#81 | Link | |
BluRay Maniac
Second, you comparing two encoders like ferrari and tractor, both can reach speeds of 200km/h, downhill.... |
#82 | Link | ||
x264
Use search ... U will see how much x264 is better at same bitrate... Half blind people will see that There is no hardware encoder that is better in quality-wise then x264 Quote:
AT REALISTIC bitrate ? hahahaah What is main point of encoder ? Keep quality at smallest bitrate posible ... So compare x264 to that encoders you named at low bitrate and u will see for yourself. At big bitrate every encoder in world will be good. Shon3i gave good example for tractor and ferrari
#83 | Link | |
Banned
a dvd 9 can hold 8.5 gigs of data, blu-ray can hold up to 50 gigs and we have hard drives in the 3 terabyte range, why would you use ridiculously low bit rates for any encode? it reminds me of that seinfeld episode where kramer is test driving the saab, the needle hits "e" and he and the salesman decide to see how far they can go before they run out of gas and the car stalls. all i know is that i just priced out a new SB based build, i can get a good motherboard for $125, a 2500k for $180 and 4 gigs of ddr3 for about $100, as soon as i get my tax refund i'm switching to SB and i'll use the transcoding engine that allows me to encode 1080p at 100fps and you guys can stick with the software based encoder and keep telling yourselves that the quality is much better and it's just as fast as quick sync. when you sober up, the rest of the world will be waiting for you... |
#84 | Link | ||
x264
And what is point of encoder ?
Encoding at same bitrate as source ? :facepalm: Quote:
#85 | Link | |
Software Developer
![]() Join Date: Jun 2005
(Needless to mention that running the test at an absurdly low bitrate and then concluding that all encoders in the test look "horrible" would be just as meaningless)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 9th January 2011 at 23:47. |
#86 | Link | |
Banned
http://www.blu-ray.com/faq/ i do think that you touched on an important thought process, it does seem that x264 proponents are of the mind set that blu-ray bit rates are too high, they forget that uncompressed 8bit 1080p29.97 video uses 119 mega bytes per second, so even a bit rate of 30 mega bits per second is on the low side, x264 users seem convinced that they can drop that all the way to 10 mega bits per second (and lower) for 1080p29.97 video and somehow still maintain the same quality. just because they can't see the differences using the consumer grade 20 inch monitors coupled to their gaming graphics cards does not mean that the quality is the same, just that they need to look at the math, get their cataracts operated on and lay off the wild turkey. personally i think the "bit rate starve" mentality has it's origins in piracy and file sharing, people eager to conserve bandwidth so they try to transcode to as low a bit rate as possible so that downloads and uploads complete faster. it's silly, if you could achieve the same quality level these companies would never have invested millions in hd-dvd and blu-ray technology, they would have stuck with dvd9 and extended the spec to include h264/vc-1. |
#87 | Link | ||
). The "pro" here is that the final customer doesn't have the master as a reference to see if the problem is on the master or came up after compression.Probably in this "field" all the encoders have rooms for improvements (I think but above all I wish). Just as a note: this 40 days old "quick" comparison was made with an average bitrate of 35Mbps (with max set to full 40 Mbps). Considering your post, this result would qualify x264 as 'bad' (which, I think first of all, is not true), but anyway clearly demonstrate that even 35Mbps average can be not enough (for both encoders). I completely agree with you, even if it's true that a lot of times even official BDs have an average bitrate of 15-20 Mbps which (to me) is again low. Last edited by mp3dom; 10th January 2011 at 00:02. |
#88 | Link | |
Banned
in these cases the output should equal the input, i.e. size and bit rate in = size and bit rate out. in all other cases you are better off simply buying another hdd (at $90 for 1.5tb it's quite affordable). |
#89 | Link | |
BluRay Maniac
The whole point here is efficiency of some standard. I can't understand why then all of these standards and improvements if there is no real difference. H264 is made to be better than MPEG2. Otherwise why not keep Lossless.
