Thread Tools Display Modes
Old 6th February 2025, 18:50   #1541  |  Link
v0lt
Originally Posted by nji View Post
Could you de-activate the "Save" button if there is no project defined/ loaded?
I didn't understand anything. What "Save" button are you talking about?
v0lt is offline   Reply With Quote
Old 6th February 2025, 19:44   #1542  |  Link
nji
It's from the post just before the virustotal issue.
nji is offline   Reply With Quote
Old 13th February 2025, 18:45   #1543  |  Link
jay123210599
Three things:
1. How do I move 5 seconds forward and backward in VirtualDub2?
2. This is the information for my video:
Format                                   : Matroska
Format version                           : Version 4
File size                                : 339 MiB
Duration                                 : 23 min 43 s
Overall bit rate                         : 1 999 kb/s
Frame rate                               : 24.052 FPS
Encoded date                             : 2016-10-26 10:52:38 UTC
Writing application                      : mkvmerge v7.9.0 ('Birds') 64bit
Writing library                          : libebml v1.3.1 + libmatroska v1.4.2
Attachments                              : CLEARG.TTF
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L3
Format settings                          : CABAC / 6 Ref Frames
Format settings, CABAC                   : Yes
Format settings, Reference frames        : 6 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Bit rate                                 : 1 803 kb/s
Nominal bit rate                         : 2 246 kb/s
Width                                    : 720 pixels
Height                                   : 480 pixels
Display aspect ratio                     : 16:9
Original display aspect ratio            : 3:2
Frame rate mode                          : Variable
Original frame rate                      : 29.970 (30000/1001) FPS
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.217
Stream size                              : 306 MiB (90%)
Writing library                          : x264 core 120 r2164 da19765
Encoding settings                        : cabac=1 / ref=6 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2246 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:0.60
Default                                  : Yes
Forced                                   : No
When I extract images out of it, I want the resolution to be 853x480 instead. I tried adjusting the aspect ratio but it didn't work. Can someone help me?
3. Say I extracted an image from one video. But when I closed it (but not VirtualDub2) and opened another video, when I decided to extract an image from that video, it uses the name of the old video instead of the new one. How do I fix that?
jay123210599 is offline   Reply With Quote
Old 13th February 2025, 20:12   #1544  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
I told you how to do this here: https://forum.doom9.org/showthread.p...07#post2012807
Old 13th February 2025, 20:37   #1545  |  Link
jay123210599
Originally Posted by SeeMoreDigital View Post
But I want to do it naturally without using any filters.
Old 13th February 2025, 20:51   #1546  |  Link
SeeMoreDigital
That's not possible as the native 720x480 image pixel resolution needs to be 'resized' to 852x480 pixels!
Old 13th February 2025, 23:36   #1547  |  Link
jay123210599
That's not possible as the native 720x480 image pixel resolution needs to be 'resized' to 854x480 pixels!
And my other two questions?
Old 14th February 2025, 04:58   #1548  |  Link
v0lt
If you are cropping a frame in YUV 4:2:0 format, then cut off an even number of pixels on each side.
If you are using resize, then use the built-in filter functionality.
Filter: Resize > Codec-friendly sizing > Multiples of 2 (8 is better).
Regardless of the format, the final result should be a multiple of 2 (preferably 8).
This has already been written about here.
People are not obligated to answer all your questions. This is not an exam.
Old 17th February 2025, 13:33   #1549  |  Link
shekh
Go to frame (Ctrl+G)
Tab to "Jump to frame at time" field
type +5s or -5s
Old 18th February 2025, 00:20   #1550  |  Link
rgr
Originally Posted by v0lt View Post
Something is not quite working though. Today VDub reported to me twice that the script editor could not save the avs file. After a while the program crashed, and then it turned out that the avs file had zero length. Today it happened to me twice and I had to rewrite the avs script.
rgr is offline   Reply With Quote
Old 18th February 2025, 04:42   #1551  |  Link
v0lt
Please use the new version of the plugin from the VirtualDub2 v2.2.0.755 release or from the GitHub repository.
Old 19th February 2025, 15:43   #1552  |  Link
rgr
1. Filter data file (default Deshaker.log).
2. Folder with .vdproject file.
I load the project to 44282 -- I can leave the field empty, the plugin uses the current folder.
I load the same project to 667 -- I have to fill in the field with the full path (I don't know where it looks for it then, but not in the project path)..
OK, I figured out where the problem is.
1. If I first run VDub, and then *load the project via File->Load Project*, everything is OK. The plugin sees the project path as "current".
2. If I first run VDub, and then *drag the project into it*, the plugin saves its data in the VDub directory -- it sees this as "current" (I also had this entered as the startup directory in the shortcut from which I run VDub). But after deleting this data, it still does not see the project folder as current, but I have not checked what the "current" folder is for the plugin.
I do not know if this is how it should be, so I am reporting the problem.
(In the vdproject file, the project path is entered as // $location if that matters)
Old 19th February 2025, 19:22   #1553  |  Link
v0lt
VirtualDub2_v2.2.0.803_unicode
Test build. The application has been rewritten to use CharacterSet=Unicode in the project properties.
