#14561 | Link |
Nicolas Robidoux
Mathias:
What is your "anchor" colorspace? Actually, what is your "anchor" luma/luminance channel. What I most care about is whether it is a linear light channel, or whether it belongs to a perceptual color space. ----- It's cheaper to do something like a "colorspace transformation" just to luma/luminance, yes? Does it cost a lot to convert to linear light, or is it one of these things that are basically free? Are colorspace transformations implemented as LUTs or with computational code? ----- This is the key code in ImageMagick (actually, the IM6 code computes a LUT; what I'm showing is the IM7 code). This is way too complicated for all sorts of reasons. But it gives the idea, hopefully. Code:
% EEEEE N N H H AAA N N CCCC EEEEE %
% E NN N H H A A NN N C E %
% EEE N N N HHHHH AAAAA N N N C EEE %
% E N NN H H A A N NN C E %
% EEEEE N N H H A A N N CCCC EEEEE %
% MagickCore Image Enhancement Methods %
% Software Design %
% John Cristy %
% July 1992 %
% Copyright 1999-2012 ImageMagick Studio LLC, a non-profit organization %
% dedicated to making software imaging solutions freely available. %
% You may not use this file except in compliance with the License. You may %
% obtain a copy of the License at %
% http://www.imagemagick.org/script/license.php %
% Unless required by applicable law or agreed to in writing, software %
% distributed under the License is distributed on an "AS IS" BASIS, %
% WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. %
% See the License for the specific language governing permissions and %
% limitations under the License. %
% S i g m o i d a l C o n t r a s t I m a g e %
% SigmoidalContrastImage() adjusts the contrast of an image with a non-linear
% sigmoidal contrast algorithm. Increase the contrast of the image using a
% sigmoidal transfer function without saturating highlights or shadows.
% Contrast indicates how much to increase the contrast (0 is none; 3 is
% typical; 20 is pushing it); mid-point indicates where midtones fall in the
% resultant image (0 is white; 50% is middle-gray; 100% is black). Set
% sharpen to MagickTrue to increase the image contrast otherwise the contrast
% is reduced.
% The format of the SigmoidalContrastImage method is:
% MagickBooleanType SigmoidalContrastImage(Image *image,
% const MagickBooleanType sharpen,const char *levels,
% ExceptionInfo *exception)
% A description of each parameter follows:
% o image: the image.
% o sharpen: Increase or decrease image contrast.
% o contrast: strength of the contrast, the larger the number the more
% 'threshold-like' it becomes.
% o midpoint: midpoint of the function as a color value 0 to QuantumRange.
% o exception: return any errors or warnings in this structure.
ImageMagick 6 has a version of this function which uses LUTs.
Sigmoidal function Sigmoidal with inflexion point moved to b and "slope
constant" set to a.
The first version, based on the hyperbolic tangent tanh, when combined with
the scaling step, is an exact arithmetic clone of the the sigmoid function
based on the logistic curve. The equivalence is based on the identity
1/(1+exp(-t)) = (1+tanh(t/2))/2
(http://de.wikipedia.org/wiki/Sigmoidfunktion) and the fact that the
scaled sigmoidal derivation is invariant under affine transformations of
the ordinate.
The tanh version is almost certainly more accurate and cheaper. The 0.5
factor in the argument is to clone the legacy ImageMagick behavior. The
reason for making the define depend on atanh even though it only uses tanh
has to do with the construction of the inverse of the scaled sigmoidal.
#if defined(MAGICKCORE_HAVE_ATANH)
#define Sigmoidal(a,b,x) ( tanh((0.5*(a))*((x)-(b))) )
#else
#define Sigmoidal(a,b,x) ( 1.0/(1.0+exp((a)*((b)-(x)))) )
#endif
Scaled sigmoidal function:
( Sigmoidal(a,b,x) - Sigmoidal(a,b,0) ) /
( Sigmoidal(a,b,1) - Sigmoidal(a,b,0) )
See http://osdir.com/ml/video.image-magick.devel/2005-04/msg00006.html and
http://www.cs.dartmouth.edu/farid/downloads/tutorials/fip.pdf. The limit
of ScaledSigmoidal as a->0 is the identity, but a=0 gives a division by
zero. This is fixed below by exiting immediately when contrast is small,
leaving the image (or colormap) unmodified. This appears to be safe because
the series expansion of the logistic sigmoidal function around x=b is
1/2-a*(b-x)/4+...
so that the key denominator s(1)-s(0) is about a/4 (a/2 with tanh).
