Old 18th July 2020, 18:37   #29641  |  Link
prologic
Tested BD-RB v0.61.06
With Movie LE_MANS_66 UHD 60gig to BD50 using geforce gtx 1070 card.
Worked a treat .Took about 1 hour to do .Very pleased with the result , on my oppo 203 Player , with all the menus and such .
Here is the log:
[07-18-20] BD Rebuilder v0.61.06
[12:27:33] Source: LE_MANS_66
- Input BD size: 60.18 GB
- Approximate total content: [02:43:59.496]
- Target BD size: 46.26 GB
- Windows Version: 6.2 [9200]
- Auto Quality: Very Good (Very Fast), ABR
- X264 Tweak(s) enabled
- Decoding/Frame serving: NVENCC
- Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640
[12:27:33] PHASE ONE, Encoding
- [12:27:33] Processing: VID_00006 (1 of 1)
- [12:27:33] Extracting A/V streams [VID_00006]
- Extracting video streams [VID_00006]
- Extracting audio/subtitle streams [VID_00006]
- [12:33:35] Reencoding video [VID_00006]
- Source Video: HEVC, 3840x2160
- Rate/Length: 23.976fps, 219,511 frames
- Bitrate: 31,380 Kbs
- [12:33:35] Reencoding: VID_00006, Pass 1 of 1
- [13:21:57] Video Encode complete
- [13:21:57] Processing audio tracks
- [13:21:57] Multiplexing M2TS
[13:26:07]PHASE ONE complete
[13:26:07]PHASE TWO - Rebuild Started
- [13:26:07] Rebuilding BD file Structure
[13:26:17] - Encode and Rebuild complete
[13:26:17] JOB: LE_MANS_66 finished.
prologic is offline   Reply With Quote
Old 18th July 2020, 21:06   #29642  |  Link
cartman0208
I'm having trouble converting UHD BDs in CQM Mode ... each one I tried so far fails on CQM prediction
[07.18.20] BD Rebuilder v0.61.06
[21:57:28] Source: COLD_PURSUIT
- Input BD size: 78,62 GB
- Approximate total content: [02:04:46.291]
- Target BD size: 47,85 GB
- Quality: Highest (Very Slow), CQM
- Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
[21:57:33] PHASE ONE, Encoding
- [21:57:33] Processing: VID_00000 (1 of 14)
- [21:57:33] Extracting A/V streams [VID_00000]
- [21:57:38] Reencoding video [VID_00000]
- Rate/Length: 24,000fps, 1.046 frames
- [21:57:38] Performing CQM Prediction...
- Analyzing 17,35 [21:57:42] - Failed video encode, aborted
VBR runs fine
Which one would you suggest for quality?
cartman0208 is offline   Reply With Quote
Old 18th July 2020, 21:24   #29643  |  Link
jdobbs
Originally Posted by cartman0208 View Post
I'm having trouble converting UHD BDs in CQM Mode ... each one I tried so far failes on CQM prediction
VBR runs fine
I think it may be too early to call for quality -- but I suspect it might be CQM. I wouldn't make a wager on that though until a lot more testing is done.
Can you -- right after the encode fails:
1. Copy the content of LASTCMD.TXT (in the BD-RB folder) and post it here.
2. Cut and paste the command line from that file into a DOS prompt window and try to run it, and see what error it gets.
Hmm... I wonder if the routine is inserting a "," instead of a "." when specifying the CQM value on the command line because of European notation for the decimal place?
Website: www.jdobbs.net
Old 18th July 2020, 21:26   #29644  |  Link
jdobbs
Worked a treat .Took about 1 hour to do .Very pleased with the result , on my oppo 203 Player , with all the menus and such.
Thanks for testing and posting the result. Appreciated.
One thing I see... since X264 isn't being used, I guess the message saying "tweaks enabled" isn't applicable and shouldn't be logged.
Old 18th July 2020, 21:43   #29645  |  Link
cartman0208
"U:\BD_Rebuilder\tools\nvenc\nvencc.exe" --avhw -i "U:\BD-OUTPUT\WORKFILES\00008.AVS.SMPL.m2ts" --codec hevc --preset quality --profile main10 --output-depth 10 --repeat-headers --chromaloc 2 --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --master-display G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1) --qp-min 0 --vbr 0 --vbr-quality 1 --aq-temporal --keyfile "U:\BD-OUTPUT\WORKFILES\VID_00008.CHP" --sar 1:1 --aud --pic-struct --vbv-bufsize 45000 --max-bitrate 48000 --gop-len 24 -o "U:\BD-OUTPUT\WORKFILES\TEMP.265"
and the result from command line:
avcuvid: size of input file "U:\BD-OUTPUT\WORKFILES\00008.AVS.SMPL.m2ts" is 0
failed to initialize file reader(s).
Failed to open input file.
