#63761 | Link | ||
A small example. SSIM2D100 + AB100 looks good in most cases and is much better than Bicubic150 or 1D. But in some cases it looks blurry. https://imgsli.com/MTQ3OTU5 In this scene from The Hobbit, Bicubic150 is preferable to my eyes. That's why I don't like the combination of 2D with AB above 75%. What do others think? What combination of SSIM1D/2D and AB are you using? Is any AB required for SSIM1D? What do you think? |
#63763 | Link |
I don't downscale any more as I have a 4K set, but 2D was quite superior to 1D. After my initial review of AB I decided I didn't find it useful, better imo to just reduce the sharpness of the display, but it all depends.
#63764 | Link | |
The "enhance detail" sharpener kind of enhances that too, along with texture details like wood grain will look more detailed. But the downside is it also enhances compression artefacts, so I don't use a value more than about 0.5 for compressy SD and about 1.0 for a very high quality DVD remux.
I'm quite happy with Lanczos for scaling and then using sharpeners if the source is soft. To me that makes more sense to do the sharpening separately as it gives me more control over the type of sharpening for the source (using profiles for convenience). Whereas I'm not sure how 1D100 might react with certain source types so I'd have to do a lot of trial and error. I'm not really seeing much meaningful difference in your Hobbit comparison. Small differences, but nothing that would cause me to pick one over the other. Maybe I need to look under better lighting. Quote:
#63765 | Link | ||
you don't want to show the frame as fast as possible you want to show it for a very exact time . is it possibile to make VRR work for video yes absolutely but that's unlikely to happen with madVR taking current development. even HDMI has VFR for video now. BTW.75 hz freesync devices are a pretty much fake usually having a range of 48-75 hz to make freesync work making it useless. low end devices are not rarely utterly broken too. even freesync on LG OLED TVS is objectively broken and they are not cheap. |
#63766 | Link |
flossy, I have an mkv that is a bt.601/pal/50 fps from a dvd. It's poor quality and the original source is from decades ago.
Resolution is 720x576. I decided to set the display resolution to 720x576 and just let the monitor upscale the image to the screen dimensions which is the same process I follow for 1080p and it works well as madvr is only handling the chroma in that case. However, what I am seeing here is that there still needs to be some image scaling in the x dimension because of the whole square vs rectangular pixel aspect ratio. If I select square, it will turn off madvr scaling but it will squish in the sides a little. If I leave it on default/4:3 it will look more normal, but then x dimension scaling comes into play.. What image upscaling algo are you using in the situation where you are only scaling in X and only for the pixel not a different resolution? Catmull-rom looks ok, and looking at the formula the b value is 0, so it's probably a good choice.. wonder if there's a better choice? PS. Have you tried your bt.601/PAL DVDs in VLC? I'm looking at the mkv in VLC and the colours and gamma are different from how madvr is doing it--richer and not as washed out. Interesting.. twiddling about with the VLC renderer choices, selecting opengl or d3d9 makes it washed out, but selecting d3d11 or auto makes it darker and richer like how they should look. Last edited by Sunspark; 18th January 2023 at 08:30. |
#63767 | Link | |
Also, there is this new thing called VESA MediaSync. It claims its main purpose is elimination of 3:2 pulldown. Gimmick or gamechanger? Last edited by kopija; 18th January 2023 at 08:55. |
#63768 | Link |
MediaSync is not a new feature, just a standard set of tests that displays can be certified against, which is far more lenient then the gaming tests.
That does not change the situation that video presentation APIs on Windows are not designed to work with what we need for video - exact presentation at a pre-determined time.
#63769 | Link | |
sleep time the render call and pray that it works :-)
so you can get the claim on most devices. |
#63770 | Link | |
Can you send the file so I can check it out? I need to see what MadVR chooses for aspect ratio, matrix, primaries & limited range on its debug screen. It will also say whether it's guessing or getting that info from upstream decoder. If it's a straight MPEG2 remux of a 4:3 DVD then debug screen should say 4:3, BT.601, EBU/PAL, limited range. If it was transcoded by someone else, then whatever software they used could have fudged something, depends how they encoded it. I reckon it might be slightly safer to output square pixels over HDMI as I know the math MadVR uses is good on that. SD signals over HDMI have been dodgy for me in the past. If the show is 4:3 then you don't want to be pillarboxing that in the middle of 576p as the active pixel area will be only 540 wide which is lower than the source. The chroma shouldn't have issues as long as the final output to TV is 4:4:4 and therefore avoiding multiple 4:2:0 -> 4:4:4 conversions. I'm satisfied with Lanczos scaling for everything, except chroma I use bicubic old because it happens to smooth out chroma artefacts in any sources which have such issues. But in a double blind test on a normal quality source I can't really tell any diff. If I pause on a scene & Ctrl+Alt+Shift+F12 to Cb/Cr channel and flick between chroma algos on SD source then yeah I can really see a lot of diff. |
#63771 | Link |
The reason I have done the png screenshots like this is because for whatever reason, if I take a screenshot with vlc it has the gamma/colour different than when it's in the player so they couldn't be used. This is just to show the difference in the players during playback side-by-side.
Usually I use overlay mode, but switched to windowed so I could capture the image. Average rendering time can be ignored, it's only high because it's paused. ![]() ![]()
#63772 | Link |
Yes I see what you mean - VLC is rendering with a higher gamma it seems.