#define ScaledSigmoidal(a,b,x) ( \
(Sigmoidal((a),(b),(x))-Sigmoidal((a),(b),0.0)) / \
(Sigmoidal((a),(b),1.0)-Sigmoidal((a),(b),0.0)) )
Inverse of ScaledSigmoidal, used for +sigmoidal-contrast. Because b
may be 0 or 1, the argument of the hyperbolic tangent (resp. logistic
sigmoidal) may be outside of the interval (-1,1) (resp. (0,1)), even
when creating a LUT from in gamut values, hence the branching. In
addition, HDRI may have out of gamut values.
InverseScaledSigmoidal is not a two-sided inverse of ScaledSigmoidal:
It is only a right inverse. This is unavoidable.
static inline double InverseScaledSigmoidal(const double a,const double b,
const double x)
const double sig0=Sigmoidal(a,b,0.0);
const double sig1=Sigmoidal(a,b,1.0);
const double argument=(sig1-sig0)*x+sig0;
const double clamped=
argument < -1+MagickEpsilon
-1+MagickEpsilon
( argument > 1-MagickEpsilon ? 1-MagickEpsilon : argument )
return(b+(2.0/a)*atanh(clamped));
#else
argument < MagickEpsilon
MagickEpsilon
return(b-log(1.0/clamped-1.0)/a);
#endif
MagickExport MagickBooleanType SigmoidalContrastImage(Image *image,
const MagickBooleanType sharpen,const double contrast,const double midpoint,
#define SigmoidalContrastImageTag "SigmoidalContrast/Image"
#define ScaledSig(x) ( ClampToQuantum(QuantumRange* \
ScaledSigmoidal(contrast,QuantumScale*midpoint,QuantumScale*(x))) )
#define InverseScaledSig(x) ( ClampToQuantum(QuantumRange* \
InverseScaledSigmoidal(contrast,QuantumScale*midpoint,QuantumScale*(x))) )
CacheView
*image_view;
MagickBooleanType
status;
MagickOffsetType
progress;
ssize_t
y;
Convenience macros.
assert(image != (Image *) NULL);
assert(image->signature == MagickSignature);
if (image->debug != MagickFalse)
(void) LogMagickEvent(TraceEvent,GetMagickModule(),"%s",image->filename);
Side effect: may clamp values unless contrast<MagickEpsilon, in which
case nothing is done.
if (contrast < MagickEpsilon)
return(MagickTrue);
Sigmoidal-contrast enhance colormap.
if (image->storage_class == PseudoClass)
register ssize_t
i;
if (sharpen != MagickFalse)
for (i=0; i < (ssize_t) image->colors; i++)
if ((GetPixelRedTraits(image) & UpdatePixelTrait) != 0)
image->colormap[i].red=ScaledSig(image->colormap[i].red);
if ((GetPixelGreenTraits(image) & UpdatePixelTrait) != 0)
image->colormap[i].green=ScaledSig(image->colormap[i].green);
if ((GetPixelBlueTraits(image) & UpdatePixelTrait) != 0)
image->colormap[i].blue=ScaledSig(image->colormap[i].blue);
if ((GetPixelAlphaTraits(image) & UpdatePixelTrait) != 0)
image->colormap[i].alpha=ScaledSig(image->colormap[i].alpha);
else
image->colormap[i].red=InverseScaledSig(image->colormap[i].red);
image->colormap[i].green=InverseScaledSig(image->colormap[i].green);
image->colormap[i].blue=InverseScaledSig(image->colormap[i].blue);
image->colormap[i].alpha=InverseScaledSig(image->colormap[i].alpha);
Sigmoidal-contrast enhance image.
