#1321 | Link |
avlib_vdplugin 0.7.0.94
Fixed the use of audio encoders.
MPC-BE 1.8.9 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
#1323 | Link |
VDub2.0 with new plugins and VDub2.1 hang with my Avisynth script. Quite an extensive script, but old VDub2.0 works OK.
The program hangs, the CPU load is 0% and nothing happens. I can only kill the process. Any idea how to diagnose why this is happening? |
#1324 | Link |
avlib_vdplugin 0.7.0.94?
I removed the use of the plugin for Avisynth scripts. Please make a simple script with the problem to test. And upload it and the related files.
#1326 | Link |
Video > Copy output frame to clipboard (Ctrl+2)
#1328 | Link |
Paint > Ctrl+V > Cut (if necessary) > Save As > PNG...
Paint.NET > Ctrl+Alt+V > Ctrl+S > PNG... IrfanView > Ctrl+V > Ctrl+S > PNG...
#1329 | Link |
avlib_vdplugin 0.7.0.98
Improved ignoring of AviSynth scripts to prevent VirtualDub 2 interface from freezing in some situations.
#1330 | Link | ||
#1332 | Link | |
VirtualDub2 saves PNG sequence in 24-bit RGB format. And if avlib_vdplugin is used, saving the sequence may fail (there are problems with getting the right frame). Fine.
#1333 | Link |
How do I make ffmpeg as the default encoder (not as an external encoder) for all functions in VirtualDub2? I mean, how do I use it in VirtualDub2 for exacting frames and making image sequences, encoding videos, cutting/trimming videos, and burning in subtitles?
#1334 | Link |
There's no way you can.
#1335 | Link |
VirtualDub2 keeps producing and getting the wrong colors for images. What should I do?
Correct Colors: https://imgur.com/a/pXfCGwz Wrong Colors (VirtualDub2, what I got): https://imgur.com/a/YocRFx8 Here the information for my video, by the way: Code:
Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Format settings, Slice count : 4 slices per frame Codec ID : V_MPEG4/ISO/AVC Duration : 23 min 43 s Bit rate mode : Variable Maximum bit rate : 40.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Time code of first frame : 00:59:59:00 Default : No Forced : No Last edited by jay123210599; 6th August 2024 at 00:20. |
#1338 | Link |
If you use the CLI version of MediaInfo, add the parameter -f
Or use https://github.com/stax76/MediaInfo.NET and look in the "Advanced" results or the video stream results. There may be such fields present, but are not mandatory: Code:
colour_description_present : Yes colour_description_present_Source: Stream Color range : Limited colour_range_Source : Stream colour_primaries_Source : Stream transfer_characteristics_Source : Stream Matrix coefficients : BT.470 System B/G matrix_coefficients_Source : Stream |
#1339 | Link | |
Count : 392 Count of stream of this kind : 1 Kind of stream : Video Kind of stream : Video Stream identifier : 0 StreamOrder : 1 ID : 2 ID : 2 Unique ID : 1 Format : AVC Format : AVC Format/Info : Advanced Video Codec Format/Url : http://developers.videolan.org/x264.html Commercial name : AVC Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, CABAC : Yes Format settings, Reference frames : 4 Format settings, Reference frames : 4 frames Format settings, Slice count : 4 Format settings, Slice count : 4 slices per frame Internet media type : video/H264 Codec ID : V_MPEG4/ISO/AVC Codec ID/Url : http://ffdshow-tryout.sourceforge.net/ Duration : 1423090 Duration : 23 min 43 s Duration : 23 min 43 s 90 ms Duration : 23 min 43 s Duration : 00:23:43.090 Duration : 00:23:41:16 Duration : 00:23:43.090 (00:23:41:16) Bit rate mode : VBR Bit rate mode : Variable Maximum bit rate : 39959808 Maximum bit rate : 40.0 Mb/s Width : 1920 Width : 1 920 pixels Height : 1080 Height : 1 080 pixels Stored_Height : 1088 Sampled_Width : 1920 Sampled_Height : 1080 Pixel aspect ratio : 1.000 Display aspect ratio : 1.778 Display aspect ratio : 16:9 Frame rate mode : CFR Frame rate mode : Constant Frame rate : 23.976 Frame rate : 23.976 (24000/1001) FPS FrameRate_Num : 24000 FrameRate_Den : 1001 Frame count : 34120 Color space : YUV Chroma subsampling : 4:2:0 Chroma subsampling : 4:2:0 Bit depth : 8 Bit depth : 8 bits Scan type : Progressive Scan type : Progressive Delay : 0 Delay : 00:00:00.000 Delay : 00:00:00:00 Delay : 00:00:00.000 (00:00:00:00) Delay, origin : Container Delay, origin : Container Time code of first frame : 00:59:59:00 TimeCode_DropFrame : No Default : No Default : No Forced : No Forced : No Buffer size : 30000000 / 30000000 FrameCount_Source : General_Duration Duration_Source : General_Duration Last edited by jay123210599; 6th August 2024 at 02:19. |
#1340 | Link |
Many SDR rips do not have colorimetry data. This is a problem because players and video editors have to guess from the frame size, which can be wrong.
| Thread Tools | |
| Display Modes | |