Check what settings you've got under MadVR's "devices > monitor > color & gamma" I'm not familiar with VLC but maybe it assumes by default that monitor gamma is 2.2 and SDR content is mastered at 2.4, therefore applying a +0.2 gamma shift by default - are there any settings in VLC which relate to this? If I take your madvr screenshot and darken gamma by 0.2 in photoshop it appears quite close to the VLC one (animated png): ![]() So basically if your monitor's gamma is 2.4 then VLC is too dark (it will be giving you about 2.6). If your monitor's gamma is 2.2 then VLC is roughly correct, but only on the assumption that most content - especially of that era of television - would have been mastered on 2.4 monitor. VLC's behaviour can be reproduced with madvr's color & gamma settings if you desire. Just keep in mind that room lighting affects perceived gamma due to "simultaneous contrast" effect - in a daylit room 2.2 can look similar to 2.4 in a dim surround. Last edited by flossy_cake; 19th January 2023 at 03:57. |
#63774 | Link | ||||||
I know what you mean about adjusting room light affecting perception, I do that all the time to make the picture have more depth, but the thing is, adjusting the lighting isn't going to at-all fix the washed out gamma issue.. if the room has all the lights off, or turned up high, it's still going to be washed, I'm still going to see the macro-blocks on dark scenes, etc. So it actually does need to be right when it is processed. I don't know what the issue is, if it's the file, if it's madvr, or if it's something else like vlc's d3d11 renderer being bugged and just happened to coincide with being correct for this file? But one thing I do know, this odd gamma issue with bt.601 doesn't happen really with bt.709. Just now I threw up a different file and compared them (with enable gamma turned off). On a scene that I paused, the madvr rendering had slightly better rendering in the darker ground shadow areas, but vlc's d3d11 had slightly better rendering in the highlight areas (clouds), but overall, it wasn't doing the great difference that it was with the bt.601 file. MPCVR renderer does the same thing with the bt.601/pal file like madvr, washed out gamma. PS. I haven't watched it yet, but the images were from a 1978 British series by Terry Nation called Blake's 7. "Blake's 7's narrative concerns the exploits of political dissident Roj Blake, who leads a small group of rebels against the forces of the totalitarian Terran Federation that rules the Earth and many colonised planets. The Federation uses mass surveillance, brainwashing and drug pacification to control its citizens." Last edited by Sunspark; 19th January 2023 at 05:35. |
#63775 | Link | |
![]() The amount of red in the cyan section is still quite different though - RGB (79,155,181) vs (73,154,182). The red sections behind it are identical though. Maybe something to do with gamut conversion... So you haven't told madvr that your monitor's gamut is BT.709 ? If not, then gamut will be wrong (assuming your monitor is BT.709). VLC may be assuming monitor is 709 gamut by default. Last edited by flossy_cake; 19th January 2023 at 05:58. |
#63776 | Link | |
However, turning on only enable gamma processing changes things. So if I tell it it's calibrated to bt.709/1.8 and set 2.40/pure in enable processing, it looks basically the same between the two players actually! So, is my understanding correct, that one needs to manually enter in the processing # based on the content? To use 2.4 for bt.601 and to change that to any number between 1.8 and 2.2 for bt.709 content? It would have been nice if it was automatic just based on the "calibrated to" setting.. |
#63778 | Link | ||
Also in the "this display is already calibrated" section, there is "this display is calibrated to the following transfer function / gamma". This appears to be used by MadVR as part of its gamut conversion formula only. For SDR content it barely affects the midtones (as you have noticed). It's not a gamma control, I think it's just one of the coefficients used in the gamut conversion formula, as far as I can tell. Separately to this in the other "color & gamma" section is the "desired display gamma / transfer function". This is a real gamma control and does change the entire gamma curve to the value you choose. To do such a conversion requires knowing what your monitor gamma is to begin with. If you haven't told MadVR what your monitor gamma is in the previous section (which happens if you select "disable calibration controls for this display") it assumes your monitor is 2.2. So if you chose 2.4 it would do a +0.2 adjustment. Otherwise, if for example you already told MadVR your monitor is 2.4 in the other section, selecting 2.4 results in no change in colour. We shouldn't need per-content settings since MadVR automatically gets the source gamut from upstream, and even if upstream doesn't have it, MadVR guesses correctly based on things like resolution and framerate of the video ("best guess" on debug screen) and I've never seen it get it wrong. So if your monitor has 2.2 gamma and 709 gamut, and you want to get accurate gamut conversion for SD 601 gamut content, and additionally emulate what VLC appears to be doing: 1. calibration > this display is already calibrated > BT.709 & pure power curve 2.2 (informing MadVR your monitor characteristics) 2. color & gamma > enable gamma processing > pure power curve 2.4 (emulating VLC behaviour of assuming SDR content was mastered at 2.4 gamma by applying a +0.2 gamma shift) The downside to 2 is that it will cause MadVR's HDR->SDR conversion to be 0.2 gamma darker than it should be. To avoid this I only set 1 and not 2, and calibrate my monitor to 2.4 for night and 2.2 for day in the video card gamma table which is system-wide. Quote:
Anti ringing seems ok and has a subtle effect when used in conjunction with sharpening filters, but doesn't seem to be effective at removing ringing in the source, eg. S01E01 of The Sopranos Bluray has some ringing that I wanted to get rid of and it couldn't help there at all. Last edited by flossy_cake; 19th January 2023 at 09:40. |
#63779 | Link | |
#63780 | Link |
I don't think it looks for ringing at all, it always runs another algorithm after scaling which makes aliasing a little worse while also making ringing better. It is based on the known amount of ringing added by the scaling algorithm, not an analysis of the image after scaling.
madVR options explained |
| Tags |
| direct compute, dithering, error diffusion, madvr, ngu, nnedi3, quality, renderer, scaling, uhd upscaling, upsampling |
| Thread Tools | |
| Display Modes | |