Like for example one car spent 8 liters and another spent 15 liters, both driving at 160km/h. And someone then says that is impossible. And all cars need to spent 15 litres and higher to be faster. Quote:
#90 | Link | ||||
Software Developer
If state-of-the-art formats/encoders, such as H.264/x264, have proven that transparent quality can be preserved at even lower bitrates, then THAT is the reference other formats/encoders have to be compared to. (To give yet another car analogy: If you can choose between a Trabi and a Ferrari, would you pick the Trabi, just because both of them are significant faster than an oxcart? ^^) Quote:
![]() Quote:
There's nothing surprising or interesting about that... (And indeed using DVD-9 with H.264 and a good encoder would have been perfectly sufficient for distributing HD movies, but of course the industry prefers selling new hardware for new disc formats!)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 10th January 2011 at 00:55. |
#91 | Link | |||
In the grand scheme of things: from a company perspective, sure, it's cheaper to pump more CPU power and bytes into something, rather than spend a few years optimizing the code. Quote:
What about downscaling the video for various different resolutions, or simply downscaling it from 1080i to 720p if the the source really doesn't have that much optical resolution to begin with ? Also, you nicely ignored the fact that weasel was somewhat flabbergasted with your ideas. Though I'm sure you were a little too, when Windows 7 was released, and you noticed that it had the same or in same parts even lower system requitements than Windows Vista - ignoring the fact that if eg. MS spent the better part of a decade to optimize it (or really rebuild it from scratch), it'd run happily on a 486 /w 32 MB RAM. Continuing on the car MPG examples: Any people/companies competing for maximum fuel efficiency must be crazy then, even if they manage an order of magnitude more efficient use of whatever fuel used than a typical car (with a real-looking car). Disclaimer: no, I'm not a Mac user, I'm an Amiga user Last edited by AnonCrow; 10th January 2011 at 01:12. Reason: typos |
#92 | Link | |
Banned
x264 is the fastest software based encoder when using the "ultra fast" preset, i'll grant you that. be that as it may, using a x4 620, transcoding a 1080p blu-ray rip to a 15 mb/s h264 with ac3 audio mkv i'm lucky if i see 15 fps, tops. an SB cpu, using the quick sync engine, did a similar test on anandtech at 100 fps and that's without stressing any of the cpu cores. according to that very same review, a 6 core 12 thread core i7 980x completes the encoding pass of the x264 hd benchmark at 49 fps. downloading the benchmark and examining the test file as well as the benchmark script shows that the source is a 720p mpeg-2 and the encode target is a 4 mb/s 720p h264, no audio with the priority set to "real time". what does one need to be smoking to conclude that using x264 to encode a 4 mb/s 720 h264 at 49fps (if you'r lucky), with your cpu maxed out and priority set to real time is preferable to using the quick sync engine to encode a 15 mb/s 1080p, with audio no less, at 100 fps? furthermore, what kind of reality distortion field is needed to believe that an x264 encode, done at 4 mb/s and 720p will somehow be of higher quality than an encode done at 15 mb/s and 1080p? are all x264 users also mac users? |
#93 | Link |
Pointless discussion
![]() One group talks about encodes which are transparent to the source at very high level, other about something which looks good and is as small as possible (mainly for ripping and sharing over net) BD was created to give best possible quality for mass consumer (DVD started being not good enough on massive new TVs) and its 40Mbits is good enough to deliver it. It's not overdone, even for x264. Saying that x264 can achieve the same at 10Mbit as BD at 30Mbit is not true at all. If x264 can achieve the same transparency at 10Mbit than great- we can put whole series on 1 BD. It also means that other encoders can be improved. x264 can achieve much more than other encoders at 10Mbit, but it's no near close to transparency, which is achieved on BD discs. Question is if average consumer does need such a good quality like BD? He could probably live with much lower, but TVs getting bigger and bigger and heavily compressed footage will start being soft, blurred, not detailed. As deadrats said- don't turn DS into GOD- because he would done almost nothing without all doom9 members- it's their big job for all encodes and reporting any problems and giving suggestions. Many companies have great programmers, but it's lack of testing time, which stops them to make their product better. x264 has biggest testing community ever and free! Quality wise x264 is as good as pro encoders for BD usage (with some stronger points and some weaker), but in terms of worflow/features/speed lot worse, so none of big studio use it. In terms of other usage x264 is great and has clear quality advantage, but even so, most of the paid web content is not encoded with x264, but with Carbon Coder, Ateme and other hardware solution mainly because of the workflow. x264 is an engine- needs GUI and other bits around it to be more popular. Andrew Last edited by kolak; 10th January 2011 at 01:28. |
#94 | Link | ||
Software Developer
(1) Both encodes must come out the same average bitrate. If the one encoder came out at a higher average bitrate than the other one it encoded at a lower compression efficiency and thus had an unfair advantage in the speed comparison. (2) Both encodes must come out the same visual quality. If the one encoder produced a lower visual quality than the one, it encoded at a lower compression efficiency and thus had an unfair advantage in the speed comparison. Unless these points are ensured, the FPS numbers are absolutely meaningless. And I'm very suspicious about that
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 10th January 2011 at 01:18. |
#95 | Link | |||
Banned
why would you down rez it to 720p, i'm pretty sure i know what you're going to say, i just really want to read it for myself. Quote:
microsoft made a number of minor mistakes with vista, like changing the memory management model so that vista assumes that any free ram is wasted ram and caches all available ram as a consequence. win 7 does the same thing but the superior malloc() library is better at allocating and releasing ram as needed. furthermore vista was the first to feature a fully gpu accelerated gui (for the 3d portions, xp featured partial acceleration), using win 7 leads me to believe that m$ extended that acceleration to 2d surfaces. in so far as win 7 running on a 486, i don't care how much you optimized the code, if all of it was done using hand coded assembler, it still wouldn't run on an 486 cpu, the windows api, at least the dx parts, have been sse optimized since dx6 (back in the win2k days, modern windows Oses are all 32/64/128 bit hybrids, maybe an embedded version of win 7 could run on a 486 but that's it. |
#96 | Link | |
We have 3D already and that would be end of HD DVD... or.... your DVD-9 would be already to small to deliver 3D movies. Andrew Last edited by kolak; 10th January 2011 at 01:19. |
#97 | Link | ||
BluRay Maniac
Anyway there is encoder efficiency which work with human perception that control how to use bits and not spent on less noticeable things Quote:
#98 | Link |
Banned
and just like that software based x264 encoding is dead:
http://tmpgenc.pegasys-inc.com/ja/do...mw5.html#trial the english version will be available soon, in addition to licensing x264, pegasys will feature the cuda h264 encoder and support for quick sync. stick a fork in x264, it's done. |
#100 | Link | |
x264.nl
| Tags |
| media engine, x.264 |
| Thread Tools | |
| Display Modes | |
