Old 10th December 2023, 17:57   #1221  |  Link
danbow
Hi Doom9!
I very much love VirtualDub2 and it is very a pity, that it is stopped on 44282 version in 2020.
I love WindowsXP even more and i use ffmpeg xpmod by Reino Wijnsma: https://rwijnsma.home.xs4all.nl/files/ffmpeg/?C=M;O=D
Right now last version ffmpeg-6.1 (2023-09-04) for xp, there is and sources, but alls it only x86 (i do not know why for xp-64 does not do).
Maybe this is useful for compile.
danbow is offline   Reply With Quote
Old 10th December 2023, 19:42   #1222  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
I would guess that Reino might have no XP64 bit installation and building tools available (me neither)
But since he was so kind to publish his build configuration
https://forum.doom9.org/showthread.p...ghlight=ffmpeg
one who has all that (and the knowledge) should be able to compile himself.
Old 11th December 2023, 15:07   #1223  |  Link
v0lt
VirtualDub2 includes only one plugin that uses FFmpeg DLLs. This is avlib-1.vdplugin.
Old version of avlib-1.vdplugin uses old versions of FFmpeg DLLs. New versions of FFmpeg differ in the names of the DLL files. The FFmpeg API has also been changed.
v0lt is offline   Reply With Quote
Old 7th January 2024, 17:21   #1224  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by v0lt View Post
VirtualDub2 x64 with updated avlib-1.vdplugin (ffmpeg6.1 test 7)
Tried to drag and drop a AVS file and it simply hangs.
@turment on Telegram
Old 10th January 2024, 18:55   #1225  |  Link
v0lt
It doesn't freeze for me, but it gives me an error.
I disabled support for AviSynth scripts in avlib-1.vdplugin.
VirtualDub2 x64 with updated avlib-1.vdplugin (ffmpeg6.1 test 8)
Alternative link
avlib-1.vdplugin (FFmpeg 6.1) source code
Old 20th January 2024, 08:25   #1226  |  Link
v0lt
VirtualDub2 x64 with updated avlib-1.vdplugin (ffmpeg 6.1.1 test 9)
Alternative link
avlib-1.vdplugin (FFmpeg 6.1.1) source code
Old 10th February 2024, 19:17   #1227  |  Link
Morku
It's nice to see updates here, but using VirtualDub2 x64 with updated avlib-1.vdplugin (ffmpeg 6.1.1 test 9) the process stays open in background after closing VD2. I need to close in task-manager.
To reproduce I need to drag and drop an Avisynth avs script, containing and loading a video:
LWLibavVideoSource("IMG_0001.MOV")
Closing VD2 and it still run.
Morku is offline   Reply With Quote
Old 10th February 2024, 21:18   #1228  |  Link
v0lt
@Morku
I think the problem is not with avlib-1.vdplugin (test 9). Because this plugin should not be used with AviSynth scripts.
Old 11th February 2024, 00:01   #1229  |  Link
Morku
Yes, that makes me also wondering, but using last VirtualDub2_44282 64Bit version, the exact same video and script, it doesn't get stuck. Using test 9, the process get stuck after closing again.
Don't know why and what exactly is the cause, but with the Avisynth script is my observation. When I drag and drop the MOV directly, VD2 test 9 just closes fine.
Old 11th February 2024, 06:53   #1230  |  Link
v0lt
What happens if you open a simpler script?
Colorbars(1280,720)
Old 11th February 2024, 10:23   #1231  |  Link
Morku
Also don't close proper. I need to close in task-manager. (AviSynth+ 3.7.3)
Old 11th February 2024, 13:55   #1232  |  Link
v0lt
I confirm the problem. But I don’t know what to do with it yet.
Old 14th February 2024, 17:56   #1233  |  Link
Morku
One more thing with test 9. Loading a DV avi gives me error:
FFMPEG: Unsupported channel layout.
File to test: https://www.sendspace.com/file/p7eghe
Loading fine with 44282.
Old 14th February 2024, 19:08   #1234  |  Link
v0lt
Older versions of FFmpeg recognized audio from DV as stereo. Newer versions of FFmpeg recognize audio as 2 channels with an unknown channel layout.
I tried to solve this problem.
VirtualDub2 x64 with updated avlib-1.vdplugin (ffmpeg 6.1.1 test 10)
Alternative link
Old 14th February 2024, 22:59   #1235  |  Link
Morku
That was quick and I can confirm, the DV loads fine now
Old 15th February 2024, 04:56   #1236  |  Link
v0lt
Fixed.
VirtualDub2 x64 with updated avlib-1.vdplugin (ffmpeg 6.1.1 test 11)
Alternative link
Old 15th February 2024, 13:37   #1237  |  Link
tormento
Acid fr0g
tormento's Avatar
It's a pity that I can't get working AVS+ support.
Hope in some future release.
Old 15th February 2024, 16:11   #1238  |  Link
v0lt
AviSynth+ scripts open for me.
Old 16th February 2024, 16:13   #1239  |  Link
LigH
LigH's Avatar
It might be the issue I once reported: Selecting the Cached vs. AviFile input driver when opening AVS files.
New German Gleitz board
Old 17th February 2024, 10:13   #1240  |  Link
v0lt
I don't have this problem with the latest test build.
You may be using FFmpegSource2, which builds an index file for the video file being opened.
