Thread Tools Display Modes
Old 28th April 2014, 22:34   #20141  |  Link
jdobbs
Originally Posted by Marban View Post
i set the ini to
OUTPUT_3D_ISO=1		n = 0/1 - 1=ON (default) - if set to "0", output is to a folder rather than ISO
and rebuild with "movie only" but nothing has chanced.
so i use better 2 Steps for a 3D ISO. BD Rebuilder and mux the m2ts to a 3D ISO with tsMuxer.
thanks for help.
It works. There are lots of people using it. I have done dozens of discs using it myself. You're doing something wrong.
I notice it looks like you've edited the HIDDENOPTS.TXT file. That's just a document -- if you're changing it there it has no effect. You have to edit the file called BDREBUILDER.INI in the BD Rebuilder folder.
jdobbs.softworks@gmail.com
Old 28th April 2014, 22:37   #20142  |  Link
jdobbs
this ist my ini and i set OUTPUT_3D_ISO=1
That isn't the INI file, that's only a document of available hidden options. Read my last post right above this one.
Here is the first line in the file you posted:
This file contains descriptions of settings that can be added to the BDREBUILDER.INI file
Old 28th April 2014, 23:31   #20143  |  Link
AmigaFuture
AmigaFuture's Avatar
I don't think I have "Cloud Atlas", but I'll look. No I haven't been able to repeat it -- and frankly I'm puzzled as to how it is even possible.
I'mmmmm trying to figure it also. Thus far it's the ONLY movie that's doing it. I'll rerip it...possible the first bad rip in a while. I did notice that it does it with either of the 3 Subtitles. I'll also check AnyDVD HD to see if there's a bug fix..?
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!!
AmigaFuture is offline   Reply With Quote
Old 28th April 2014, 23:56   #20144  |  Link
gonca
@jdobbs
@AmigaFuture
I'm running a backup of Cloud Atlas using the Alternate Settings to see if the problem occurs on my system.
gonca is offline   Reply With Quote
Old 29th April 2014, 00:21   #20145  |  Link
gonca
Can confirm the issue. PGS in VID 0058 only have one entry each, looks like a language identifier. I.E. [ENGLISH] according to BDSup2Sub
Old 29th April 2014, 00:25   #20146  |  Link
Marban
now i understand you, thanks
any important settings for the best Quality? i use very slow, normal Priority and open GOPs for encoding.
Marban is offline   Reply With Quote
Old 29th April 2014, 02:15   #20147  |  Link
AmigaFuture
Originally Posted by gonca View Post
@jdobbs
@AmigaFuture
Can confirm the issue. PGS in VID 0058 only have one entry each, looks like a language identifier. I.E. [ENGLISH] according to BDSup2Sub.
I updated AnyDVD program. I just reripped it, made a BD-50 (no reencode)..and used that to make an Alternate MKV output. Looks good. I'll now check it direct from the direct rip before processing with BD-RB 47.05, and if that functions (as I'm confident it will..) then AnyDVD HD was it. I'll modify this message soon.
Old 29th April 2014, 02:18   #20148  |  Link
jdobbs
@jdobbs
@AmigaFuture
I'll run "Cloud Atlas" with ALTERNATE settings tomorrow and see what gives...
Old 29th April 2014, 03:01   #20149  |  Link
AmigaFuture
Since you replied...I'll share this finding. The new BD-RB MKV from AnyDVD HD has the same challenge as I posted before. The other, processed by BD-RB is showing chapters and film time correct. Odd! I don't know enough of what you do, JDobbs, to...explain that. Nice to know I found a work-around for myself..hehe. More testing..
Old 29th April 2014, 14:12   #20150  |  Link
jdobbs
I don't understand what you're saying. You did it twice and one works while the other doesn't?
I did my disc with no issues -- but it doesn't appear to be the same version as yours.
