4th February 2021, 15:07 | #30381 | Link |
does mkv import have any limitations ?? ie number of mkvs or total time ?? tried importing 8 mkvs and getting an error on the 8th, tried importing just mkv 8 and its fine ??? ive had this happen before with multipul mkv ??
PHP Code:
4th February 2021, 17:39 | #30382 | Link | |
4th February 2021, 21:44 | #30383 | Link |
ah doh storage space, although not sure if that was the prob my hdd shortage is cos ive just updated a game hmmm, will have to retry when i know i got space
4th February 2021, 22:16 | #30384 | Link | |
From a BD's structure. Pointed BDRB to the directory containing the BDMV directory.
31,758,146KB 32,011,146KB 31,775,400KB Don't know what else to say. |
4th February 2021, 22:43 | #30385 | Link | |
In my case, if the size does not fit on a disk with a minimum of space left, I usually re-run and adjust via custom output size. |
4th February 2021, 23:37 | #30388 | Link |
Run the job and when it gets to one of the problem M2TS files and starts the encode, then abort before it finishes. Then go to the BD-RB folder and open up LASTCMD.TXT. Cut-and-paste the command into a CMD window and run it. See if it completes all the frames before it stops.
5th February 2021, 15:08 | #30390 | Link |
The problem has been solved. I had issues with one of the HDDs on the system, so I replaced it. It wasn't a brand new drive, but it wasn't that old either. Turns out, the replacement drive was going bad as well. Some of the files that I was working with landed in bad areas.
But, in my defense, while BDRB was re-encoding the 4K video files, the encoder aborted when it had trouble reading the file. The problem is that BDRB never received an error and continued right on working. That led me to believe that everything was fine. It was when I tried to copy the offending files that the reading stopped and Win7 errored out. I had received a new drive to replace another where the SATA connector got messed up. Before the drive arrived, I managed to MacGyver the SATA connection and that drive is now working just fine. That allowed the new drive to be used to replace the 2nd drive to go fubar. I just finished rerunning the job that gave the problem and all is well. It really sucks when you get led on a wild goose chase. |
6th February 2021, 05:20 | #30391 | Link |
For UHD discs, I've noticed that even though the target is 23500, the actual results are 2-3 GB below the target.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 6th February 2021 at 13:16. |
6th February 2021, 12:11 | #30392 | Link | |
That really depends on the source. That's why I output the ISOs and if it's too small or too big, I adjust the custom output size. |
6th February 2021, 16:56 | #30393 | Link | |
8th February 2021, 15:02 | #30395 | Link | |
New version to include this? Sent from my iPhone using Tapatalk |
17th February 2021, 05:59 | #30396 | Link |
Finding Dory BD
Hello JD and All,
I've ripped this BD many times, and still the same results after processing it with BD-RB. Many other BDs are doing fine. I had BD-RB make an MKV after ripping and NOT pre-processing with BD-RB. That MKV plays as it should. I've played each MKV with LG BD Player and PowerDVD..not any problems. Then processed.. Code:
- [18:30:18] Multiplexing M2TS - [18:30:24] Processing: VID_00447 (161 of 161) - [18:30:24] Extracting A/V streams [VID_00447] - [18:30:49] Reencoding video [VID_00447] - [18:30:49] Keeping original video (no reencode) - [18:30:49] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (eng): Keeping original audio - Track 4355 (eng): Keeping original audio - Track 4358 (eng): Keeping original audio - [18:30:49] Multiplexing M2TS [18:30:55]PHASE ONE complete [18:30:55]PHASE TWO - Rebuild Started - [18:30:55] Rebuilding BD file Structure [18:31:03] - Encode and Rebuild complete [18:31:03] JOB: FINDING_DORY_(DECRYPTED_AND_NOT_PROCESSED) finished. Code:
[02/16/21] BD Rebuilder v0.61.19 [18:32:17] Source: FINDING_DORY_(DECRYPTED_AND_NOT_PROCESSED)_00801 - Input BD size: 19.83 GB - Approximate total content: [01:36:29.137] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, 1920x1080, 640Kbs DD5.1 - Quality: Highest (Very Slow) - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [18:32:20] PHASE ONE, Encoding - [18:32:20] Processing: VID_00411 (1 of 52) - [18:32:20] Extracting A/V streams [VID_00411] - Extracting video streams [VID_00411] - Extracting audio/subtitle streams [VID_00411] - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: C:\USERS\User\DOWNLOADS\FINDING_DORY_(DECRYPTED_AND_NOT_PROCESSED)\BDMV\\STREAM\00411.m2ts - Extracting audio streams [VID_00411] - Error in attempt to extract audio. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: C:\USERS\User\DOWNLOADS\FINDING_DORY_(DECRYPTED_AND_NOT_PROCESSED)\BDMV\\STREAM\00411.m2ts - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: C:\USERS\User\DOWNLOADS\FINDING_DORY_(DECRYPTED_AND_NOT_PROCESSED)\BDMV\\STREAM\00411.m2ts [18:33:06] - Failed to retrieve audio, aborted I haven't yet checked previous versions of BD-RB. I'm using lossless audio and video for MKV and processing.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 18th February 2021 at 06:33. |
20th February 2021, 20:50 | #30397 | Link |
BD-RB encodes some UHD-Disks over 100%.
[02.20.21] BD Rebuilder v0.61.18 [09:29:33] Source: DIE_UNFASSBAREN_1_UHD - Input BD size: 72,67 GB - Approximate total content: [03:08:39.683] - Target BD size: 46,26 GB - Windows Version: 6.2 [9200] - Quality: High Quality (Default), Two Pass - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [09:29:33] PHASE ONE, Encoding - [09:29:33] Processing: VID_00000 (1 of 12) - [09:29:33] Extracting A/V streams [VID_00000] - [09:36:11] Reencoding video [VID_00000] - Source Video: HEVC, 3840x2160 - Rate/Length: 23,976fps, 166.462 frames - Bitrate: 39.293 Kbs - [09:36:11] Reencoding: VID_00000, Pass 1 of 2 |
21st February 2021, 01:45 | #30398 | Link |
@AmigaFuture
Unfortunately the "Reading buffer overflow..." errors come from TSMUXER. BD Rebuilder is just capturing the error and showing it in the log. Interestingly (if I read your post right), the error is coming from a disc that appears to have been muxed with TSMUXER. |
21st February 2021, 07:01 | #30399 | Link | |
Don't process the disc and make an MKV...zero problems (so far noticed). Process the disc, read that processed disc into BD-RB, make a new BD or MKV = problems.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 21st February 2021 at 07:04. |
22nd February 2021, 08:09 | #30400 | Link |
I thought it's TSMUXER rather than BD-RB.. I'll make a new menu from movie and extras. Appreciate the reply, JD. I almost always know something is "happening" when Menu & Extras" doesn't have the menu graphic in the Stream VID list. Haaa!
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
