#9141 | Link | |
![]() Join Date: Oct 2001
jdobbs.softworks@gmail.com |
#9143 | Link | |
Programmer (or just 教务长)
FULL BACKUP - use BD-R/RE media MOVIE ONLY BACKUP - use BD-R/RE or DVD-R media I believe this is your case: FULL BACKUP with NO JAVA (BD-J) - use DVD media (BD5/BD9) but you'll have to patch the output (index.bdmv) with goBD tool or AVCHD patcher and PS3 will recognize it as AVCHD FULL BACKUP with JAVA (BD-J) can't be used when written to DVD media. Dean Last edited by deank; 11th August 2010 at 16:22. |
#9144 | Link |
I have experienced some "strange" audio UPconversion with 34.06 (havent tried latest 07 yet):
Title "Breaking Up" has (according to tsMuxeR) these two audio streams I wanted to keep: German DD 5.1 448kbps English DD 2.0 192 Rebuilder output was: German 640kbps English 224kbps Tried two times as I wanted to make sure I had no weird settings in the setup, which look like this: Usually BD RB downconverts to 640 or 448 if selected but was has changed now? Here are the logs: Code:
[15:23:09] BD Rebuilder v0.34.06 (beta) - Source: BREAKING_UP - Input BD size: 14,28 GB - Approximate total content: [01:25:55.000] - Target BD size: 7,84 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), CRF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [15:23:09] PHASE ONE, Encoding - [15:23:09] Extracting A/V streams [VID_00002] - [15:27:53] Reencoding: VID_00002 (1 of 1) - [15:27:53] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 25,000fps, 128.875 frames - [15:27:54] Performing CRF Prediction... - Analyzing 23,94 16,97 20,24 [19,94] - [15:31:31] Encoding using constant rate factor. - [17:03:11] Video Encode complete - [17:03:11] Reencoding audio tracks (if req'd) - [17:05:10] Multiplexing M2TS [17:09:05]PHASE ONE complete [17:09:05]PHASE TWO - Rebuild Started - [17:09:05] Rebuilding AVCHD file Structure [17:13:23] - Encode and Rebuild complete - WORKFILES folder removed. [17:13:24]JOB: BREAKING_UP finished. Code:
[Status] LABEL=BREAKING_UP VERSION=v0.34.06 (beta) SOURCE_SIZE=15328978944 SOURCE_VIDEO_SIZE=15328978944 TARGET_SIZE=8422162432 REDUCTION=.549427490426332 RESIZE_1080=0 AUDIO_TO_KEEP=deu;eng; SUBS_TO_KEEP=deu;eng; BACKUP_MODE=1 MOVIEONLY_TYPE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00002] AUDIO=110 PGS=1 M2TS_TARGET=8422162432 NSIZE=7286132736 FLINK=0 MLINK=0 |
#9145 | Link | |
jdobbs.softworks@gmail.com Last edited by jdobbs; 11th August 2010 at 16:48. |
#9146 | Link | |
#9147 | Link | |
First let me say the material has not been preprocessed - AnyDVD was used and that's all. The bigger of the two DD streams is 448 according to tsmuxer and TMT3 also states this bitrate during playback: Dont be confused by the fact that tsMuxeR declares stream #2 as GERMAN, which in fact is wrong - it's English. I DEselected the LPCM stream so normally it cannot be the source for a downconversion to 640kbps which leaves me to assuming that the 448kbps stream was changed. The BD output looks like this: Last edited by DK; 11th August 2010 at 17:18. |
#9148 | Link | |
#9149 | Link | |
![]() And it was not only tsMuxeR but as I said before: TMT3 said so as well and here is a screenshot of what MediaInfo says about the orignal m2ts: Last edited by DK; 11th August 2010 at 17:44. |
#9150 | Link |
H.264 stream does not contain fps field. Muxing fps=23.976
Who can help me with this error? I have tried the fullbackup without any error. It doesn't matter which target size I choose on movie only, the error occurs. Code:
[06:53:55] BD Rebuilder v0.34.07 (beta) - Source: ANGELS_AND_DEMONS_ORIGINAL - Input BD size: 33,59 GB - Approximate total content: [02:18:37.308] - Target BD size: 4,36 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - SHUTDOWN at completion enabled - Auto Quality: High Quality (Default), Two Pass - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=448 [06:53:56] PHASE ONE, Encoding - [06:53:56] Extracting A/V streams [VID_00505] - Extracting A/V to M2TS [VID_00505] - Extracting A/V from M2TS [VID_00505] - Error in attempt to extract audio/subs. - H.264 stream does not contain fps field. Muxing fps=23.976 - Error in attempt to extract audio/subs. - H.264 stream does not contain fps field. Muxing fps=23.976 [18:47:35] - Failed to retrieve audio, aborted Code:
[Options] MODE=1 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=1 TARGET_SIZE=4469 AUDIO_TO_KEEP=deu; SUBS_TO_KEEP=deu; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=0 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=1 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23450 [Paths] SOURCE_PATH=D:\FILME\ANGELS_AND_DEMONS_ORIGINAL\ WORKING_PATH=F:\FILME\GESCHRINKTE FILME\ANGELS AND DEMONS_5GB_03407_FORCED\ Code:
- Windows Version: 5.1 [2600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - FFDSHOW VC-1 set "disabled", WMP11, Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.34.0.7, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok |
#9152 | Link |
This reminds me. On my Vista64 SP1 machine, inspect.exe always crashes with error 13 "Type Mismatch" even if BDRB works perfectly. inspect.exe works as expected on Windows Seven 32 bit.