Old 29th April 2014, 17:19   #20151  |  Link
Acerjen
Pacific Rim 3D
Has anyone tried Pacific Rim 3D? I tried encoding it to a BD25 and the picture is excellent. But at the 1:06:16 mark, the picture jumps ahead about 8-10 seconds and the audio stays the same, so the rest of the movie is out of sync. I do not know if this is a BD Rebuilder problem or a FRIM Encoder problem. I was curious if anyone else has tried this movie, and if so, what were your results? I do have the ini and other info I can post if needed. I did re-rip my disc and the problem occurs with the new rip as well. I do not believe my drive is bad, as I ripped other discs before and after this one and they successfully converted.
Any help or insight is greatly appreciated. Thanks.
Acerjen
Acerjen is offline   Reply With Quote
Old 29th April 2014, 19:06   #20152  |  Link
setarip_old
setarip_old's Avatar
@Acerjen
Hi!
If you read through this thead, you'll note that specific problem (halted video while audio has continued) has occurred with a fair amount of discs (2D as well as 3D).
I'd suggest that you once againg attempt to scrupulously clean your disc. If the problem persists, return it to the place of purchase for a new replacement disc...
setarip_old is offline   Reply With Quote
Old 29th April 2014, 19:41   #20153  |  Link
Sharc
Acerjen
As Setarip wrote, there have been issues with Pacific Rim. It seems to be a hopeless case......
See for example the discussion here.
Old 29th April 2014, 19:42   #20154  |  Link
kabster
kabster's Avatar
Acerjen
me... it should play nice in sync from start to finish ... unless your PR_3D rip is not a region B !!
I can't vouch/ be certain for other regions... !!
about the A/V playing out of sync, i have re-done all my movies because of that ↑ nuicance by using x264 internal LaVf as frame server .. and .. voila nomore A/V synch problems... that easy..
You might wanna try that too !!
P.S: tested many BD-25 (panasonic japan import 4x burned @6x using pioneer BDR-208EBK BDXL) in different stand alones like the ps3, philips BDP-3480 with 0,00% issues
Even BD-R brand Mediarange (midcode: LEGBRAS006) 6x certified , capable of writing them @10x with my pioneer do play very VERY NICE
succes,
kabster is offline   Reply With Quote
Old 29th April 2014, 20:13   #20155  |  Link
AmigaFuture
Not exactly. If have BD-RB process the rip to MKV Intact video and DTS to AC3, then the chapters and movie length show as 5 plus hours.
If I process the rip with BD-RB, in this case removing the stuff I don't want, to a BD-50 then use that output BD structure to create the MKV the the chapters and film time are as they should be. Why? I don't yet understand.
Do you follow now? If not, I'll type the steps? Let me know.
Mine comes from Amazon. Combo Pack; Blu-ray, DVD and Ultraviolet.
Old 29th April 2014, 21:18   #20156  |  Link
jdobbs
I guess I'm going to have to get that one for testing... just, please, assure me there is really an issue that can be repeated. I've been buying a lot of discs lately based on bug reports only to find they work fine... (Nurse 3D comes to mind). These 3D discs aren't cheap.
[Edit] I ordered it and should get it Thursday. It wasn't too bad, $18.
Old 29th April 2014, 22:14   #20157  |  Link
AmigaFuture
I'm trying "Cloud Atlas" from an almost stock INI and direct from rip. Maybe something in the settings is causing it? Testing now..
Edit 1: Hm...still same result. I'm removing ENABLE_TEST=1...as it was the only change I made. Should not affect it but will check. Doing test.
Old 29th April 2014, 22:14   #20158  |  Link
Sharc
The issue I was referring to was with the (SW) decoding of Pacific Rim 3D. Both DGMVCDecode and FRIM (both based on the same Intel library) produced a couple of reproducible short glitches as reported by a number of testers. The root cause of these glitches was never found, and the disc has eventually been put aside as an exceptional case as far as I remember.
I didn't retry since. It is definitely not a BD-RB problem, it is a stream or decoder pecularity.
Old 29th April 2014, 22:47   #20159  |  Link
jdobbs
Thanks. I think it might be a good exercise to look at it and see if I can find anything. You never know, the sun even shines on a dog's butt sometimes.
Old 29th April 2014, 23:36   #20160  |  Link
If you want to save buying the disk we can give you the stream fragment that fails.
Thread Tools