PS: updated to 2.2.0.803.
Old 22nd February 2025, 03:25   #1554  |  Link
isidroco
Will you consider changing /queryVersion reply to some # higher than older versions (ie: 45nnn )
isidroco is offline   Reply With Quote
Old 22nd February 2025, 04:44   #1555  |  Link
v0lt
I don't understand you.
Old 22nd February 2025, 11:18   #1556  |  Link
I dont offhand know how to show the /queryVersion thingy that he mentions (CLI is rusty).
But this is I think what he's going on about.
vudb64 /?
VirtualDub CLI Video Processor Version  (build 44282/release-AMD64) for AMD64
  /autorecover              Scan for auto-recover files
  /capture                  Switch to capture mode
  /capaudiorec [on|off]     Enable/disable capture audio recording
  /capaudioplay [on|off]    Enable/disable capture audio playback
  /capchannel <ch> [<freq>] Set capture channel (opt. frequency in MHz), use antenna:<n> or cable:<n> to force mode
  /capdevice <devname>      Set capture device
  /capfile <filename>       Set capture filename
  /capfileinc <filename>    Set capture filename and bump until clear
  /capfilealloc <size>      Preallocate capture file in megabytes
  /capstart [<time>[s]]     Capture with optional time limit (default is minutes, use 's' for seconds)
  /F <filter>               Load filter
  /edit <instance>          Open video filter configure dialog
  /h                        Disable exception filter
  /hexedit [<filename>]     Open hex editor
  /hexview [<filename>]     Open hex editor (read-only mode)
  /resetall                 Reset all settings to defaults
  /s <script>               Run a script
  /i <script> [<args...>]   Invoke script with arguments
  /cmd <command>            Run quick script command
  /c                        Clear job list
  /b <src-dir> <dst-dir>    Add batch entries for a directory
  /p <src> <dst>            Add a batch entry for a file (SaveAVI)
  /SaveAVI <src> <dst>
  /ExportViaEncoderSet <src> <dst> <set>
  /RunNullVideoPass <src>
  /SaveAVI * <dst>          (* to use source loaded with other commands)
  /RunNullVideoPass *
  /ExportViaEncoderSet * <dst> <set>
  /r                        Run job queue
  /master <file>            Join shared job queue in non-autostart mode
  /slave <file>             Join shared job queue in autostart mode
  /portable                 Switch to portable settings mode
  /priority <pri>           Start in low, belowNormal, normal, aboveNormal, high, or realtime priority
  /queryVersion             Return build number
  /safecpu                  Do not use CPU extensions on startup
  /min                      Start minimized
  /max                      Start maximized
  /topmost                  Create window as always-on-top
  /x                        Exit when complete
Maybe it dont properly return [EDIT: set errorlevel] the build number.
EDIT: from post #1539
set oldVDub= & REM space: Enable newer VDub2 commands: use color matrix, hide i/o video in status window
set xCompr=I& REM *I* default h264 vDub internal for new Vdub
IF not "%PARAM:ch264v=%" == "%PARAM%" set xCompr=H& REM *H* h264 vfw
IF exist "%vdloc%%vDubCli%" (  rem Check if old vdub version
  "%vdloc%%vDubCli%" /queryVersion >nul
  if not errorlevel 42475 ( REM if ver<42475 old version of virtualDub
    set noWavHeader= & REM don't use in new vdub versions
    set oldVDub=// & REM bars "// " comments out newer commands
    set xCompr=H& REM *H* default h264 vfw compressor for old Vdub
EDIT: Is this correct for cli logic ??? [maybe something like "if not errorlevel < 42475"
Old 22nd February 2025, 13:45   #1557  |  Link
v0lt
I think it is wrong to use the build number to compare executables of different projects with different executable file names.
If you want to know the version number, you can do it like this:
@ECHO OFF
SET FILE_NAME="VirtualDub2.exe"
FOR /F "USEBACKQ" %%F IN (`powershell -NoLogo -NoProfile -Command ^(Get-Item %FILE_NAME%^).VersionInfo.FileVersion`) DO (SET FILE_VERSION=%%F)
ECHO %FILE_NAME% %FILE_VERSION%
PAUSE
I will fix the "/queryVersion" command for the next release. But it will not give a number greater than the build number of the original VirtualDub 1.10.4.
Old 22nd February 2025, 16:45   #1558  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
This is only a teeny tiny thing, but when a video is 100% of the window width, but doesn't exceed the window height, it still has a raised border to the left and right.
Could that border be shifted off the edges of the window in such a case?
wonkey_monkey is offline   Reply With Quote
Old 22nd February 2025, 17:27   #1559  |  Link
LigH
LigH's Avatar
Yes, ERRORLEVEL comparison is implicitly "greater than or equal", but there are 3-letter verbose operators (e.g. "EQU").
https://ss64.com/nt/errorlevel.html
New German Gleitz board
Old 23rd February 2025, 00:24   #1560  |  Link
Ta LigH
Thread Tools