status=MagickTrue;
progress=0;
image_view=AcquireAuthenticCacheView(image,exception);
#if defined(MAGICKCORE_OPENMP_SUPPORT)
#pragma omp parallel for schedule(static,4) shared(progress,status) \
dynamic_number_threads(image,image->columns,image->rows,1)
#endif
for (y=0; y < (ssize_t) image->rows; y++)
register Quantum
*restrict q;
register ssize_t
x;
if (status == MagickFalse)
continue;
q=GetCacheViewAuthenticPixels(image_view,0,y,image->columns,1,exception);
if (q == (Quantum *) NULL)
status=MagickFalse;
continue;
for (x=0; x < (ssize_t) image->columns; x++)
register ssize_t
i;
if (GetPixelMask(image,q) != 0)
q+=GetPixelChannels(image);
continue;
for (i=0; i < (ssize_t) GetPixelChannels(image); i++)
PixelChannel
channel;
PixelTrait
traits;
channel=GetPixelChannelChannel(image,i);
traits=GetPixelChannelTraits(image,channel);
if ((traits & UpdatePixelTrait) == 0)
continue;
q[i]=ScaledSig(q[i]);
else
q[i]=InverseScaledSig(q[i]);
if (SyncCacheViewAuthenticPixels(image_view,exception) == MagickFalse)
status=MagickFalse;
if (image->progress_monitor != (MagickProgressMonitor) NULL)
MagickBooleanType
proceed;
#pragma omp critical (MagickCore_SigmoidalContrastImage)
#endif
proceed=SetImageProgress(image,SigmoidalContrastImageTag,progress++,
image->rows);
if (proceed == MagickFalse)
status=MagickFalse;
image_view=DestroyCacheView(image_view);
return(status);
#14562 | Link | |
Availability of a special purpose sharpness filter will definitely shift resampling preferences. Last edited by TheLion; 9th October 2012 at 17:43. |
#14563 | Link |
Nicolas Robidoux
Mathias:
Sorry. I was not clear. What I invented was using sigmoidal-contrast to do better upsampling. Another way to put it is that I invented a parameterized family of color spaces which help get better results when enlarging (upsampling, actually: does not need to be orthogonal). The code I show above was mostly written by me. It's based on earlier version written by, I believe, Anthony Thyssen and Cristy with some help from others who I can't all list without digging (Fred Weinhaus is one of them, and there is a textbook involved). To give you the most optimal code, I need to know a few things about how you do things. As I mentioned, the ImageMagick code is way too complicated because it is mostly used to do other things than what I call "sigmoidizing". ----- Makes more sense? Last edited by NicolasRobidoux; 9th October 2012 at 17:53. |
#14564 | Link | |
So everything checked, including 10-bit and 16-bit formats as well as RGB 32 & 24?
SETUP: Win 10/MPC-HC/LAV/MadVR HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750 |
#14565 | Link | ||
Yes, that makes a lot of sense, thanks!
#define Sigmoidal(a,b,x) ( tanh((0.5*(a))*((x)-(b))) ) #define Sigmoidal(a,b,x) ( 1.0/(1.0+exp((a)*((b)-(x)))) ) Last edited by madshi; 9th October 2012 at 17:56. |
#14567 | Link |
Nicolas Robidoux
Mathias:
================== Sigmoidization HOW TO ================== Let me explain things thus, and we can sort out the nitty gritty later. I've always done sigmoidization separately on each channel of a physically linear color space which in ImageMagick is linear RGB with sRGB primaries. So, let's suppose that we have one channel of image data x which is strongly constrained to the interval [0,1] and which can reasonably be interpreted as one component of linear light. I understand that in general there may be mild over- or undershoots, resulting from color space conversion (it has to do with negative coefficients in transformation matrices when things are properly normalized). If there may be over and undershoots, let me know and I'll tell you how to fix things. First, choose a contrast. Like in the ImageMagick code, let's call the contrast "a". a should be a float > 0. As a approaches 0, sigmoidization has less and less effect, so you may as well skip it. I generally like values between 7 and 12. If tanh is in your math library, it should compute faster than the formula that uses exponentials, because tanh is a very easy function to approximate. I can also provide fast approximations (given a bit of time). Or I can give you the formulation in terms of the exp function. Ideally, though, you have access to both tanh and atanh (the hyperbolic tangent and its inverse). Have the following constant set: s = tanh(0.25*a) (This is equal to Sigmoidal(a,1) = -Sigmoidal(a,0) because tanh is odd.) Step 1: Convert your input to the "sigmoidal color space", that is, "replace" every x by the value y computed as follows: y = 0.5 + (2.0/a) * atanh(-s+(2.0*s)*x) <- friendly to multiply-add Now, we are in the "sigmoidal color space". You don't need to clamp: If your original x was in [0,1], y is in [0,1] too. (Again: I know how to fix things if there may be over and undershoots in the x data.) Step 2: Upsample as usual, using the y values. Let's say that we get a pixel value of w. Step 3: Convert w back to "linear color space": z = tanh((0.5*a)*(w-0.5)) = tanh((-0.25*a)+(0.5*a)*w) <- friendly to multiply-add final value = (z+s)/2s = 0.5+(0.5/s)*z Only clamp if you want to. Step 3 does not care about what interval w is in. ----- That's it! Last edited by NicolasRobidoux; 9th October 2012 at 20:42. |
#14568 | Link |
Thank you, that looks easy enough!!
