Thread Tools Display Modes
Old 18th September 2017, 20:27   #45761  |  Link
steakhutzeee
steakhutzeee's Avatar
well maybe depends on your screen.
I'm on an Asus VC239H 1920*1080 FullHD
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM
steakhutzeee is offline   Reply With Quote
Old 18th September 2017, 20:33   #45762  |  Link
default should be fine.
Old 18th September 2017, 21:21   #45763  |  Link
steakhutzeee
Let madVR decide?
Old 18th September 2017, 22:18   #45764  |  Link
Manni
Anyone knows why 4K60p RGB 8bits Full would give a magenta tint when playing a video with MadVR, while 4K30p RGB 8bits Full or 4K30p RGB 12bits Full would give the correct colors? 4K60p YCC 4:2:2 12bits give the correct colors too (4:4:4 isn't possible due to bandwidth limitations).
As I set the nVidia panel to 12bits RGB in 30p, the bit depth goes blank when playing 60p (it does send 8bits automatically to fit into the 18Gb/s bandwidth limitation of HDMI 2.0), so I tried to force the output to 8bits at 60p (8bits showing instead of blank in the nVidia control panel) and I get the same results.
I checked and it's not a wrong colorspace selected in the projector (whether I select RGB or YCC instead of Auto the colors are wrong at 4K60p in RGB).
Win11 Pro x64 25H2
Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac Core OC 5090 32GB 581.42
jRiver MC / MyMovies & Dune Pro Vision 4K / Ugoos AM6B+ with CoreELEC A14
Denon X8500HA>HD Fury VRRoom>Samsung 77S90C
Old 19th September 2017, 00:56   #45765  |  Link
dvd1
Banned
D3D11 on 576 and D2D9 on 1080p
why D3D11 on 1080p is not there?
graphics card 1050 ti
thank you
dvd1 is offline   Reply With Quote
Old 19th September 2017, 02:36   #45766  |  Link
SamuriHL
SamuriHL's Avatar
I think I've got my setup pretty well dialed in at this point. I may mess with it more cause that's how I roll, but, I'm watching Revenge of the Sith right now and the quality on my 1060 is phenomenal. I very much like NGU AA High for Chroma upscaling. Since it's blu-ray I don't have any other scaling active at the moment. Using the D3D11 decoding in LAV nightly. Very pleased!
(What I've changed recently is turning on pure direct on my Panny plasma and setting everything to RGB FULL. Working great!)
Old 19th September 2017, 08:18   #45767  |  Link
x7007
Hey,
Why MadVR can't use Full Present Queue ? it just stays 0-1/8 for 4K HDR. and the rendering is 25-32ms ...
x7007 is offline   Reply With Quote
Old 19th September 2017, 08:26   #45768  |  Link
nevcairiel
Your GPU is too slow for your settings if this happens. Its 60 fps content, rendering times over 16ms are too high.
Old 19th September 2017, 08:32   #45769  |  Link
x7007
right... insane ,,,, we need better card then 1080 or 1080 Ti to be able to run with NGU ....
Old 19th September 2017, 08:44   #45770  |  Link
oldpainlesskodi
Originally Posted by x7007 View Post
Hey,
Why is your system downscaling Luma?
Same clip here (albeit my clip reports HDR 1000nits) on a 1080ti using DX11 Native and NGU AA med for Chroma @ 11ms render times.
K
oldpainlesskodi is offline   Reply With Quote
Old 19th September 2017, 09:25   #45771  |  Link
Originally Posted by steakhutzeee View Post
Let madVR decide?
yes.
thank you
decoding or presentation both? what are you talking about.
make a screen to show the problem.
Old 19th September 2017, 11:52   #45772  |  Link
Magik Mark
Guys,
Need your thoughts.
Using MPC BE I get perfect sync for my display 23.976hz using madvr custom refresh rates using 10bit & 8bit
However,
Using DSplayer I only get perfect sync using 10bit. if I set madvr display output to 8bit, refresh rates is only 23.970. This results to frame drop every 3 minutes
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR
Magik Mark is offline   Reply With Quote
Old 19th September 2017, 11:58   #45773  |  Link
ryrynz
ryrynz's Avatar
Please don't quote superfluous images in a reply.
Old 19th September 2017, 12:01   #45774  |  Link
oldpainlesskodi
Sorry? I quoted with the image because it was far from superfluous...
K
Old 19th September 2017, 12:29   #45775  |  Link
pirlouy
_
Quoting is at 90% misused
[IMG] is often useless and destroys formatting, and quoting a big image is disrecpectful.
And for your question, luma is downscaled because if you look at this enormous image, you'll notice he is in window mode.
@el Filou: you can test D3D11VA deinterlacing with mpv if you're really interested, but not to be discussed here.
Old 19th September 2017, 12:38   #45776  |  Link
oldpainlesskodi
I think that was my point..
K
Old 19th September 2017, 12:51   #45777  |  Link
el Filou
el Filou's Avatar
@oldpainlesskodi : it was superfluous because the (massive) image you quoted can be found literally 3 posts above
Old 19th September 2017, 14:25   #45778  |  Link
dvd1
Banned
576 D3D11
1080P D2D9 . why D3D11 on 1080p is not there?
Old 19th September 2017, 15:27   #45779  |  Link
steakhutzeee
treat 25p movies as 24p (requires Reclock or VideoClock): [Disabled] Uses 24 Hz modes to display 25 fps content, it requires Reclock or VideoClock to slow down the audio to match.
hack Direct3D to make 24.000Hz and 60.000Hz work: [Disabled] A hack to Direct3D that enables true 24 and 60 Hz display modes in Windows 8.1 or 10 which are usually locked to 23.976 Hz and 59.940 Hz. May cause presentation queues to not fill.
I'm on Windows 7, where can i learn about these? What means "treat 25p movies as 24p" etc.? Don't know what nomenclature are.
Old 19th September 2017, 15:37   #45780  |  Link
@dvd1
are you using profiles in rendering?
Thread Tools
