Old 19th January 2024, 11:53   #341  |  Link
ProWo
Newest beta (v3.2.0.05), online now.
Fixed:
Batch tasks: file extensions, progress bar.
Improved:
Many code corrections.
ProWo is offline   Reply With Quote
Old 23rd January 2024, 16:24   #342  |  Link
ProWo
January 23, 2024 release version 3.2.1.
New:
Resume unused processed files after program closing.
b switch option for dynaudnorm (request by mannequin80).
LoudNorm filter settings (request by manneqin80).
Unused processed tasks exported to file for next time use.
All closed EIA 608/708 captions can be exported now, not only the first (request by ss vegata).
Batch task possibility to replicate commandline to many files (request by ingsoc, non documented).
Extract from and mux in picture to video
Tooltips on colorspace selection items (video encoding)
Filename check with automatic filename change for filenames with illegal characters in join grid.
Fixed:
Batch tasks file extensions bug.
Batch tasks progress bar bug.
Video cut bug.
Some small bugs.
Improved:
Cut info.
Batch elements handling.
Audio bitrate handling.
Many code corrections and little cosmetics.
Old 25th January 2024, 11:33   #343  |  Link
ProWo
Newest beta (v3.2.1.01), online now.
Changed:
Replaced all system colors with real RGB colors, so setting dark windows themes or designs can't change them anymore and the functionality should be preserved.
Old 26th January 2024, 16:47   #344  |  Link
ProWo
January 26 2024 release version 3.2.2.
New: New RGB colors instead of system colors.
Fixed:
Bug in loudnorm 2pass parsing
Bug in automatic file naming.
Old 28th January 2024, 09:39   #345  |  Link
ProWo
January 28 2024 release version 3.2.3.
Fixed:
Important bug in color range parsing.
Old 28th January 2024, 15:04   #346  |  Link
ProWo
Newest beta (v3.2.3.01), online now.
Fixed:
Missing source chapters muxing.
Old 29th January 2024, 00:40   #347  |  Link
Lathe
Lathe's Avatar
Fixed:
WOW! What a great program, thanks for all the hard work Bro
So, I've been converting UHD HDR video files to SDR (I have an older OPPO and telly that is not 4k) I've just been using Handbrake because it is so easy and using the basic color filter BT709 like others have suggested. Is using your lovely program basically doing the same thing? Sorry, but I am not conversant in the deeper stuff like this.
I have downloaded but not tried your program yet. I noticed in the color space area there seem to be a nice variety of choices that I am not familiar with. Would I just set it for basic BT709 encoding, or are there any other, finer 'Tweaks' with these settings that might help the color turn out better for these conversions? Would it allow me to do anything else or 'better' than I get with Handbrake?
I really appreciate any input or suggestions, and please remember I am not super duper technical in understanding the really deep things about this, but I really do want to understand it better.
Thanks kindly!
Lathe is offline   Reply With Quote
Old 30th January 2024, 09:52   #348  |  Link
ProWo
@Lathe
For a correct tonemapping the BT709 filter isn't enough.
Here you have an example of how to convert a 4k HDR 10 bit video into a HD SDR 8 bit video readable for your OPPO with mobius tone mapping. The batch mode is used because the tone mapping is slow and in batch mode the standby is deactivated and therefore the entire video is encoded without interruption.
However, you can also encode just one sample instead of batch mode as a test.
To do this, activate the sample checkbox, enter the desired duration in seconds and click on encode instead of to batch.
https://forum.videohelp.com/attachme...chmentid=76610
Old 31st January 2024, 17:08   #349  |  Link
ProWo
Newest beta (v3.2.3.02), online now.
Fixed:
Bug in subtitle selection for burn in subtitles.
Bug in audio volume detection.
Changed:
Scan for errors (now errors only, not messages).
Help screen loaded automatically with chapters screen.
Other system colors to RGB
Old 6th February 2024, 01:24   #350  |  Link
TDS
Formally known as .......
TDS's Avatar
Hi ProWo,
I haven't posted here for a long time, as I haven't been doing much of this sort of stuff, recently.
But the other day I thought I'd refresh my memory with some of these DV app's, and get back into to it again.