Old 18th July 2020, 21:52   #29646  |  Link
jdobbs
Ok... I see. It looks like the input file is too short for BD-RB to create a sample. I guess I never thought about that possibility when I added the new sampling method for HEVC.
There's only 1 frame in that file? I'm surprise it is even in the list to be encoded... you must have set the minimum encode length to 0, maybe?
Would you mind posting the contents of your BDREBUILDER.INI file?
Old 18th July 2020, 22:10   #29647  |  Link
cartman0208
The input file should have 160k frames
[22:37:53] PHASE ONE, Encoding
 - [22:37:53] Processing: VID_00008 (5 of 14)
 - [22:38:24] Reencoding video [VID_00008]
   - Rate/Length: 24,000fps, 160.215 frames
 - [22:38:24] Performing CQM Prediction...
   - Analyzing 1,00 [22:38:28] - Failed video encode, aborted[/QUOTE]
[QUOTE][Options]
AC3_192=0
AC3_640=1
AC3_REENCODE=0
ALTAUTOCROP=1
ALTCRF=20
ALTMETHOD=0
ALT_CRF_TARGET=1024
ALT_TARGET=1024
ASSUME_DVD_PAL=0
AUDIO_DRC=0
AUDIO_TO_KEEP=deu;eng;ger;
AUDIO_TRACK_LIMIT=1
AUTO_BURN=2
AUTO_QUALITY=0
AVCHD=1
BD25_SIZE=24500
BD50_SIZE=49000
BDMV_CERT_ONLY=0
COMPLETION_BEEP=0
CONVERT_WIDE=0
CUSTOM_TARGET_SIZE=23500
DECODER=0
DEINTERLACE=0
DTS_REENCODE=0
ENCODER=1
ENCODE_QUALITY=3
FRIMSOURCE=0
IGNORE_3D=0
IVTC_PULLDOWN=0
KEEP_HD_AUDIO=0
MODE=0
MOVIEONLY_TYPE=4
NEROAAC=0
NVENC_CAPABLE=1
ONEPASS_ENCODING=2
OPEN_GOP=0
OUTPUT_SBS=0
PGSTOSRT=0
REMOVE_OUTPUT=0
REMOVE_WORKFILES=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
SD_CONVERT=0
SD_TO_1080=0
SUBS_TO_KEEP=all
SUBTITLE_TRACK_LIMIT=1
SUPTITLE=0
TARGET_SIZE=49000
USE_FILTERS=0
VERSION=0.61.0.6
MENU_AUDIO=U:\BD_Rebuilder\tools\blankclip\blank.ac3
IMPORT_THRESHOLD=1
QUICK_PLAY_THRESHOLD=1
MENU_AUTO_BACKGROUND=1
MENU_AUTO_DVDAUDIO=1
MENU_PLAY_SEQUENTIAL=0
MENU_START_WITH_MENU=1
IMPORT_LIMIT_LANG=0
IMPORT_KEEP_PLAYALL=0
IMPORT_PREPARE_MKV=0
[Paths]
SOURCE_PATH=U:\FULLDISC\COLD_PURSUIT\
WORKING_PATH=U:\BD-OUTPUT\
DGIndexNV=U:\Tools\dgdecnv2053\x32 Binaries\DGIndexNV.exe
DGDecNV=U:\Tools\dgdecnv2053\x32 Binaries\DGDecodeNV.dll
Old 19th July 2020, 01:29   #29648  |  Link
jdobbs
Not in the log that you posted:
The 160 frames is for an entirely different M2TS (VID_00008). (5 of 14)
Looking back at it now, though, it looks like even that one had over 1000 frames (I got confused by the use of "." rather than ",")
Old 19th July 2020, 08:35   #29649  |  Link
cartman0208
Sorry, that was the same movie, I just wanted some progress while waiting
I did the 1st vid ... when that failed, I posted that and switched to VBR
When you asked for that command line, I was on the 5th vid of that movie, switched back to CQM, and posted the log...
Sorry again for the confusion
Should I switch regional settings on my OS?
Old 19th July 2020, 11:45   #29650  |  Link
cartman0208
Good hint ... and guess what?
That worked!
I set decimal separator to "." and digit grouping to "," (like here ) and now the encode runs fine in CQM mode...
But I'd rather have my settings back to normal
Old 19th July 2020, 13:53   #29651  |  Link
jdobbs
That worked!
Try this version and let me know if it fixes your issue:
BD-RB v0.61.07
It also adds the --repeat-headers fix when using UHD_V3_MODE=1
Also, I did some testing yesterday to compare CQM and VBR modes with NVENCC. At the same files size (bitrate) it seems that CQM gives a better SSIM. But... since the CQM prediction isn't perfect, its possible that you might have a lower file size and the better SSIM might not hold true. I'm looking at possible ways to improve prediction, or, since it's so fast -- maybe do a second CQM pass (using the first pass as the ultimate "prediction" sample).
