Old 16th May 2018, 20:06   #181  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Originally Posted by moderate View Post
@clsid Hello.
On GitHub:
https://github.com/clsid2/mpc-hc/releases
...the latest version is v1-7-16.
How can we reach the versions with the latest fixes like:
v1-7-16-1:
v1-7-16-3:
...which shows in the update tools.
Thanks for answer.
Ben
SUMo is a pretty useful tool, but it has a certain tendency to show "available updates" which, in reality, are nowhere to be found
Old 16th May 2018, 21:07   #182  |  Link
moderate
There are however the users, who have those versions installed. Like here:
https://www.reddit.com/r/Windows10/c...latest_update/
moderate is offline   Reply With Quote
Old 17th May 2018, 14:31   #183  |  Link
Sarasa
Lost In The Web
Sarasa's Avatar
There's peoples that compile their own version of MPC-HC, Lav, ...
Those reddit user are perhaps doing that.
Sarasa is offline   Reply With Quote
Old 20th May 2018, 08:21   #184  |  Link
pikaczu
Posts: n/a
what, how many new versions will it be?
Old 9th June 2018, 17:26   #185  |  Link
Virtual_ManPL
Virtual_ManPL
Virtual_ManPL's Avatar
Over 9000
Virtual_ManPL is offline   Reply With Quote
Old 10th June 2018, 19:16   #186  |  Link
KoD
There's a (user interface only?) bug in this version of MPC-HC. On the Audio Renderer settings page, the "Ignore system channel mixer" setting does not persist across sessions:
- go to the page and disable the setting
- press Apply and OK
- close the player
- open the player again and go to that setting page -> the setting is enabled
KoD is offline   Reply With Quote
Old 11th June 2018, 14:22   #187  |  Link
clsid
^ fixed
Old 12th June 2018, 07:14   #188  |  Link
khanmein
Where can I get the 1.7.16.6?
khanmein is offline   Reply With Quote
Old 12th June 2018, 08:46   #189  |  Link
JohnLai
So, I got myself another Astrometa USB DVB-T2 sticks.
I was able to scan few tv channels, video is coming out fine, but there isn't any audio coming out at all
Filters currently loaded:
- BDA MPEG2 Transport Information Filter
- MPEG-2 Sections and Tables
- LAV Audio Decoder ----->DD+ 48000Hz 6ch 192kbps
- LAV Audio Decoder ----->Dolby AC3 48000Hz 6ch 192kbps
- LAV Audio Decoder ----->MPEG Audio 48000Hz stereo 256kbps
- madVR
- Internal Audio Renderer ---->IEEE Float 48000Hz stereo 3072kbps
- LAV Video Decoder
- LAV Audio Decoder ---->AAC 48000Hz stereo 128kbps
- MPEG-2 Demultiplexer
- ASTROMETA DTV Filter
- Microsoft DVBT Network Provider
There isn't audio selection at MPC-hc either.
Any idea?
JohnLai is offline   Reply With Quote
Old 12th June 2018, 09:22   #190  |  Link
LigH
LigH's Avatar
Unfortunately, clsid may not provide a binary release for every single patch, only for a new minor version (so next release would probably be 1.7.17); there are other people who build it more often, I remember the tool SUMo (Software Update Monitor) being mentioned, but I don't know where they host their own builds.
P.S.: That was less than 20 posts before your question. Don't forget to read back past posts before asking...
New German Gleitz board
Old 12th June 2018, 10:23   #191  |  Link
khanmein
I know the SUMO, but I don't want to grab it from there. :x
Old 12th June 2018, 12:00   #192  |  Link
LigH
LigH's Avatar
I would prefer a separate "nightlies" archive (hosted by one of them who are able to build) as well. But that will be their decision.
Old 12th June 2018, 14:24   #193  |  Link
clsid
For DVB issues, you can try test builds found here:
https://github.com/mpc-hc/mpc-hc/pull/145
I don't even have DVB hardware, so I can't provide any help at all.
Old 12th June 2018, 15:33   #194  |  Link
JohnLai
Oh well, might as well as I test it, failing it, at least the alternative progdvb works.
EDIT: Nope, the test build doesn't work. Still no audio coming out. ProgDVB works flawlessly with audio and video. I wonder if it is caused by lack of mpc-hc audio selection. I mean there are four audio streams, but I don't seem to get menu to select the audio stream.
EDIT2:
Strange, the pin seems to be connected properly, why there isn't any audio coming out?
Below is for radio station via dvb-t2.
I think the problem is the automatically selected demultiplexer. Any alternative demultiplexer that I can use?
Old 16th June 2018, 18:25   #195  |  Link
PCU
any news from cls dos (clsid) & new version?
PCU is offline   Reply With Quote
Old 16th June 2018, 21:01   #196  |  Link
clsid
@JohnLai
Try settings "Microsoft DTV-DVD Audio Decoder" as a preferred external filter. Maybe that works better in your case.
@PCU
New version will probably be shortly after next stable LAV Filters release. But I am not making any promises.
For example K-Lite contains the latest development builds of MPC-HC and LAV Filters.
Old 16th June 2018, 23:22   #197  |  Link
LigH
LigH's Avatar
@PCU: "CLSID" = Class Identifier, neither related to ClearScreen nor MS-DOS.
Old 18th June 2018, 03:53   #198  |  Link
JohnLai
@JohnLai
Nope, it doesn't work.
I added "Microsoft DTV-DVD Audio Decoder" as mpc external filter, set it to 'prefer'.
Next, I added "LAV Audio Decoder" and set it to "block"
Unfortunately, once I set "LAV Audio Decoder" to 'block', mpc will output "could not open capture device" once I clicked "Open Devices..."
I think it is because "Microsoft DTV-DVD Audio Decoder" doesn't support HE-AACv2?
I am using nightly version of lavfilter and latest mpc-hc.
SmartDVB and ProgDVB works, but.....ProgDVB has some issue with Astrometa buffer detection (broken video every 5 seconds) and its WASAPI/Exclusive mode for audio works just fine. SmartDVB has perfect audio and video output. However, SmartDVB doesn't have WASAPI for audio.
Old 18th June 2018, 14:49   #199  |  Link
PCU
i'm just kidding about clsid & i'll wait even 2 months for next version.
Old 19th June 2018, 14:30   #200  |  Link
clsid
1.7.17 has been released
Changelog:
* Updated LAV Filters to v0.72
* Updated MediaInfo DLL to v18.05
* Fixed: the "Ignore System Channel Mixer" audio renderer option was not saved
* Change: Use millisecond prevision in SaveImage filename
Download