Despite the obvious of what the main objective is with these app's, I found one that would convert THD 7.1 to Eac3 7.1, and it's obviously using FFMPEG, so I thought I'd grab your latest build as see what happens, seeing you are constantly improving it
I was quite surprised, when after loading the same .thd file I had just converted, to only be presented with a "Not Supported" message.
Not sure how this other app/tool does it, but it does.
And another function it seems to do quite well, is converting SDR to HDR, it takes a while, but again, it does it.
Just fyi.
Cheers
Long term RipBot264 user.
RipBot264 modded builds..
TDS is offline   Reply With Quote
Old 6th February 2024, 08:27   #351  |  Link
ProWo
@TDS
With the newest nightly build:
[eac3 @ 000001e0ac35f5c0] Specified channel layout '7.1' is not supported by the eac3 encoder
And as far as SDR to HDR is concerned:
where is the program supposed to get all the missing data from?
Old 6th February 2024, 10:10   #352  |  Link
TDS
TDS's Avatar
@TDS
Like I said in my previous post, I have no idea how this app does its "magic", so maybe you should take a look for yourself...
But it definitely converts thd 7.1 to eac3 7.1 (8 channel), as for the SDR to HDR conversion's, it does do that too, although there are issues with the tonemapping / colourspace, it's a little washed out.
https://github.com/R3S3t9999/DoVi_Sc...readme-ov-file
Old 6th February 2024, 11:28   #353  |  Link
tebasuna51
tebasuna51's Avatar
That app say clearly use EasyAudioEncoder.exe to create eac3 7.1, you need download yourself (legality?) to be used in a Plex install, with python, Dolby tools (need a account), etc...
It is not the ffmpeg encoder.
Old 6th February 2024, 11:49   #354  |  Link
TDS
TDS's Avatar
Thanks for the info, "teb", I just downloaded and installed EVERYTHING that "RESET_9999" recommended.
The only issue I have found is with the SDR to HDR conversion, it has some tonemapping issues.
EDIT:- I got a msg from "RESET" stating that the SDR to HDR conversion is just the first step in the process, and needs to be colorgraded with DaVinci Resolve
Old 11th February 2024, 08:09   #355  |  Link
oniiz86
@Lathe
@ProWo I seem to be having an issue with converting 4K HDR 10 bit HEVC stream to an 1080 SDR 8 Bit AVC stream when played back on my OPPO BDP-105D, one file that I converted simply hangs at 100% on my OPPO & will not start whilst the other file will play but the OPPO's Elapsed Time Counter is stuck on 00:00:00 unless I forward to the next chapter which then the Elapsed Time will initiate, I didn't mux these files with clever FFmpeg-GUI nor did I use the "Batch Mode" option, I simply started the encode process & then I used MKVToolNix
for muxing.
Here is the MediaInfo file info of the file that hangs at 100% on my OPPO that will not start to play,
Format : Matroska
Format version : Version 4
File size : 11.1 GiB
Duration : 2 h 11 min
Overall bit rate mode : Variable
Overall bit rate : 12.1 Mb/s
Frame rate : 24.000 FPS
Movie name : Hannibal 2001
Encoded date : 2023-04-28 21:43:22 UTC
Writing application : mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Cover : Yes
Attachments : cover.jpg
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@Main
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 8 021 kb/s
Width : 3 840 pixels
Height : 2 076 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.042
Stream size : 7.36 GiB (67%)
Writing library : x265 3.5+rarbg-HDR-38-20255e6:[Linux][clang 16.0.0][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=6 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2076 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / no-eob / no-eos / no-hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / no-hist-scenecut / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / no-limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=8000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=0 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1) / cll=1000,710 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light : 710 cd/m2
Audio #1
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 3 652 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 3.35 GiB (30%)
Title : English DTS-HD MA 5.1
Language : English
Default : Yes
Forced : No