Old 19th July 2020, 14:15   #29652  |  Link
Sharc
Some time ago I found to my surprise that leaving --aq 'off' gave the best SSIM and VMAF values in CQM mode (adjusted for nearly same filesize) using NVEncC (AVC, h.264). Maybe it was specific to the source I tested and/or the --aq algo may have improved since, so don't quote me on that.....
Old 19th July 2020, 17:05   #29653  |  Link
GreasyGreedo
Have you had a chance to look into the issue where subtitles are lost from a UHD disc containing multiple movie files? Just checking, no rush or anything.
GreasyGreedo is offline   Reply With Quote
Old 19th July 2020, 19:07   #29654  |  Link
Michi
CQM fails on 61.07, too:
[07.19.20] BD Rebuilder v0.61.07
[19:50:44] Source:  UHD_GENTLEMEN
  - Input BD size: 60,94 GB
  - Approximate total content: [01:56:59.095]
  - Target BD size: 46,26 GB
  - HEVC/V3 mode for BD disc enabled
  - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
[19:50:46] PHASE ONE, Encoding
 - [19:50:46] Processing: VID_00000 (1 of 2)
 - [19:50:46] Extracting A/V streams [VID_00000]
 - [19:50:50] Reencoding video [VID_00000]
   - Rate/Length: 23,976fps, 610 frames
 - [19:50:50] Performing CQM Prediction...
   - Analyzing 1,00 [19:51:01] - Failed video encode, aborted
Nvenc VBR works without error, but the quality on UHDs with grain isn't good enough for me.
I used a GTX 1660 for all tests.
Michi is offline   Reply With Quote
Old 19th July 2020, 19:54   #29655  |  Link
Sharc
The blue seems not right to me ....
If size is not that important to you, you may want to try with a fix quality factor rather than running the prediction, or you could try with the old prediction algo perhaps (NEW_CRF_PREDICTION=0 in the .ini). I didn't try it though.
Old 19th July 2020, 20:09   #29656  |  Link
jdobbs
I'll take another look at it.
Can you post the contents of LASTCMD.TXT (in the BD-RB folder) right after it fails? If possible, then copy the command to a DOS window and try and run it so we can see what error is occurring.
Old 19th July 2020, 21:19   #29657  |  Link
Michi
LASTCMD.TXT;
"C:\BD_Rebuilder UHD\tools\nvenc\nvencc.exe" --avhw  -i "Q:\4K\WORKFILES\00000.AVS.SMPL.m2ts" --codec hevc --preset
--qp-min 0 --vbr 0 --vbr-quality 1 --aq-temporal --sar 1:1 --aud --pic-struct --vbv-bufsize 60000 --max-bitrate 60000
--gop-len 24 -o "Q:\4K\WORKFILES\TEMP.265"
Old 19th July 2020, 21:33   #29658  |  Link
jdobbs
@Michi
Thanks. It looks exactly like what cartman0208 saw. I'm going through sources trying to find one that causes it for me so I can point out exactly why the sample is created with a zero length.
Old 19th July 2020, 22:16   #29659  |  Link
cartman0208
I reseted my regionals back to normal and the Prediction fails on 61.07...
[23:03:26] PHASE ONE, Encoding
- [23:03:26] Processing: VID_00000 (1 of 14)
- [23:03:26] Extracting A/V streams [VID_00000]
- [23:03:31] Reencoding video [VID_00000]
- [23:03:31] Performing CQM Prediction...
- Analyzing 17,35 [23:03:35] - Failed video encode, aborted
Set it to "US" type:
[23:06:53] PHASE ONE, Encoding
- [23:06:53] Processing: VID_00000 (1 of 14)
- [23:06:53] Extracting A/V streams [VID_00000]
- [23:06:57] Reencoding video [VID_00000]
- Rate/Length: 24.000fps, 1,046 frames
- [23:06:57] Performing CQM Prediction...
- Analyzing 17.35 9.18 5.09 3.04 2.02 1.51 1.26 1.13 1.06 1.03 1.02 1.01 [1.01]
- [23:07:31] Encoding using constant quality mode.
Unfortunately thats not all ... on a later vid of that BD the prediction fails with an error Popup
[22:42:06] PHASE ONE, Encoding
- [22:42:06] Processing: VID_00020 (6 of 14)
- [22:42:06] Reencoding video [VID_00020]
- Rate/Length: 24,000fps, 240 frames
- [22:42:06] Performing CQM Prediction...
- [22:42:06] PredictAndEncode() 00006 2810
[22:42:17] - Aborted by user request
LASTCMD.TXT still holds the command from the previous vid.
What I noticed ... VID_00020 only shows the copyright warning, still frame with no motion at all
Old 20th July 2020, 01:42   #29660  |  Link
jdobbs
Yeah. Definitely some work to be done on that HEVC prediction routine.