It's never given any report other than the error 13 dialog on the 64 bit PC.
"I don't want to belong to any club that would have me as a member." - Groucho Marx |
#9153 | Link |
Nope.
Same error message. Code:
[20:13:14] BD Rebuilder v0.34.07 (beta) - Source: ANGELS_AND_DEMONS_ORIGINAL - Input BD size: 33,59 GB - Approximate total content: [02:18:37.308] - Target BD size: 4,36 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - Auto Quality: High Quality (Default), Two Pass - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=448 [20:13:18] PHASE ONE, Encoding - [20:13:18] Extracting A/V streams [VID_00505] - Extracting A/V to M2TS [VID_00505] - Extracting A/V from M2TS [VID_00505] - Error in attempt to extract audio/subs. - H.264 stream does not contain fps field. Muxing fps=23.976 - Error in attempt to extract audio/subs. - H.264 stream does not contain fps field. Muxing fps=23.976 [20:37:46] - Failed to retrieve audio, aborted Code:
[Options] MODE=1 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=1 TARGET_SIZE=4469 AUDIO_TO_KEEP=deu; SUBS_TO_KEEP=deu; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=0 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=1 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23450 [Paths] SOURCE_PATH=D:\FILME\ANGELS_AND_DEMONS_ORIGINAL\ WORKING_PATH=F:\FILME\SHRINKED_MOVIES\ANGELS_AND_DEMONS_5GB_03407_FORCED\ |
#9154 | Link |
Which tool did you use for extracting the content?
Normally Angels & Demons should be more than just [VID_00505] so I wonder if some sort of preprocessing took place. This is what my log looked like: Code:
[01:37:06] PROCESSING BATCH FILE [1] ----------------------- [04:49:23] BD Rebuilder v0.30.04 (beta) - Source: ANGELS_AND_DEMONS - Input BD size: 33,59 GB - Approximate total content: [02:18:37.308] - Target BD size: 7,72 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - SHUTDOWN at completion enabled - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=1 HD=1 Kbs=448 [04:49:23] PHASE ONE, Encoding - [04:49:23] Extracting A/V streams [VID_00505] - [04:59:52] Reencoding: VID_00505 (1 of 34) - [05:35:13] Extracting A/V streams [VID_00506] - [05:35:23] Reencoding: VID_00506 (2 of 34) - [05:39:06] Extracting A/V streams [VID_00509] - [05:39:12] Reencoding: VID_00509 (3 of 34) - [05:41:30] Extracting A/V streams [VID_00511] - [05:41:41] Reencoding: VID_00511 (4 of 34) - [05:46:30] Extracting A/V streams [VID_00512] - [05:46:37] Reencoding: VID_00512 (5 of 34) - [05:49:16] Extracting A/V streams [VID_00514] - [05:50:22] Reencoding: VID_00514 (6 of 34) - [06:19:35] Extracting A/V streams [VID_00515] - [06:19:40] Reencoding: VID_00515 (7 of 34) - [06:21:53] Extracting A/V streams [VID_00517] - [06:21:56] Reencoding: VID_00517 (8 of 34) - [06:22:47] Extracting A/V streams [VID_00518] - [06:22:50] Reencoding: VID_00518 (9 of 34) - [06:23:58] Extracting A/V streams [VID_00520] - [06:24:50] Reencoding: VID_00520 (10 of 34) - [06:46:19] Extracting A/V streams [VID_00521] - [06:46:24] Reencoding: VID_00521 (11 of 34) - [06:48:17] Extracting A/V streams [VID_00523] - [06:48:25] Reencoding: VID_00523 (12 of 34) - [06:51:29] Extracting A/V streams [VID_00524] - [06:51:33] Reencoding: VID_00524 (13 of 34) - [06:52:46] Extracting A/V streams [VID_00526] - [06:53:52] Reencoding: VID_00526 (14 of 34) - [07:21:30] Extracting A/V streams [VID_00527] - [07:21:31] Reencoding: VID_00527 (15 of 34) - [07:22:06] Extracting A/V streams [VID_05032] - [07:22:49] Reencoding: VID_05032 (16 of 34) - [07:39:47] Extracting A/V streams [VID_00530] - [07:39:49] Reencoding: VID_00530 (17 of 34) - [07:40:24] Extracting A/V streams [VID_00532] - [07:40:30] Reencoding: VID_00532 (18 of 34) - [07:43:11] Extracting A/V streams [VID_00533] - [07:43:15] Reencoding: VID_00533 (19 of 34) - [07:44:28] Extracting A/V streams [VID_00535] - [07:44:37] Reencoding: VID_00535 (20 of 34) - [07:48:22] Extracting A/V streams [VID_00536] - [07:48:27] Reencoding: VID_00536 (21 of 34) - [07:50:19] Extracting A/V streams [VID_00538] - [07:50:26] Reencoding: VID_00538 (22 of 34) - [07:52:59] Extracting A/V streams [VID_00539] - [07:53:04] Reencoding: VID_00539 (23 of 34) - [07:55:16] Extracting A/V streams [VID_00542] - [07:55:19] Reencoding: VID_00542 (24 of 34) - [07:56:49] Extracting A/V streams [VID_00545] - [07:57:06] Reencoding: VID_00545 (25 of 34) - [08:04:20] Extracting A/V streams [VID_05033] - [08:04:22] Reencoding: VID_05033 (26 of 34) - [08:04:53] Extracting A/V streams [VID_00548] - [08:05:14] Reencoding: VID_00548 (27 of 34) - [08:13:34] Extracting A/V streams [VID_00550] - [08:14:28] Reencoding: VID_00550 (28 of 34) - [08:35:36] Extracting A/V streams [VID_00551] - [08:35:38] Reencoding: VID_00551 (29 of 34) - [08:36:22] Extracting A/V streams [VID_00553] - [08:36:44] Reencoding: VID_00553 (30 of 34) - [08:45:09] Extracting A/V streams [VID_00554] - [08:45:13] Reencoding: VID_00554 (31 of 34) - [08:46:43] Extracting A/V streams [VID_00556] - [08:48:16] Reencoding: VID_00556 (32 of 34) - [09:26:20] Extracting A/V streams [VID_00557] - [09:26:24] Reencoding: VID_00557 (33 of 34) - [09:27:28] Extracting A/V streams [VID_00559] - [09:28:13] Reencoding: VID_00559 (34 of 34) [09:41:58]PHASE ONE complete [09:41:58]PHASE TWO - Rebuild Started - [09:41:58] Rebuilding BD file Structure [09:53:26] - Encode and Rebuild complete [09:53:26]JOB: ANGELS_AND_DEMONS finished. ========================== |
#9155 | Link | |
In my BD stream window, i can see also the files as you have. With fullbackup mode there were no issues, only with movie-only mode. I have started now again with choosing the play list 00001. But I guess this will used automaticly, right? |
#9157 | Link | |
How I can fix this? Last edited by bluerip; 11th August 2010 at 22:21. |
#9158 | Link |
Ok. Cars is now ready. It did rebuild completely. But I had to confirm many oversize messages ang got round about 9,2GB oversize (target size 14,5GB, size in real 23,7GB).
Playback run with following issues: - Main movie has activated english subtitles (with original disk no sub is active without user activity) - playback completely hang up at the movie parts, that are more than one time on the disk but with different in movie text translations (ok, the first part at beginning with happy birthday 20 years pixar not) I have to skip them to continue playback. In the short movie "One man band" this works correctly. The other things seems to work. Log and INF I put into attachment. Will do Madagascar 2 now again to see how much the other fix solves problems (same issue as in Monster vs. Aliens) PS: Is there some problem with the forum software? I can't see since today screenshots anymore in Iron (is a "spyware" free version of the Chrome brwoser). Last edited by KarstenS; 11th August 2010 at 21:52. |
#9159 | Link |
Stupid me. I didnt realise that of couse your conversion stopped after trying to (unsuccessfully) extract [VID_00505]. Can't judge your screenshot yet so we'll wait for approval. Maybe you could have a look at my posts concerning Angels & Demons in the meantime: CLICK |
#9160 | Link | ||
I have tried the same movie with language english. It's not finished, but you can see it further than with German. Quote:
I need the German language with forced subs. In the setting I have marked only the German on the audio and subtitle languages. Limit to one track for each language is not marked. I am confused.... |
| Thread Tools | |
| Display Modes | |