MediaInfo file info of the file that has the Elapsed Time Counter stuck at 00:00:00 but corrects itself if I go to the next Chapter,
Format : Matroska
File size : 17.8 GiB
Duration : 2 h 2 min
Overall bit rate : 20.8 Mb/s
Frame rate : 23.976 FPS
Movie name : 3:10 to Yuma 2007
Encoded date : 2017-12-21 23:02:56 UTC
Writing application : mkvmerge v19.0.0 ('Brave Captain') 64-bit
Writing library : libebml v1.3.5 + libmatroska v1.4.8
Video
Format : HEVC
Format profile : Main 10@L5.1@High
Bit rate : 14.2 Mb/s
Height : 1 600 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.096
Stream size : 12.1 GiB (68%)
Writing library : x265 2.5+58-06979c042350:[Windows][GCC 6.2.1][64 bit] 10bit
Encoding settings : cpuid=1173503 / frame-threads=4 / numa-pools=20 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1600 / interlace=0 / total-frames=176115 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / analysis-reuse-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,0) / max-cll=1000,720 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-mv-type=0 / copy-pic=1
Default : Yes
Forced : No
Mastering display luminance : min: 0.0000 cd/m2, max: 1000 cd/m2
Maximum Frame-Average Light : 720 cd/m2
Audio #1
Format : DTS XLL X
Commercial name : DTS-HD MA + DTS:X
Codec ID : A_DTS
Bit rate : 6 290 kb/s
Channel(s) : 8 channels
Channel layout : C L R LFE Lb Rb Lss Rss Objects
Bit depth : 24 bits
Stream size : 5.38 GiB (30%)
Language : English
Default : Yes
Forced : No
oniiz86 is offline   Reply With Quote
Old 11th February 2024, 11:54   #356  |  Link
ProWo
@oniiz86
Both files are:
Bit depth : 10 bits
so you have not set the settings for the conversion correctly.
I advise you to repeat the conversion and use the batch mode, because this blocks the windows standbay and the conversion is guaranteed to run to the end.
Encode a sample first, so you can test it.
Use the newest beta (v3.2.3.03), online now.
Old 11th February 2024, 11:55   #357  |  Link
ProWo
Newest beta (v3.2.3.03), online now.
Added:
Deletion of eia 608/708 captions from h264, hevc, mpeg2 videostreams.
Audio spectrogram (request by ingsoc).
av1 muxing to asf, avi, mov, mp4, wmv.
Fixed:
eac3 audiostream extraction as eac3 (request by Ennio).
Bug in HDR10/HLG metadata parsing.
Bug in source stream audio delay parsing.
Improved:
HDR10/HLG videos handling.
Invalid filenames handling.
Batch tasks handling.
FFmpeg errors handling.
Old 11th February 2024, 14:18   #358  |  Link
oniiz86
@ProWo Thanks for that, will do, I did end up using v3.2.3.02 with the batch mode with the "Hannibal 2001" file that hangs at 100% on my OPPO using a CRF setting of 25 & it significantly made the stream size much smaller at around 1GB from its 7.36GB size, after it finished processing the newly created AVC stream, I then went to mux it using clever FFmpeg-GUI de-selecting the HEVC stream from the original source file & it muxed a 0kb file, very strange behaviour, I must say this particular "Hannibal 2001" file has a HDR/HLG metadata missing warning, not sure why, anyway I'll try the latest beta v3.2.3.03.
Old 11th February 2024, 14:41   #359  |  Link
ProWo
Retry with v3.2.3.03.
Then it depends on whether the source file is recognized as HDR10 or HLG.
With HLG, HLG to SDR is currently not possible because ffmpeg copies the mastering display data from the source without being asked and this cannot be deactivated.
However, if HDR10 is detected, select the x264 encoder, CRF 23, resize to 1920x1040, various, HDR/HLG checkbox, HDR10 to SDR, mobius, Bit depth 8, then to batch.
Old 12th February 2024, 06:45   #360  |  Link
oniiz86
No such luck with v3.2.3.03 unfortunately, I had the same HDR/HLG Metadata missing but I don't think that really matters as much during the conversion to 1080p SDR 8 bit, I used CRF 23 & this time it created a slightly larger AVC stream size of 2GB, what is strange is that the size of the stream is always greatly reduced when using a CRF setting of 23 or 25 but if I choose CRF setting of 18, the newly created stream size is more or less the same 7.36GB size (which I prefer) as the original HEVC stream & then when trying to mux with clever FFmpeg-GUI it created a 0kb file
Is the issue that the Audio/Subtitle streams should first be demuxed than added separately to the newly created AVC stream, perhaps it is getting confused that the HEVC stream is present despite it being de-selected?
