libffms2.so.4; }; })
libtool: install: (cd /usr/local/lib && { ln -s -f libffms2.so.4.0.0 libffms2.so || { rm -f libffms2.so && ln -s libffms2.so.4.0.0 libffms2.so; }; })
libtool: install: /usr/bin/install -c src/core/.libs/libffms2.lai /usr/local/lib/libffms2.la
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/sbin" ldconfig -n /usr/local/lib
Libraries have been installed in:
/usr/local/lib
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the '-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the 'LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the 'LD_RUN_PATH' environment variable
during linking
- use the '-Wl,-rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to '/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
/usr/bin/mkdir -p '/usr/local/bin'
/bin/bash ./libtool --mode=install /usr/bin/install -c src/index/ffmsindex '/usr/local/bin'
libtool: install: /usr/bin/install -c src/index/.libs/ffmsindex /usr/local/bin/ffmsindex
/usr/bin/mkdir -p '/usr/local/share/doc/ffms2'
/usr/bin/install -c -m 644 doc/ffms2-api.md doc/ffms2-changelog.md '/usr/local/share/doc/ffms2'
/usr/bin/mkdir -p '/usr/local/include'
/usr/bin/install -c -m 644 ./include/ffms.h ./include/ffmscompat.h '/usr/local/include'
/usr/bin/mkdir -p '/usr/local/lib/pkgconfig'
/usr/bin/install -c -m 644 ffms2.pc '/usr/local/lib/pkgconfig'
make[1]: Leaving directory '/root/ffms2'
bjoker is offline   Reply With Quote
Old 28th May 2019, 13:33   #3378  |  Link
ChaosKing
Maybe someone could make a flatpack / appimage / snap version with vsedit, vapoursynth and some plugins.
Old 28th May 2019, 15:14   #3379  |  Link
bjoker
I solved issue of loading plugins by
import os
import sys
#LoadPlugin(path='/usr/local/lib/pkgconfig/ffms2.pc')
core.std.LoadPlugin(path='/usr/local/lib/vapoursynth/libffms2.so')
clip = core.ffms2.Source(r"/root/eega-1min.mkv", cachefile = r"/root/eega-1min.mkv.ffindex")
clip.set_output()
root@ubuntu19:~#
But do I need to load each one manually that I need?
Old 28th May 2019, 15:24   #3380  |  Link
Are_
The problem is /usr/local/lib is not in your path.
You can pass it to configure when you build ffms2 and then install to the common path:
./configure --prefix=/usr --libdir=/usr/lib64
Ops, and then soft-link in "/usr/lib64/vapoursynth" I guess.
Are_ is offline   Reply With Quote
speed, vaporware, vapoursynth
