#1 | Link |
![]() Join Date: Feb 2005
MP4 muxers
Maybe GPAC-MP4Box, there are a link to v2.2-rev0 here 2022-12-21
And MeGUI update load a v2.3 (rev 349) 2023-07-30 For latest stable release 2.2.1 27/04/2023 and Nightly builds https://gpac.io/downloads/gpac-nightly-builds/ Last edited by tebasuna51; 28th February 2024 at 14:30. |
#5 | Link |
l-smash can create mp4 files?
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 1st March 2024 at 11:29. |
#6 | Link |
I still use Yamb on occasion, but it can be a bit temperamental.
#8 | Link | |
Broadcast Encoder
MP4Box GUI 0.6.0.6, but it runs on an older version.
It will be totally fine for H.264 + AAC in MP4, though. ![]() Here: https://www.videohelp.com/software/My-MP4Box-GUI I prefer to do this, though: Quote:
#9 | Link |
My ver$ Yamb about box shows v2.0,
but Changelog shows, Code:
Changes for the 2.1.0.0 beta 2 release (2009/06/29) [Addons] - TS/M2TS Extraction is now managed by EAC3to. - QuickTime compatibility for AVC streams containing B-Frames. - appleTV compliancy (not tested on such device though...). - Windows Seven support. [Improvements] - Better Internal Files detection. - Better AC3-in-MP4 files creation. - Better MKVExtract detection. - Few tunings in the NSIS script. [Updates] - MediaInfo library (0.7.17) - MP4Box (0.4.6-dev_20090629) - MKVExtract (2.9.5) - EAC3to (3.16) [Regression] - Disable temporarily the ASS/SSA Converter. Need to find a better algorithm... [Fixes] - Fix splitting command lines errors. - Fix Matroska tasks convertion. - Fix mkvtoolnix libs missing from the installer. - Several other fixes. MediaInfo.dll libgpac.dll ea3to mkvextract Mp4Box Although probably older versions. I think I usually do one thing at once, then re-run Yamb again for any further operations. [avoids most problems] I could put the ver$ I have up if needed.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 29th February 2024 at 18:49. |
#10 | Link |
Yes, it is actually a whole software suite. You may only know L-SMASH Works which only uses the MP4 (or more generally, its ISO Base Media File) demultiplexer out of it in an Avisynth/VapourSynth source filter.
Unfortunately it is quite hard to find a standalone binary of the L-SMASH multiplexer today. I found an old one from 2014 by 06_taro who used to be a member here too... (and that link is dead now) Last edited by LigH; 29th February 2024 at 21:15. |
#11 | Link |
random user
maybe there is something suitable in my signature...
BeHappy Audio Transcoder > <Doom9 forum> <Gleitz forum> <GitHub> MP4.tool GUI for MP4Box & L-SMASH muxer > https://www.mediafire.com/folder/3i6y6cbkyhblm/MP4.tool |
#12 | Link | |
Use xxx --help to see the available commands. |
#13 | Link |
Make a GUI to use MP4Box is really easy, but add other tools to extract and check if streams (video, audio, subs) are mp4 compliants, and convert them if not, is more complicated and require maintain updated all the tools used.
Talking about MP4Box GUI's I recommend MeGUI with updated tools to extract and encode video and audio. Code:
Tool MeGUI Yamb MP4.tool My MP4Box GUI ------------ ----- ---- -------- -------------- MP4Box 2023 2009 2013 2013 installer MediaInfo 2018 2009 2014 ? not installed eac3to 2022 2009 - ? MkvExtract 2023 - 2014 ? tsMuxer 2023 - 2013 ? AviSynth 2020+ - - - ffmpeg 2022 - - - x264/x265 2023 - - - Last edited by tebasuna51; 1st March 2024 at 13:42. |
#14 | Link |
#15 | Link |
Life's clearer in 4K UHD
It would be great if someone could develop a new .mp4 muxer and GUI
#16 | Link |
New uploads (MSYS2, MinGW32 / MinGW64, GCC 13.2):
MP4Box 2.3-DEV-rev937-g69b32cebf-ab-suite GPAC 2.3-DEV-rev937-g69b32cebf-ab-suite Another interactive MP4/MKV remux GUI tool: BOX4 (not sure which multiplexers it uses internally) Last edited by LigH; 1st March 2024 at 22:18. |
#17 | Link |
Was there an MP4 muxer that allowed you to alter and amend certain parameters of an h.264 elementary stream prior to muxing?
#18 | Link |
H264 Patcher and BDTools maybe?
#19 | Link |
I think it had a GUI... It's a long time ago!
How mature is FFmpeg at .mp4 muxing?
#20 | Link |
I use avidemux from Mulder. I don't need do special treatement (demux, remux,...) but they are options to optimize for streaming and changing the time scale (I even don't know the utility of this). I can change the number of tracks in audio, even add from file. The mp4 muxed-remuxed is 100% compliant with my devices. I also use "LosslessCut", even the resulting video where equal to original, but I can do any elemental changes (rotate, change number of audio tracks,...). Is ffmpeg based, so compart their weakeness. And finally, I use tsmuxer, for quick demuxing (with the help of TsMuxerGui)
| Thread Tools | |
| Display Modes | |
