#14501 | Link | |
I was under the impression that there is always a conversion from 16-235 to 0-255 at some point along the chain when you're using a PC because video cards don't like 16-235. If you set MadVR to 16-235 you're getting 1 video card up-conversion, 1 video card down conversion: 16-235 source MadVR converts to RGB; upsamples chroma in 16-235 colorspace (No BTB/WTW color information at all) After MadVR, video card converts 16-235 to 0-255, does its thing Video card converts back down to 16-235 and outputs 16-235 You're better off doing the following (1 MadVR up-conversion, 1 video card down-conversion): 16-235 source MadVR converts to RGB, upsamples chroma in 0-255 colorspace Video card converts back down to 16-235 and outputs 16-235 (Lose BTB/WTW color information here, which is later) Best case is only 1 MadVR up-conversion: 16-235 source MadVR converts to RGB, upsamples chroma 0-255 colorspace Video card outputs 0-255 (Keep BTB/WTW) Last edited by Moony349; 8th October 2012 at 22:24. |
#14502 | Link | ||
Bicubic's negative blur makes things 'pop' like the the aforementioned darbee darblet for free. Leaving default at 0 would behave as current bicubic and users may find something they really like by adjusting blur, like me. Negative blur is becoming a common suggestion to gain sharpness without affecting speed in avisynth. Quote:
#14504 | Link |
regarding the seeking bar, would it be possible to add additional time information when seeking, the time within a movie the mouse is moving the seeking bar? would be way easier to find specific scenes or spots.
guess you could do it either when the mouse is dragging the seeking bar or also when hovering over different places of the seeking with the mouse.
#14505 | Link |
Nicolas Robidoux
Note: I have never liked Jinc 4 (EWA Lanczos 4-lobe in ImageMagick speak) for natural images. Even with the deblur optimized, it is a very unusual scheme, very different in character from Jinc 3.
I may have to triple check on this, but my opinion right now is that if you are going to go higher than Jinc 3 lobes, skip 4 and go up to 5. Also: The "best" deblurs for Jinc depend on the number of lobes. I'll try to be more specific in a future post. Last edited by NicolasRobidoux; 9th October 2012 at 00:33. |
#14506 | Link | |
I have it configured like you say (I think), 0-255 hdmi, 0-255 in madvr and 0-255 in TV.
SETUP: Win 10/MPC-HC/LAV/MadVR HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750 |
#14507 | Link | |
On all systems except system 2. System 2 actually worked correctly with all content for the first time after testing with 0.83.x builds and has ever since. So whatever deinterlacing logic you changed at that point “fixed” this legacy 4000 series Radeon system but has caused problems with much newer 6000 series systems Did the original problem only occur with interlaced content, btw, or also with progressive content? Originally, I saw it with any content, just jump around with any file that I tested and it would eventually freeze the que/s and start dropping frames. Not sure if I understand this correctly. So basically deinterlacing doesn't work, but progressive content plays perfectly. Did I get that right? Not sure why deinterlacing doesn't work. The test build was a quick hack of moving some v0.82.5 code back into the v0.84.2 source code. It's *really* difficult because there was a very big change between v0.82.5 and v0.83.0 in the source code. The change itself shouldn't do much, but it makes it hard for me to create versions that sit between v0.82.5 and v0.83.0. With interlaced content, the test build madVR actually crashes and generates the crash reports that I gave a link to. It crashes and you get a black screen, no video at all and only sound with the AMD 6570 systems. With the NVidia system just massive frame drops. With all other progressive content that I tested I did not see any problems, except that on a “qualitative” basis things seemed to take a little longer to load up and start. Did System 2 have issues with the official v0.84? No … As noted above, system 2 worked well with all 0.83-0.84 builds that I tested. But it actually did not work correctly with interlaced content with 0.82.5 … It actually worked correctly with the first version of 0.83.x that I tested and has ever since … Yes, there was a change in deinterlacing logic. Which is the code which I tried to revert in the best build I made for you. Again … thanks for the great work and hope this helps.
MPC-HC and MPC-BE (latest), MadVR 0.92.17, LAV 0.73.1 Intel NUC w_650 internal, Roku Ultra, Nvidia Shield, Apple TV 4K PLEX Server with QUADRO 2000 Windows 10 Pro (all latest updates) |
#14510 | Link |
Looks like Jinc 3 taps with anti-ringing on image upscaling runs fine on GTX 285 & I5-750, I get few dropped frames and usually just one delayed frame when fullscreening. (Running windowed mode.)
Can someone explain me what is the difference in Chroma and Luma(Now "Image") (Up)scaling? (Or link to it, I have a feeling it's been asked more than twice already) I have Chroma upscaling set as SoftCubic 100, without Anti-ringing, and it has no ringing so there would be no difference I guess? When SoftCubic is set to 100 and you activate anti-ringing it makes SoftCubic go to 50 automatically. (For the first time, after you set it back to 100 you can activate it but I guess that's meant to show there's no point in doing so?) Thanks. |
#14512 | Link | |
To check your colorspace, what I've found works best is downloading the mp4 version of these test videos: http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration Use the APL clipping (Basic Settings #2) to make sure your colors are correct. Nvidia cards notoriously will output 16-235 over HDMI unless you hack the monitor INF or use Madshi's madnvlevelstweaker (I haven't tested it but I assume it works). You want to be able to see blinking in the white area up to at least 234 (And black down to 17 or so ideally). If the whole screen is blinking your card is probably converting down to 16-235 and you should try using madshi's tweak. |
#14513 | Link |
Nicolas Robidoux
Mathias:
IMHO, instead of adding more lobes to Jinc (3 is enough), I'd add quadratic B-spline-windowed Jinc 3-lobe with no deblur ("blur=1") or with the same deblur you use with Jinc if it's easier. Examples: sigmoidized EWA quadratic B-spline windowed Jinc 3-lobe. (I do realize you have many many many other things to do.) Last edited by NicolasRobidoux; 9th October 2012 at 03:51. |
#14515 | Link |
Chroma upscaling: Jinc 8 taps
Image upscaling: Jinc 8 taps Image downscaling: Lanczos 8 taps (I have the anti-ringing option enabled on everyone of them. All work great on the NVIDIA GTX 570M without dropped/delayed frames. The image and colours of 1080p, 720p and below are magnificent. And the display modes option also works really well for me. Keep up the good work Madshi. Last edited by sunnah; 9th October 2012 at 05:56. |
#14516 | Link |
sunnah:
Chroma upscaling: Jinc 8 taps Image upscaling: Jinc 8 taps Image downscaling: Lanczos 8 taps (I have the anti-ringing option enabled on everyone of them. All work great on the NVIDIA GTX 570M without dropped/delayed frames. The image and colours of 1080p, 720p and below are magnificent. And the display modes option also works really well for me. Keep up the good work Madshi.[/COLOR][/COLOR] do you play 60fps video? |
#14517 | Link |
Most of the time I run 30fps (Korean/Japanese tv shows) and 24fps videos. (the display ofcourse changes with the framerate, but 60fps videos also worked well without problems.)
#14518 | Link | |
my gtx550ti can only run jinc3 without antiring when play 720p 60fps! |
#14520 | Link | |
I use mpc+madvr+ffdshow video audio+haali +SVP+reclock but i do not use LAV video use soft decoding maybe gtx570 is much greater than gtx550ti..... |
| Tags |
| direct compute, dithering, error diffusion, madvr, ngu, nnedi3, quality, renderer, scaling, uhd upscaling, upsampling |
| Thread Tools | |
| Display Modes | |