![]() Two problems: (1) Pixel shaders can do "atan", "tanh" and "exp", but not "atanh", unfortunately. (2) Black is 0.0 and white is 1.0, correct? In that case: Yes, there may be values outside of [0,1]. Not only from YCbCr -> RGB conversion, but some movies also contain BTB (black than black) and WTW data. How can I solve that? Thanks!! |
#14569 | Link | |
Nicolas Robidoux
Can you determine ahead of time an (ideally reasonably tight) interval which each channel cannot overshoot (after conversion to linear light or what resembles it)? (I'm sure computing the min and max in each channel for the whole movie is not an option.) ----- The atanh issue is not a big deal. Just need to sit down and do algebra. Atanh is often not included because it's so easy to reconstruct. |
#14570 | Link |
Nicolas Robidoux
Mathias:
No need to do algebra: http://mathworld.wolfram.com/Inverse...icTangent.html. atanh(x) = 0.5 * log((1+x)/(1-x)) |
#14572 | Link | ||
[-0.0029842504073062995363224069370219,1.2143440435408780674380747705496] Quote:
#14573 | Link | |
#14574 | Link |
XP32
Catalyst 12.4,HD 4770 ZP 5.02 Hello,Madshi everything is fine here but I just can't select the Intel MPEG2 decoder (While the libav can be without any pb).ZP uses the Cyberlink decoder (Wich ouputs 4:2:2...). Is it a question of priority ? Thank you. Last edited by Luv; 9th October 2012 at 21:12. |
#14575 | Link |
Ok, I've implemented the Sigmoidal contrast stuff and it seems to work pretty well. I like the results better compared to the "pretend linear" hack. Here they are for comparison:
jinc3 normal -|- jinc3 hack -|- jinc3 sigmoidal To my eyes the "sigmoidal" image clearly looks best. I've still left the anti-ringing filter enabled, though. Although the "sigmoidal" stuff does reduce the ringing artifacts, it doesn't completely remove them. So image quality is still noticeably better with the added anti-ringing filter on top. So, only 2 questions remaining: (1) Which is the "best" sigmoidal contrast? I've seen 7.5 (named with "safe") and 11.5. The image from above is with 11.5, which I prefer with this test image. Should I always use 11.5? Or would that be a bad idea? (2) Still need to handle those out of [0,1] values somehow. Thanks a lot, Nicolas, with your help upscaling quality just made another step forward in madVR...
#14577 | Link | |
I watch my Korean tv shows always 1080p quality, on the laptop's full hd screen or by hdmi on a full hd led tv. The laptop also has an overclock button on it, so that if it ever stutters(never happened), then I just push it then the processor speed will increase plus the graphic processing speed. This is the laptop, http://nl.msi.com/product/nb/GT683.html Cheers. Don't forget to enable the "Hardware acceleration: LAV CUVID" Last edited by sunnah; 9th October 2012 at 21:08. |
#14580 | Link |
Nicolas Robidoux
Mathias:
Here's the fix (or, more precisely, here is "a" fix, since I am not enforcing symmetry w.r.t black (0) and white (1) and I'm not 100% sure this is the best choice): The constant s of my HOW TO is strictly between 0 and 1. (In the interval (0,1), which I think some Europeans write ]0,1[.) Let's assume that the interval in which every single channel belongs to is contained in (A,B). Note that I don't want the bounds to be attained. In the case of [-0.0029842504073062995363224069370219,1.2143440435408780674380747705496], I'd use something like A=-0.00298426 and B=1.214345. That is, I'd enlarge the interval by some epsilon on each side to make sure that the bounds cannot be reached. If I was in double precision, I'd use something tighter, of course. What you are going to do is that you are going to fix things so that (A,B) is mapped to (-1,1) by the transformation x -> -s+(2.0*s)*(b+m*x) A little bit of algebra says that this is accomplished by choosing m = (1/L)/s and b = 0.5 + (D/L)/s where L = B-A and D = -0.5*(B+A) ----- So, all you have to do is add a preliminary step that replaces x by b+m*x, and add a final step that replaces "final value" by (-b/m)+(final value)/m. So, it adds two multiply-adds: one at the beginning, and one at the end. |
| Tags |
| direct compute, dithering, error diffusion, madvr, ngu, nnedi3, quality, renderer, scaling, uhd upscaling, upsampling |
| Thread Tools | |
| Display Modes | |
